mk4
New Members
About mk4
  • Birthday 04/11/1992
mk4's Achievements
Member
Member (2/5)
0
  1. any progress on this, it tickles my fancy!!. cheers
  2. bugga i was going to show up, but i had my birthday dinner and after that no one was at burgerfuel. should of got some pictures!!
  3. Thanks spencer. now to try and convince my buddy to let me buy the friken thing!
  4. cheers guys!. So will the altezza gear box from the 3s bolt strait up to the 3s from the celica? or do they have a different block like sr20s do? cheers!
  5. Cheers for that. ill have a look at the coil.
  6. gidday guys. I'm not to sure where to put this, feel free to move it to its appropriate form. I don't know much about the engine and cant find much about it over the internet, But my friend has a 3sgte celica sitting out the back of his house and he wants to get rid off it, the engine receives fuel and air. but there's no spark(engine does turn over). Any help on this would be gratly appreciated. Also are there any rwd gear boxes that bolt strait up? or do i have to get a custom bellhousing etc etc? Cheers
  7. hey fellas. Ive been looking around for a brake upgrade for the old mk4 cortina. id like to convert the rear to disk brakes,and 5 stud all round and maby bigger disks or calipers in the front?, but have not found any info what so ever.. so any info would be grate. Cheers jase
  8. mk4
    newby here
    Theres no oil in the radiator but it is using a little bit of oil... i just did a oil change on wednesday. but oil is fine? cheers
  9. mk4
    newby here
    thank you. ill have a look if they are all getting spark assoon as it stops raining:(
  10. mk4
    newby here
    cheers sholdowa. Where would i find the valve clearances? for this engine?. ive checked that vacuum line it seems to be fine?. cheers
  11. mk4
    newby here
    gidday. I thought i better introduce my self. Well i'm Jase i'm 16 and i'm based in rotorua north island, and have currently brought my self a 1979 mk4 cortina 2l. It has done 149.000 original ks. warrented and registerd. But now i have run into a few problems. The accelerator pump diaphram is leaking, so i have brought my self a gasket set, i am just waiting for it to arrive. also i think the valve guides and rings are about to give way as it blow's a big cloud of white smoke wen starting, and a little white smoke wen accelerating. It is also missing quite badly, I have not been able to find the problem of this, I have been told it could be a hole in the manifold or a vacume hoes or somthing like that, but i have checked and it's not one of them. i have changed spark plugs and leads and it is still missing. Any help on this would be grate. cheers jase.
