mlracing.co.nz
Everything posted by mlracing.co.nz
Nah it still goes it's just got no balls. For example if the wipers are not on the windscreen then it will go but still shittily, however when the wipers are on the windscreen sometimes it can't even move them. I could take it all apart and have a poke, and it's definitely still an option. I agree, I think that S13 one is a no hoper
mlracing 1971 Skyline 2000GT Sedan (Hakosuka)
mlracing.co.nz replied to mlracing.co.nz's topic in Projects and Build Ups
OK so the 180SX wiper motor arrived and after closely inspecting it I can't see any easy way to make it work. None of the brackets line up (could make custom though) and the size is a bit different. So it's definitely not quite anywhere near bolt on. Even once I remove the mounting plate on the original one there's not really any way to easily attach it to the new one. Will have to think a bit more about the strategy. I'm not sure if this will be the same for other countries or models but this one is from a 180SX Type X, so later model. Perhaps early model ones are more suitable. I'll continue to look out for something a bit older and around the same period before destroying this one. -
Ever since I've had the car the wipers have not been great/hardy work at all so my mission today was to remove the wiper motor because I've been told that S13 ones can fit with some small adjustments. I was a bit worried that when I pulled off this cowling there would be epic rust underneath but actually it's very tidy. The cover has a little surface rust under it and on the car side the rust looking marks are just dirt from the seal being damaged and letting muck in. I've ordered a new seal to replace it. Also, an enterprising fellow the previous owner must have been as the rubber cover you see there above the access hole is actually the sole of a shoe. It worked well so can't complain. I had to cut it up to get in there though so I've also ordered the correct replacement rubber part for when it goes back together. The wiper motor is actually inside the car behind the glove box. Initially I couldn't work out how I would get to it but ended up quite easy once I actually had a proper look at it. That's the thing with these cars, once you slow down and have a bit of a snoop around it's pretty straight forward how things go together. Because of this you can get quite a bit of satisfaction from just doing simple tasks because you can actually do them! Also fun note, the glove box is made of cardboard material. As you can see it's pretty weathered and you can get new ones but at this stage it's not super high on the priorities. I could unstaple it and even make my own one using the original as a template if I really wanted. Got em! The S13 one should be here sometime earlyish next week so it will be interesting to compare the parts and see what I need to change. I've read that the shaft that connects the linkage to the motor needs to be swapped and maybe some wiring needs to be tickled but as I've not actually seen a proper write up on the process (in English anyway) I figured I'd give it a shot and see what happens. Can't get any worse.. Discuss: //oldschool.co.nz/index.php?/topic/49704-mlracings-hakosuka/page-7#entry1661447 -
Turns out I'm just a retard and somehow got the wrong one despite the listing saying for my year of car grr >_< Oh well, just ordered a bunch of other stuff too.. -
Parts parts parts parts Slowly I pick away and find things to buy to fix up the car, this morning a package arrived with Nissan OEM brake lines (seems like clutch lines are the same), Nissan OEM shift boot and also a rubber boot to go under it all as mine didn't really have one. Immediately run into an interesting problem. There are two types of these rubber boots listed for Hakosuka depending on the year, I picked up the one which was suitable to my year but it seems like the shifter itself is in the wrong place. So that makes me wonder if the gearbox is not a Hako gearbox, could be from any number of Datsuns of similar vintage. Regardless I put the boot there and it's kind of just sitting as it is better than nothing. This waas what was there before.. The shift boot looks cool! I just need to get a new chrome trim ring around the plastic where the shifter goes through. It looks like to get the boot to stay up it folds around that trim ring then the trim ring is screwed from below. I'm actually looking for a full new console as this one has cracks and various repairs etc out of it so not that great. Discuss: //oldschool.co.nz/index.php?/topic/49704-mlracings-hakosuka/page-7#entry1661447 -
Classic car Nagoya is sweet, I went there a few years ago. Saw my first Z432 there.
Epic super charge!
I'll just clean them up and jam them on the L28 see how it goes. No major (except for the cost) if I need to take them off and replace them with something bigger. Also did play with the idea of putting them on the current L20..
