Posts posted by sr1600
The collector in me is saying fd3s, the engineer is saying fc and hack it,because race car.......
Looked better Maroon..................................would rock any day ftw
simmons for lyfe
You are correct , these discs are pretty new as well.
They even appear to have handbrake cables........................................
Bugger , however your strut tube is slighty larger than mine from memory.
Why s15 Rears ?
How much are s15 rear brakes worth?
FOURRE up for sale
Wish I had the dollars to bring that back to life.....................
Negative offset
Not allowed any camber in nz that shit is dangerous
We used a Dimond tipped blade in a drop saw/skill saw when building towers out glass pultrusions.
And concrete drills as well for holes, you would only get about 2 holes out of a normal drill bit
I linish my tungstens to a point, they soon ball when your welding,
I find Most ali is clean enough to just weld without cleaning up, scotch brite is excellent to clean alloy
When you find settings that work, make a note of them, even better find someone with the same machine and pinch their settings
My tig is digital, fuck knows what each setting is, i just know what numbers should be in each box
Fancy putting up the numbers out of your old box machine? Or coming round mine for a few pointers?
Oooo could space the disk back as an alternative.
The 45 would possibly mean I couldn't get a bolt into the caliper.
Might keep Nissan. For laughs.
yeah have to chuck caliper bolts in first on mine to get them on.
RFB........................run f**kin bearings for life
Don't have that spacer in mine because I spaced between the brake disc and the hub to give me another 4-5mm clearance on the back of the wheels.
Running fully epic 45 degree spec........................should help keep the stones out......or not.
Can take the Nissan off , isn't any balance lines hiding inside like the mazda ones.
If you want try them upside down, don't have to take as much out of them.
Bleed nipples get cosy to the strut tho -
Just above the left headlight on radiator support..
Pretty cool that a basically paperish looking sticker has lastest 40 odd years.
NZ new paint options?
Haha - yeah probably but I really only need one set hanging on my wall.
You know where they are
Got 2 sets of rx2 hub caps , set of series 2 and a set of series 3....................Consider offers
Hamptons looks a lot like taupo in that shot...................
http://www.trademe.co.nz/motors/used-cars/mazda/auction-945576410.htm
"Just needs compliance"
Read the last question.......................
20g buy now??????????
RacKing up dem fines
#Rotalife
- 5
That mans got good taste in cars
Shouldn't have bought panasports, should've bought 24's.
haha
C8r's or g7's?
Been trying to win some 4 stud c8r's.....................................but to much dutch blood
//dont know they will fit over the brakes.
Be easy to change the oil under those ozzy spec cars.................................................If they are onto something I aint buying it
Rotary piner thread.
in General Car Chat
Old owner is trying to get these back, regrets selling his factory wheels
