Taistorm
Everything posted by Taistorm
Fake news This still exists, its not full of rat droppings and looks basically how it was left (bar some extra cobwebs). The boy was stoked to check it out. Pretty happy as that the seats haven't been eaten up by rats and the engine still turns over all good by hand. I've just moved back to NZ and now living up close to where it's stored. Slowly getting the new rental setup and shifting all the stuff that I left at mum and dad's over. I'll start sifting through the car parts and bits and pieces soon, then make a plan on the next step with the slow burn build. Stoked the shed hasn't fallen over yet as the posts have all rotted out haha. See how we go anyway. Chur, Tai
- 140 replies
- 16
She lives! Filled up the engine oil, gearbox oil and coolant. Fitted up the wheels and put it on the deck. Hooked up the battery and gave it a go. Surprised as it started first go, no visible leaks. Didn't rev it up or anything as it needs the tuner box hooked up and a proper tune, also need to swap the fuel pump over from the 265 due to the new system being rising rate so it has a different internal fuel reg. Stoked!
- 29 replies
Haven't touched this for a little while but I got some time in the last couple days. I finally got both new gearbox output shaft seals. Fitted those (lh side was a prick due to lack of space to punch it in, wish I did this with the box out. Rh side was a piece of cake though). Also reassembled the hubs, steering, suspension and brake parts. Got the rest of the hoses, plugs, brackets, battery box, battery, front bar etc in. i had to extend the wiring for the throttle body and this intake sensor (map sensor I think). Also had to clearance the fan shroud a little more for the throttle body sensor. I'm not overly proud of how the throttle body harness section looks. I had to run thicker gauge wiring and only had smaller split conduit so had to run half the wiring across 2 sections so it looks stupid. Oh well, it will do for now. And the engine cover still kind of fits. Looks oem enough anyway. My situation over here has changed and we are now in the process of selling our home to come back to NZ. This will be up for sale in Perth shortly so there's only a few little bits I'll do before then. Another incomplete project but hey, hopefully I'll have some spare change to throw at my mazda when I get back. Chur
Wedding car feelers - Auckland and beyond
Taistorm replied to Taistorm's topic in Upper North Island Region
Haha what a thread dredge. No divorces yet unfortunately haha. My mate ended up just getting a couple vip mini bus things which ended up being awesome (no way near as dope as it could have been though...) My wedding still hasn't happened yet. Covid restrictions stopped it from happening so had kids then moved to aus. Probably go do a helicopter elopement later this year in Queenstown I think. -
Probably the last bit of work on this until next weekend as I'll be back at work from Tuesday... Had another look and think about fitting the rs225 throttlebody. After some quick measurements I reckon I can trim down some of the excess manifold flange meat and drill a couple more holes to get it to fit up, if I change the engine lift point over from the 225 as well. Some quick measurements and cuts/grinding. Mark some holes, drill and tap. Mock up then fit. didnt think about clearances on the front side, so i had to trim the radiator fan shroud a little bit. And a quick mock up of the coolant hoses. Should do the job I reckon. Save me some time and effort making up a custom adaptor plate. Chur
Small daily update. Refitted the lower engine stabiliser mount - I've reused the old one, the inserts I've purchased only replace one of the bushes that's torn, not the other so I'll look at just buying a replacement unit. I also got my spanner back and finished tightening up the transmission mount. Exhaust fitted. I had to swap the rs225 intake pipe onto the turbo to get better clearance over the brake slave cylinder. So cleaned it up and fitted it. I also bought some vacuum hose and fuel vapor hose for the breather piping. Rerouted everything to suit and re routed the fuel line as they're different across the 2 cars. So now the fuel lines are sorted, crankcase vent pipes and inline valving is sorted, and Brake booster hose sussed out. I'm not overly happy with the fuel hose layout so I'll change it over later. Luckily I could reuse the push oem push lock fittings. I ended up just hose clamping new hose onto the barbs. Chur