Haha that kit costs at least double what I paid for the car T_T
Latest parts container has arrived so I went down for a nosey before the stuff gets delivered to our dispatch facility. Picked up a few things (Heaps of Boss coffee in stock now for anyone that's interested). There was a nice box that said my name on it and look what's inside! Ohhh, ahhh. Mikuni Solex 40s. Come off the L28 that is also in the container. I'm told explicitly not to open them up as they're setup and run perfectly for L28 with big cam on stock bottom end. Super happy the throttle linkage has the adapter on it for cable too, makes life so much easier as mine uses cable not linkages like the twin carb ones. Also these came in the box, some ancient MSD system. Looks pretty full on, not exactly sure how this would be set up or if I'll use it but will investigate that further down the line. Also these old as electric fuel pumps, neat! They look well used that's for sure. Shit yarns: //oldschool.co.nz/index.php?/topic/49704-mlracings-hakosuka/page-7#entry1660864 -
AE86 is on my garage wish list buttttt... I'll stick to the Hako for now haha
Did a couple of small bits the other day, decided to see why my wiper motor was not really doing a good job and install the rear emblem as well as finally put on the hood latch handle thing. So basically when I got the car it didn't have a proper handle connected to the wire to pull the bonnet latch so what I ended up doing is getting this washed and knob setup there which was ok but still difficult. Most excellently I found a whole wire on Yahoo but as it turned out I could just unscrew the handle bit and screw it onto my current wire which was great because it looked quite difficult to get the other one out. Next up I attached the emblem that I sort of reburbished just using some double sided tape (the kind used to attach wings and such) so that isn't going anywhere. Looks sweet! Also mocked up the black bit there but I still need the trims that go along the top and bottom then I can attach it on there properly. Still debating whether or not to get a badge for it, probably will. Next step rip into the wiper motor.. so what happens is when the wipers are on the windscreen it has one speed, slow. Despite having multiple actual speeds available (slow and slightly less slow). My first port of call, the switch. Sometimes people jump the switch if there's a problem or do some different wiring or wahtever. Definately some.. typical wiring jobs under here.. This one, twist and taped (and a gear boot which is broken that I have another one on the way). This one, casual wire just hanging around. This one, some kind of twist and tape splice method, appears regularly. Old mate twist (no tape even on this one). This is what I mean about the twist and tape splice method.. sans tape. Anyway after all that I did another test with the wipers not on the windscreen and it does change speed so I think the motor is just old and worn out and can't put through the power it needs. So I've got a couple of choices here.. I can take it out and see if it can be revamped somewhere or get a different one. I've been told that S13 ones may be able to work so I'll investigate both options. Also I got rid of a bunch of redundant wiring that I suspect was for the head unit/navi that was probably there before. Also I thought the car may have been red before and repainted to silver.. now I wonder if it's always silver and the floor was just red? No idea really.. probably had some shitty rust repair done on the floor before and maybe it's a coating or something. Yarns: //oldschool.co.nz/index.php?/topic/49704-mlracings-hakosuka/page-7#entry1646412 -
Gave the badge restoration a go. Restoration is probably a pretty loose way to describe it but I gave them a recolour. For the GT badges just used a blue Vivid, probably didn't quite turn out as I'd like, not really dark enough so I might get some blue model paint to do those at some stage. For the SKYLINE badge I used some model paint and tried to use a while paint pen to get the white bits but I think it was almost drying before it even got out of the nozzle so that didn't quite work out. May get some white model paint at some stage too but probably will be OK for now. -
So previous owner debadged the lot and removed a bunch of trim. This is common as GT-R doesn't have the same kind of trim as the lower models and people try to go for this look. Being that mine is not a GT-R and not trying to be, I want to put the trim and badges back. Only problem is the previous owner covered over the holes which are typically used to hold on the badges etc Deciding what to do but I may just use tape to hold most of them on as a few of the mounting prongs are damaged anyway. Still deciding.. Also my bonnet cable is missing the handle so picked up another one of those to fit! The badges will need some restoration anyway so will need to research the best way to go about doing that. Discuss: //oldschool.co.nz/index.php?/topic/49704-mlracings-hakosuka/page-7#entry1646412 -
Haha OEM L28 sounds good to me with hot cam and big carbs Just buying out what stock Origin has in Japan at the moment haha
I'm still out of country not getting back until next week but I had these come through from depot during the packing of the container (which will be here shortly as well).. It's got a busted bottom end apparently, but block should still be OK. The boys also tell me it has a big cam but not sure spec on anything. -
Haha cool, I think it used to have white 17s on it or something as well back in the day. No doubt it's had a hard life but it's still kicking! Had Ewan drive us there, that was my first trip over.
