Lump
Posts posted by Lump
  1. fuel filters clogged? would explain while it will rev in neutral but not under load.
    the pump's in the boot there should be cheap filters upstream of the pump and the main filter downstream.
    - Also don't put a SBC in it (been there done that)
  2. On 5/17/2017 at 09:24, jesselc said:
    Anyone seen the beigey-yellow trump Ute in chch? Had to do a double take as I just drove past, no photos though looked sweet!
    That'd be Darryl from Economy Autos, or it might not be anymore I think someone mentioned he was closing down
  3. We had an Orange Holden One tonner ute on the farm called the 'Orange Roughy' when dad did the feeding out he'd put it in gear and us kids (I would have been around 5 years old) would sit in the cab and steer it around the paddock while he threw the feed out. Because their were three of us we had to take turns so we'd be sliding over the bench seat climbing out the open door and jumping back onto the tray to 'help'.
    When I was about 7 I thought it would be cool to do a MacGuyver roll while jumping out of the drivers seat and managed to run over my own ankle.
    • Like 4
  4. Like you I usually use the Kyteler/Hemi method which works 95% of the time - when something being a bit of a cunt (usually the jag where the rear pipes has lots of ups and down or if a systems been completely drained) and still has a small amount of air somewhere in the system bleed as per above and then go around each corner again this time get someone to pump the brake pedal a few times and then hold it down while you crack open your bleed nipple and then tighten it before they release then pedal you should only need to do this once or twice at each corner. This pressurizes  the brake fluid and makes the air into larger bubbles rather than lots of tiny ones which sometimes can't be seen you should get a few bubbles at the affected corners (no way of knowing which ones they are so do them all).
  5. Just now, Adoom said:
    I thought it might be, but it didn't seem to make any difference. I will try again when it is dark.
    Yeah I don't recall mine ever working either - might be able to clean out the rheostat to see if it helps.
    If its anything like the Jag it'll be pretty dim at full power anyhow
  6. I found a really good article about this years ago. Essentially the thinking went that any engine that had run on unleaded fuel the valve seats retained enough of the lead in them that they should outlast the vehicle.
    If you replaced your valve seat with the original spec ones (rather than hardened) and ran them on unleaded they'd be buggered quick.
    I think that's how it went - I'll see if I can find it
  7. Can anyone recommend someone to have a look at my bikes carbs (Honda GL400).
    It tends to be hard to start needing alot of choke then its stumble along on a low idle before suddenly increasing in revs. When warmed up with no choke it runs fine (although maybe a little thirsty). This isn't much of a problem in summer but its a pain in the arse in winter
    I've pulled the carbs to bit and cleaned the passages a few times to no avail - but the main jets are stuck fast and I can't get them out. Love to hear some suggestions on who could have a look at these and finally spend some cash on the poor old workhorse.