Cue "It was a good day - Ice Cube". Donk and box back in the hole. Oil filter housing/oil cooler swapped over aswell with new filter on. Just awaiting pick up of my work ute tomorrow (as it's having some recall work done) so i can get some other tools i need to carry on with assembly. Stoked as to see the gap filled! Chur
- 29 replies
- 17
Drilled and tapped an additional mount hole for the engine upper timing cover/engine mount. This is due to a variation between the 2 top covers and the 265 inlet manifold not having the provision for the additional mount. Upstream o2 sensor back in and rs265 exhaust cover fitted. I did a half ass job trying to clean off some of the melted plastic from the engine bay. And lastly for the night ive swapped over the lower engine stabiliser mount and rh drive shaft hanger from the 225 engine. Hopefully I'll have this bolted back in the car tomorrow evening. Chur
- 29 replies
Couple hours in today. Looks like the breather/decanter plate has been leaking (top plate on the rocker cover). Removed it, cleaned it up and refit with some Three bond sealant. Also cleaned up the ignition coils and replaced the dust seals (just used some orings I had) and refit them. Gave the rocker cover a very quick degrease. Quick clean of the ac compressor and refit. Also fit the drive belt. Swapped over the required sensors from the rs225 engine. Also swapped over the thermostat housing. Reused the old thermostat. The seal seemed ok but i gave it a light smear of sealant just incase.
Also began swapping over engine bits. Turbo coolant lines were slightly different. Instead of swapping over the inlet/outlet block from the old turbo I decided to just swap over the hoses. I trimmed the inlet hose and swapped over the heat resistant sheathe. Oil filter housings also have different coolant line inlet/outlet points so I began to swap these over however I didn't have a suitable seal, so I'll need to sort one of these out in the next few days. Rs265 rs225 the alternator/ac compressor mount block is also different so these are now swapped over. I also uncovered the reason for the 225 engine not running. Hole in the side of the block. Conrod must have fallen apart... swapped over and alternator mounted. The compressor needs a bit of a clean up before I refit it. The rs225 drive belt and tensioner were replaced not long before it went bang, so I'll be using reusing these. Also had a look over the throttlebodys to see what's needed to adapt the 225 tb to the new manifold. I should just need a 10mm block of alloy to make an adaptor plate. 225 on top, 265 below. Clearance needed. Happy new year OS. Chur
- 29 replies
- 16
Went to fit the clutch last night but I couldn't get it on as the disc was too proud and the mounting bolts couldn't reach the threads in the flywheel. Turns out I had no idea that self adjust clutches were a thing, and this one needed to be reset/compressed. Drove around this morning trying to find somewhere open that might have the tooling to do this for me but no luck. Found some clips on the net so I made a jig up out of a broken dolly board, used a piece of m10 threaded rod I had up the middle, mounted the clutch disc on some nuts as spacers then used the old release bearing wound in to free up the pressure, reset the springs, then backed it off to reapply pressure. I realised that the new bolts i had were actually slightly shorter than the old ones so I used the old ones to begin clamping the clutch assembly together, enough to get the new ones on then swapped them out and sent it home. Gearbox quickly cleaned up, new release bearing/concentric slave cylinder fitted. and rs225 box mounted onto the rs265 engine. stoked to see it together!
