Everything posted by wickmyster
E36 318is Spark, but not power to fuel pump 0_o HELP!
wickmyster replied to wickmyster's topic in Tech Talk
Hmmm, still hitting brick walls, I am about to try out my spare cranks angle sensor. I ahve read it thaty dont put out a strong enough signal that is can cause the power to be cut to the FP. -
Not yet, but he told me hes talked to the past 5 of the 7 owners of his coupe, THat is pretty impressive!
My E36 318is has park, but not power to fuel pump, so I am guessing crank angle sensor is ok...what else do I check? Waht else stops power to the fuel pump? I might get the voltmeter out agin soon and have another prod around. Any ideas? It does start from time to time for 2-3 seconds then dies. It but out on the way home for 5 seconds, kicked into life again then died completely
Hahah yeah, he caught me on facebook XD did he message you on fordforumns?
Fingers crossed someone sheds some light on these soon. I am not having much luck tracking donw the dealership this was sold at :/
Yeah, not to worried if it was a ford/dealing thing or not, would just like to track some down. I will have to have a chat with the pervious owner, he must have some more photos somewhere.
It was dealer fitted, the guy I purchased it off had it for 35 years, and I have hit up the aussies on http://www.fordforums.com.au/showthread.php?p=4489739#post4489739 but still no progress
It is also not a McLeod Ford Horn Car stripe, guess Ill ahve to try track down which dealer sold it and go from there.
I need help identifying XA Coupe factory decals. I am trying to find what models and where to get a set of these stickers or some clear photos so I can have them made up. I am wanting to return my coupe back to its factory specs (other than wheels, and twin headlight conversion; D ). Does anyone have any info or pictures of these stripes? http://tinypic.com/r/sw8j8j/6
ZF Fairlane H/light bracket work for Xa GT twin headlights?
I am after the distance between the drivign lgiht rings and the headlight rings on a XA GT grill. Can anyone help? -
I recentl bought some driving light rings for my XA coupe and I am after some measurements of the gap between the headlight rings and the driving light rings. Any help willo be greatly appreciated!!!
http://www.curbsideclassic.com/wp-conte ... d-tilt.jpg Hehehe
Ignore post, just a blonde over tired moment XD
Looks to be the under side of an XA-XC coupe :/ Is it just a different live axle set up?
As per pic in link. http://www.freeimagehosting.net/da2mj Can't remember if I took this photo or now, but has been on my PC since 2006.
yup, i have found a second hand engine with 120,000ks that has over heated. waiting to hear back from guy though....
I am on bimmersport atm XD. My engine has done 297000k on the original chain etc. Will put a new tensioner on soon to see if it stops the rattle and I will pull of the sump to see if there is anything suspicious and the rocker cover to see what the sprockets are like.
I am wanting to do my camchain guide sprockets etc on the e36 318is but where can I get them for under $700?????
As per title....Do mk2 escort two door back seats fit into a mk1 two door??
This car does not ahve a crank angle sensor...will check of rotor is spining in dizzy next..and the the leads.
HELP...my 1993 Celica died while driving it (Suddenly), there is no spark, I have replaced the coil and the alarm relay. There is power getting to the coil. Any ideas????
Do mk1 capri diff heads fit into escort diff housings?
Here is a pic of the actual car I am wanting to get the diff from. http://www.freeimagehosting.net/5f5wv Whichdiff is that? -
Do mk1 capri diff heads fit into escort diff housings? I am looking at a mk1 capri factory 1600OHC diff head as I have heard they fit into escort houseing and are a lot stronger!! Any one have a clue?
Is a 2.3 cortina V6 solex a good carb upgrade for a 2L pinto? Does it bolt onto the manifld, if not , how hard would it be to fit?
Able to be fitted into a mk1 though? Even as a temporary fix?
