Posts posted by OSM Garage
Havent done too much to the wagon. Was using it as my daily for a while whilst the Mirage was WOF-less. This car is no longer a suitable daily driver with the cams that are in it. Makes for horrid peak hour driving.
Added a boost gauge to the dash.
Was a bit surprised as I thought the wastegate had a 12psi spring. The gauge was bang on 10psi (probably +/- 2 psi accuracy)
Wanted to fit a boost gauge as I had a drag meet and wanted to raise the boost to around 14psi
Took the car to said drag meet.
Track was slippery. Didnt set any ET records but did finally crack the ton. 102 MPH with a crap time. If I had traction I may have got a PB. Oh well.
And I made the wagon unofficially official
It now has no WOF and the little shop I used to go to have got their act together. Which is good for me because it forces me to get this certified.
That is all
Clint, do you charge to inspect a certain part on a car before it goes thru the cert process? To see if all is ok or should be done another way?
Im unsure about the brake lines on my adjustable suspension
I agree with it being a "Dick move" but could it be a butt covering ploy over everything? Disabling the ability to modify the tune so if you were able to change the tune and get it horribly wrong to the point of destruction, you cant point the finger at the tuner?
I heard a while back that Tony Marsh would put a "warranty" on his engines that he built. If you touched anything on the motor the "warranty" is void.
I did donuts inside the oriental markets building in my r32 once
Seemed to be the thing to do.
We did donuts in a Lancer Evolution I. 5 deep. Thing was a weapon.
Whats the date on this one? Sounds like a good idea
Cheers
Thats a very tidy Super Estate. Theres a guy on Faceballs (hes on here too) that is selling a set of brand new roof racks that they fitted to these Sigmas back in the 80s. You at least have to get those.
RFB
Now to tidy it up and drive it over the summer
^ Well that never happened......
After the drag day I drove the car to work, which is roughly a 50km journey. 6km into that journey my clutch pedal went straight to the floor and never came back which meant I had to turn the car off when I came to a complete stop and start off in 1st gear and shift without a clutch. This was extremely difficult with the usual shit traffic.
Finally made it to work and put the car up on axle stands. Found the issue was a broken clutch cable mount.
It stayed in this state for 3 months.......
I decided to do something about it and get it running again. If you watch the video in my last post you can hear my gearbox protesting between gear changes. It was so hard to get into gear.
With this in mind I decided to replace the clutch setup. The clutch setup was the same equipment that was on the original SOHC 4G63 when I got the car.
Had the flywheel machined
New clutch kit
Whilst the gearbox was out I decided to wire brush and paint it. Cos you know, painting something you never see is a good idea.
I also put a new rear seal in the box as it leaked quite bad.
Slapped it all together and the clutch still wasnt the best. Wasnt till I compared clutch cables with a few I had and noticed that there was a rubber spacer/grommet that had perished causing the pedal to run out of adjustment. Replaced the grommet with a good one and shes a runner!
Out of hibernation
Theres still a few things to fix up. Tacho and check engine light dont work, no heater fan etc. Small stuff.
Will take it for a WOF and see if it passes with out a cert, but I think cert time is near.
- 5
Cant make this one. Have to be a parent apparently.
Kids.......Who'd have em
Purty
Is that a re-pro head from STA?
Gonna be there in my new Tidy immaculate mirage
Might have to check out this stoned immaculate mirage
Shit, my Lancer has been on hold for approx 7-8 years.
Just keep re-newing the exemption
RAR. Beaten
Sounds extremely heavy handed for a first offence.
He has been done for dangerous driving causing injury before apparently
Thanks Ranter! that's really good information was wandering about the starter/flywheel offset differences, How would I go about correcting this?
By using a RWD 6 bolt flywheel from any 4G6* powered RWD vehicle
Doesnt have giant sticker on the back anymore
Do they have to be original? (wheels, suspension etc)
If not id put forward my Mirage
Beverly Hills, that's where I want to be....
- 7
My dad has a Holden 202 in a RWD Sigma.
Its a dirt track car though
Depends what you like/want
Nice reliable cruiser - 4G63 DOHC N/A
Easy power - 4G63 DOHC Churbo
Unique factor - 4M40, 4G93 MIVEC, 6G72TTTTT etc
That handbrake adjustment
- 6
Auckland Monthly Meet - 18th May 2016 (This Wednesday!)
in Upper North Island Region
Thats my birthday. Does that mean burgs are free?
