AndyGal
Posts posted by AndyGal
All he has to do is bleed clutch and borrow my ecu and he can drive this.
Looking good man You'll be stoked. I think you should sand the wheels to dull them a bit, they look too shiney and scream look at me i'm brand new and fake.
Put a standard airbox back on untill you get flat slide carbs. Thats what kgs will say lol
He can finally lean back on his sissy bar now those gay low bars are gone mahahaha
Rob at a nats! lol
And finally for tonight this is the latest project.
A tru test styled mini bike with a Kirby lawn mower engine. Goes pretty good once it gets up to idle which is about 30ks.Top speed about 50ks. Direct drive and nice and dangerous. Got some sweet plans to restore it for the smash palace motorcycle show. Watch this space.
I got this suzuki a50 from an old boy and now it runs Dunedins streets piloted by Zeabadiah.
The only bike I don't have a photo of is a standard Honda Cb50 I bought not running and put a new piston in then sold on.
Another push bike I currently own is this old beast, approximately 100 years old, with a sweet major taylor stem, back pedal brake, 28 inch wheels and a circumcising old brooks saddle. I got the frame and stem from Valiant, wheels from Chumley. Shes goes good!
It runs mustache bars and used bandages for grips.
It seized on my a few months ago because I changed the front end and throttle and didn't hook up the oil pump up around the right way.
I have converted the front end to an Rd50 telescopic front end. Handling is much firmer around corners now with no slop in the front suspension.
I cut the front springs to lower it a bit more and changed the front end from disk back to my drum front. With the big caliper and monster brake reservoir sitting on my small bars it looked no good.
I got an old push bike headlight and fitted my LED conversion into it.
We also decided to make a new chamber to go with the now 1.5mm oversize piston. (54cc's now mother fuckers)
Bubblejews worded out the dimensions, I drew them out on sheet metal and rolled and tacked the cones together. Surfab welded it up nicely and shes a screamer now.
Oh I also got rid of the hard tail a year or so ago and are using modern scooter front shocks with cut springs and cut down bump stops.
Did a dyno run for a laugh too.
Back to my OG scoot, Bubblejews turned my slap on expansion chamber into something that actually worked and made a big difference.
Also around this time the piston got broken by mistake when the engine was apart, so I got a new over sized piston and ring, and Cheerio's lathed 1mm off my bore to up the compression.
e
After that I just rode the shit out of it for a couple of years until the latest round of mods. We have ridden to the west coast, done a 350km round trip with 70ks of gravel etc. Shes mostly been very reliable. I must have clocked up a few thousand ks by now.
Had a go at building a slam bike too.
Started with this.
And made it into this. Went on a few tweed rides etc with it good pedal scraping times. -
Theres a few photos of my yamaha v50 in the QCR thread but I though I would add a bit more detail here.
This is what is was like when I picked it up for $100 from a guy named Jesus.
A week of so later it looked like this.
With the help of Chris, Brendon, Luke and Lewis
Chopped bars,
chopped seat,
bobbed,
hard tail,
painted wheels and engine,
new exhaust,
new front tyre.- 1
Bubblegoose cam over for another session tonight. Slowly getting a bit more done.
Front drip rails have been welded on.
Bits around the boot tidied up
And around the left tail light.
I have started sanding it down and have filed out 6 of the door hinge holes to get the gaps better.
Also have got my reset leaves back and its sitting at a better height. Need to sort out a panhard rod next. Should be quite low once the windows, petrol tank, spare wheel, and 5 people are in it!
Sorry about the shocking old cell phone photos but we can take some nice ones when its back together.
- 8
Window bars to de lengthen it mexicant.
Looking forward to seeing it at bike night with half an exhaust
Aaron's DB Teg of Bleh
in Other Projects
keep doing it I say, until they crush your car