- 29 replies
Keep the minimal momentum going. Quick clean up of the back of the engine, remove the rear crank seal and fit the new one. Fit the new single mass flywheel with new bolts. Also cleaned up the rs225 starter motor and corrosion from the terminals, swap it over and mock it up. Because I'm on a bit of tight schedule (to get parts over from the uk) and don't want to spend bank on new exhaust gaskets from renault (plus shipping from sydney), I'm reusing the old exhaust outlet and dump pipe outlet gaskets. I've cleaned them up, doubled up with both the old ones and smeared a tiny bit of copper sealant (probably won't do shit). Should seal up alright I reckon. Fitted new exhaust studs as well ( turbo exhaust shield is only mocked up on top). ill try get a couple hours im each day, juggling around the kids and house painting haha. Chur
More downpipe spam. Ground out the outlet flange to match the larger pipe, picked up some titanium exhaust wrap and wrapped it up. Pretty stoked at the outcome tbh! Chur
- 29 replies
- 15
Managed to get a little bit of time in on the exhaust today. Made a mount bracket for the original mount. Fucked up the position but was close enough. The bolt is siezed on the manifold so I'll just weld the bracket onto the mount when it's bolted in place cause I can't be arsed trying to remove the bolt. Old oxygen sensor bung removed and welded in place. Very close fit but it should work. Extra bung for the afr. Mocked up. Cleaned up the welds and painted it black so you can't see how average it is. I'll try get some exhaust wrap tomorrow as well. Lastly I just need to die grind the outlet flange to open ot out for the larger pipe but it's more or less done. Chur
Hey Simon, The evaporator is there and youre right, id have to pull the dash out to get to it, however I'm in Perth, Australia. If you're interested we can probably work something out and ship it over. Cheers
Thought I'd have a go at making a decat turbo downpipe as the factory cat pipe is very restrictive on these. Luckily picked up some 2.5" bends from the only exhaust shop that I could find that was still open a couple days before xmas. Removed the old downpipe, a couple studs were siezed so had to cut and extract them. Welded a piece of flat bar to the flanges for the position. Cut off what I didn't need then cut and welded I'm some pipe. The welding is pretty atrocious but solid enough. Still need to weld in 2 more oxygen sensor bung and I'll probably heatwrap it but it should help it breathe a little. Hopefully have some more updates across the next week. Chur
I've been gearing up across the last month in anticipation to try get this thing back together on the xmas/new years break. Parts shipped from rstuning and engine dynamics in the uk, auto Paris and car mods australia over East. Comprised of the timimg kit components, rear main seal, clutch and flywheel bolts, negative battery terminal, engine upper stabilizer mount, engine lower stabilizer mount inserts, rs limited tuning box amd an aem afr gauge kit. Also some oils and fluids from Repco.
Difference in intake manifolds. 265 225 Also was having a look at the exhaust downpipes. Both 225 and 265 are 2.5inch but slightly different in design. Both terminate to the exhaust in the same spot. As I'm wanting to decat the system as it's a huge restriction on these, if I can't get a second hand one cheap enough I might just by some pipe and bends and do it myself. The factory 225 exhaust is 2 1/4inch and the 265 looks to have an aftermarket 3inch exhaust (flexi is torn and brackets have broken off at the front). Might see if I can repurpose the 265 exhaust and bodge something together for the 225. 225 265 Might order the mounts this week and hopefully get a rear crank seal, gearbox input and output seals as well. Chur, Tai
Not a real update but planning the next step and to organise new parts. Have been super busy with house reno's and family coming over for a holiday plus other family duties since last post. Had a quick moment today to check over a few things. Firstly, the engine mounts and timing cover swap. As there are a few differences a d changes required to get it to work. Rs225 Rs265 Covers and mounts side by side (265 on top). The 265 cam cover has an extra 2 smaller bolt provisions on the top for the top timimg cover. The top engine mount on the 225 also has an extra mount point which bolts onto the intake manifold. From what I've gathered, most in Europe who carry out the conversion drill and tap into the intake manifold to allow for the extra bolt. I'm thinking I might just swap over the 225 intake manifold/throttlebody/injector rail and injectors onto the 265 head. Reason being is that I'd need to swap the 225 tb over anyway (as this is known to have random cut out issues if running an rstuning box), also I can just run the factory fuel system and do away with the rising rate fuel setup. This gives me the oem provision for the top engine mount bolt hole and I can also run the factory engine cover if I choose. Also checking over the rear engine mounts. Upper 265 225 Lower 265225 I'll need to swap over the 225 rh cv shafts hanger and lower mount bracket (engine side) and run the 225 dog bone mounts. Both of mine are torn so I'll just order some new ones.
