Posts posted by 77magnum13hundy
Yes that's the right one that will bolt up to block... I'll see if it's the same as l200 as mentioned in earlier post
not sure if this is the same as an l200 gearbox but it can be done... go have a look in http://www.projectzerog.com/
for my mates l200 he got a AWD flywheel machined out a spigot bearing hole and found the smallest l200 clutch available with the correct input shaft.
Its not that easy, cos you have to suss out the flywheel and change ring gear and make sure the starter works... also narrow or wide block will be the crucial matter.
oh i dunno how its wired but usually they have 2 other wires ones charge light the other is a 12 v ignition source(apart from the big batt feed), you dont need a charge light but its handy, but re-run the 12v wire directly from the key, this one switches it on or off. Its either that or its a faulty component in the alt.
just grab it off them and when you flick it onwards give them some of the proceeds, i'd never buy a car off my olds id just start using it and give it a nice tune and some fresh fluids etc. If they want money for it then just give them a few hundy. do they use it? if no then sweet.
Cherry bomb, although you should make it match the drapes and the carpet....
if you know what i mean
oh man cant wait to see what this does...
oh yup true, give old sterling a bell, located in onehunga...
http://www.sterlingbrake.co.nz/
also depends on what its doing and when, ie does it piss out when pushing pedal in or when releasing the pedal?
just replace the whole unit master cylinder, depending on what car its for and availability...
if not then sort the seals out, flush the whole system (brakleen) and put new fluid in at least. also having that fluid going everywhere its a paint stripper so once its sorted make sure you deal to the places its stripped,
if its not the master cylinder then check the hose, down to the slave. You'll have new stuff sorted for under a hundy buck.
cheers will crack on with it and see how it goes... hopefully not the cracking part! awesome lads.
hey folks
ive heard theres a trick to putting a window back into car with a peice of rope/string but didn't find any decent youtube videos or maybe i didnt look well enuff
Any peeps here can chime in on how to do this...
Cheers
Rob
In the projects section is where you should start a thread for your sigma, there are a few of these kicking about and a few experts on the forum, suss out how to upload images and then paste the link in a new post. Go check out the projects section for some ideas. If you have a good look through here you will be able to suss it out. Posting photos go here
Welcome
when do you need it by? I gotta 3/8 teng talker here if you wanna borrow FYI
also when starting the car in P (park) does it make a difference if you try in N (neutral) at all? happens on the middys car and this solves it, the not starting part. Applicable to autos
Oil pressure switch wire loose on some cars effects the starting as well.
That is sweet... Hope its not too difficult to restore... Sounds like a feckin idgiot that fulla
ready to try this...
Ask Andre, nzvohc, as he has a fair few bits for them boat anchor engines.
sweet will do, went and got some new front wheel bearings today, same ones listed for vc ve vf valiants and early toranas so may have a few hub ideas later down the track...
A-Frame towbar, professional grafter
fuck yeah il take that... noone else had a tandy and trailor was headed for the scrap man anyways... wasnt too bad for the little 1.5 donk
not much left that wasn't salvageable... will be getting back into the shell now for some finesse touch ups with the mig...
Has anyone got any 1800 slant parts; need bottom pulley and fan/waterpump pulley (or knows if the 2.3 is the same).... keen as for one of those... cheers
Aw yeah... One of them pssssst woosh things
maybe not hb, is there much difference in the mounting points? anyways i see now they look to have a raised bit in the middle which these ones dont.... as you were
have a few bumpers as well alex, dunno about if the chrome is of quality or just cheaply done but they are shiney... but nonetheless ive got one here if no go with vivaspeedgeoff... goddam tailgaters... need to activate the smoke screen out of the exhaust system next time so they back off a bit/ fumes all up in their grill
i now know what you mean about the steering wheel facing inwards a bit. Didn't notice till i fitted a racing wheel... draws you into the centre of the car instead of straight ahead from the seat...
do you mean 6 mill pipe to feed fuel rail?
starion conversion in l300
in Project Discussion
In your case it should just be sorting clutch plates and flywheel then...