Maybe, I got it from somewhere like Taranaki, can't recall exactly where now. Was in a sad state when I got it.. manage to get it back on the road. Still not flash haha but it's a hoot to drive as well
Took the Skyline around the block to make sure all still working as it should be, rides a bit nicer on the new tyres compared to the cracked other ones so that's cool. Also did an Instagram walk around as hadn't done that yet. Got several puzzled looks in my short around the block journey haha, people can't work out what it is. https://www.instagram.com/p/BAEEuXSGbEx/?taken-by=mlracing_alex When I parked it up to open the garage it was in the right spot.. Squad.. with myself? haha I had a really good time just driving it around the block, it's made me excited for this year! Also the new woodgrain Nardi is so much nicer to use, perfect for the car.- 54 replies
I had some tyres that needed to be removed from the car because they had cracks all through them, surprised they hadn't blown out! Luckily I had some already from other wheels. All different brands/models because I like to live dangerously. Also the sizes slightly different (two 175, two 185) so put the 185's on the rear, naturally. While I was under the car I had a look at the rust and repair places that will need to be fixed up. Some really awesome Japanese typical body panel repair jobs involving urethane, silicone, cardboard (or plastic) and metal tape. Just the usual. The good thing (but maybe expensive) is that inner/outer sills are available as well as a couple other common failure points as repair parts. Not genuine Nissan of course but a couple restore companies are reproducing them which is excellent. They were all like this, and also had cracking inside the tread too. New (old) tyres on.. I think there are some from China and some from Korea, quality. So much room for activities. Bit of a shitty look at the stainless exhaust. It's loud. Hmm those could be a problem. I had a feeling it was on cut springs after driving it. The rear actually is captive so that should be OK, but the front is no bueno, will look at upgrade options because the shocks look pretty average too. Looks like a bolt missing from there... and interesting exhaust hanger situation. Talk: //oldschool.co.nz/index.php?/topic/49704-mlracings-hakosuka/page-6#entry1631496 -
I reckon I'll just leave it as is until I eventually maybe get around to refurbing the whole grille area. Actually when I was showing someone the car earlier today it looks fine from about a foot away and chances of looking super close are slim.. there are much more important things to get onto first haha
Picked up this Nardi woodgrain wheel for a price I couldn't resist as was looking for something larger than the Momo that was on there in order to see the gauges properly (couldn't see water temp, somewhat important). With a bit of fettling it's on, and looks perfect. Feels really nice to hold, I've never had a woodgrain wheel before. Also took this opportunity to straighten the boss as the previous owner for whatever reason had the wheel on a slight angle which bugged me to no end. Now I need to get some repair parts for the centre console to get it back to it's former glory. When I took that photo from the driver's seat it reminded me of this one I took a little over 3 years ago at Rocky Auto: It was never a matter of IF I would own one.. but a matter of when! Discussion: //oldschool.co.nz/index.php?/topic/49704-mlracings-hakosuka/page-6#entry1627841 -
That's not a bad idea. Initially I was thinking of something like vasoline or similar then I got lazy/thought I was better than I actually turned out to be haha
Arts and crafts time again! Something that was bothering me for ages is the N emblem on the front was all faded out. Picked up some basic model/craft paint during the week and thought I'd have a poke about and get it looking nicer. Turns out it looked way nicer just with a bit of a clean with some solvent.. but still not vivid enough for me. It took me ages to work out how I was going to do it with masking off so I could minimise the paint on the chrome. Ended up making a hash of it anyway but this is the first lot I did, and that turned out all good. Then this is the second lot and I couldn't figure out how to mask the inner bits so just gave up and made a mess. Quite a bit of the paint seemed to bleed through that paint tape but I managed to clean up the majority of it afterwards with some ear bud things and solvent. Finished product.. it's not super sharp around the edges but stand a few feet away and she's magic. Just brings that bit of something to the front where it was all silver/black before. Next I have to figure out the best way to refurbish the 2000GT badge on the front.. or maybe just leave it off for a while because I realised painting is quite hard. Also the front lip bugs me. I'm pretty sure it's warped somehow but it is flat on the bottom so hard to tell. Oh well, problem for another day. Discuss: //oldschool.co.nz/index.php?/topic/49704-mlracings-hakosuka/page-6#entry1620756 -
You talking to me or other guy with choke issue? Pretty sure my choke is working ok