They always seem to have the oddball stuff at Sterling. How good though? Had a look at nz suppliers but nothing was comparable to the UK on pricing. Xtreme clutches here in Aus were wanting just shy of 3k for a SMF conversion kit. So I decided to put an order in at RS Tuning in Leeds, England last week as it was almost half the price. Posted on Friday and arrived on Tuesday, but I wasn't home to sign so they delivered it again today. Can't believe how fast though, it takes longer to get something sent local hahaha. R26 LUK organic clutch with Valeo slave cylinder and a TTV single mass flywheel. Got slammed with $317 import tax though which was annoying. Now I'm just waiting on them to stock up on the Tuning box to order. I also need to get a rear main seal, gearbox input and output seals and some new torque mounts amongst a few other things. Chur.
Got a bit more time in on this today. My son had a bad fever since Friday night so Saturday and Sunday morning was a write off and now my daughter is sick. Had to wait for everyone to go bed before I could crack into it haha. Drilled out the fucked lh brake disc retainer and got that off. Dropped the lcas and links, removed the cv shafts carrier and popped the shafts out. Remainder of the wiring removed and pulled out of the way, gearbox cables and last few hoses off. Needed to grind down a socket extension for a service on a Renault engine turbo diesel v6 navara the other day so now I had a 8mm square drive socket to drop the engine oil. Did that, as well as the trans oil. The exhaust decided it wanted a one out so I had to fight it the whole way. 3 lower cat flange bolts were seized and rounded upon trying to remove. Top flange had no access to 1 nut, the top came out but the other started to round. Decided to unbolt the exhaust by the centre muffler. Engine and trans mounts unbolted (trans mount is a stupid ass design and the lower rear engine mount is fucked) and then tried to swing it out. The exhaust didn't want to come out but now I had access to the remaining top flange nuts so gingerly got them off and now I could pull the donk out. Also had a quick look at the weird black stuff sprayed around the engine. Looks like the lower timing cover plastic has been chewed away at. I'll get it off another time and see what's going on behind there. Gonna look at ordering a SMF conversion, clutch pack and slave cylinder from the UK and possibly a RS Tuning box for this maybe this week. Chur, Tai.
Not a proper update. Haven't really had time to work on this, however I got the wheels and brakes off. LH brake caliper taper torx retainer bolt broke my torx key which was fun. Then it stripped o the other side... Also the battery tray wanted to fight me as the mount torx caps crew stripped so I had to drill it out. Don't have time for this nonsense, have enough of these issues at work playing with machinery haha. Also split the gearbox off the 265 engine to return to the bloke I bought it off. Managed to line up a few parts for sale off the 265 so hopefully the engine will half pay for itself or more which would be a win. Chur.
Managed to sneak in an hour on this after the kids went to bed. Front end off, bit weird getting the bumper off but everything else so far has been nice and easy. Also noticed this black substance sprayed and melted all around the front of the engine area. Wonder where it's come from, will soon find out. I reckon another hour or 2 and I'll have the engine out. Will see if time allows tomorrow. Chur.
Engine out. What a prick trying to remove the halfshafts. Ended up pretty much unbolting the whole knuckle & strut and everything connected as the lca was being a bitch. Of course half the exhaust fasteners were seized as well, couldn't unbolt it from the bottom side of the cat, so ended up managing to remove it from the top. Out it came though. I will need to grind off one of the cat lower flange studs though. Trolley worked a treat. Had to lift and shuffle it to turn it due to no castor's but it was easy enough. Length was perfect for both the box and engine as well. I might try and do some work during the evening this week but we'll see what happens. Chur.
- 29 replies
- 18
Managed to sneak in a couple hours today. Got the lacky to set her up... Then proceeded to start the strip down for engine and gearbox removal. A little bit more time and I'll have the donk out. Just need to disconnect the fuel lines, clutch line, exhaust and halfshafts. Hopefully time allows next weekend. Chur.
- 29 replies
- 15
