Posts posted by sr1600
And the steering wheel is on the other side
1 hour ago, 13th said:
that's my dream right there
Very Nice car.....but not that nice.
Id think half that would be around the market price.
but I dont own one................... .......... ......... .. . . . ... yet
Bloody nice job
Did you end up pressure testing that tank for leaks? -
Anyone running a link rx ecu?
Wondering the difference between that and maybe the new Link Monsoon unit.
7 minutes ago, dabuzz said:
IMO - First gens are on the very cusp of attracting serious money soon - get them now
Agree'd - however to find one that hasn't been hacked up and smoothed up with bog is hard work
Few 808's coming up for sale at the moment...........................
Sitting with my 10-12k range on the hunt................seen a reasonable local one and "Boom" due wants 18k on hubbies rolling body half patched in primer.
Bugger me........there are complete cars going for that not much more, the world really has gone mad.
Then some sense 25k rolling body , lot of work done for the money
Reg on hold cert for 13b n/a
- recon s5 box
- recon big Ford diff
- new driveshaft
- s7 disc brakes
- 17" racing Hart wheels ($5000)
- nolathane right through
- custom rear leaf setup
- custom bilstein front coilovers
- fibreglass 12a front
- n.o.s front and rear bumpers
- n.o.s nosecone trim
- new chrome grill
- custom alloy light bezels
- new headlights and buckets
- full rewire front to rear
- all new lenses and reflectors
- all new rubbers
- all trim reconditioned
- all new glass all round
- autometer Rev and speedo
- 3 x 2" gauges
- full blaupunkt sound install with sub
- full white retrim interior
- chromed door hinges , strikers , bonnet hinges , stay, Catch , cowl, wipers etc
- chrome crossmember
- new chrome booster
- all new brake lines and handbrake Cables
- painted in ppg vibranceHeaps I would have missed. Everything either new, rebuilt or chromed. Undersides real tidy. 2 minor paint blemishes from sitting outside for 5 years.
It's done around 3000kms since being vinned and 300kms in the last few years . No one has really seen it around.
Needs a motor setup, fuel pump and exhaust then your away . Will fly through the next Wof with the right exhaust.
Done 13k in the work ute - new triton since getting it before christmas...............
If you want a ute for the purpose of lugging stuff around id go for last of the old shape hilux
Triton is alright and has dragged some stuff I didn't think it would , to be honest im impressed, however there is just those niggley things that annoy me already.
- - After driving around the hilux it seems laggy , boost dont really start to wind up till about 1800rpm , takes a while to get moving in the traffic and then wham-mo.
- - The Hi-beam switch is double click fucker instead of flick off.............
- - passengers seat belt always gets logged between the plastic and the seat..............then rattles
- - So much higher to lift things onto that the old hilux
- - Tray resonates alot more often , Hilux would only do it on gravel roads in the right conditions
- -Had it a month of so without the towbar and uphill in first gear felt like the uni's were out of whack , extra weight or time has sorted that.
- - bushes in the rear leaves are already making that annoying squeaky noise when you rock the truck.
Has more boogy than the hilux , but Id rather a hilux
Hill start assist makes you pretty lazy..........................
Depending on the width I'd be keen
41 minutes ago, Archetype said:
I may have asked already, but do we have a contact on Oldschool for new Mazda parts?
Ill Double that , need a set of 3mm carbons
55 minutes ago, rotor_dude said:
WANTED
rx8 4-port/6-port engine or parts - cheap
prefer auckland, or anywhere if you can pallet
Is a 4 port in Wellington on trademe atm.
Automatic ones don't have the hardened stat gears.......but they do have the counterweight for flywheel.
If anyone has a set of 6 port stat gears I'll swap ya
>aliexpress
Yes there is a number of ida throttle bodies including one rail of injectors for 300usd.......45mm to 50mm
Anyone use simple green in the dishwasher?
an old one of course
Rather buy two rx2's for the same price.
Are you buying them from pac performance?
Capellas are much cheaper
Hooks up alright, Did you run it on the lingslongs you normally rock?
13.7 @ 102mph
Fair honkin in a hilux.....
Was at taupo paintes for 18 months pulled it out and they went bankrupt , Sat in the shed for another year while the bank account recovered.
Now in whaakatane and has been there for 6 months.........................however painted the door jams, its getting there but basically 3.5 years to paint it.
Thinking I might buy something else now ( it might never get finished)
Because of the ploom.........
5 valves per cylinder = more leaks
What are yoy doing here, You should be bidding on 490kw xr6t on trademe.....
Rotary piner thread.
in General Car Chat
Leave the factory weight flywheel and will still drive exactly the same. We compensate for rotating mass by increasing the idle...............
Pumps aren't really expensive like they used to be , aftermarket replacement would be advised.
Injectors - I think you swap the primary injectors out with some secondary ones (or some larger ones with the secondary ones in the primary place) then you only need two off
