HighLUX
Area Reps
Posts posted by HighLUX
  1. Discussion thread
    //oldschool.co.nz/index.php?/topic/28143-os-triumphs-ute-of-grandad-greatness/?p=717190
    Just picked this up today and drove it home from Auckland
    New Zealand new 1986 Sr5 Extra Cab, im only the 3rd owner and it was originally from the south island.
    Its mint, no rust and still has original manual and sales info
    Powered by a 3y with 186000kms on it, runs like a dream(was expecting it to be a gutless piece)
    Plans are roll it as a daily and start saving for a 1kz-te or a 1kd-ftv to drop in it.
    Was thinking of converting it to EFI until that happens, anyone got a a 3y injection setup lying round?
  2. Anybody got any knowhow with these engines? Mate has a P10 primera with one of these engines, its a single point injection setup, never seen one before and thought it was carby till I took the air filter off.
    It was working fine until a few days ago, then the injector stopped spraying fuel, its getting fuel though (didnt have a multimeter on me so couldnt check if the injector was getting a pulse)
  3. So went from looking like this
    to this
    Good to have it fixed as I can wind the adjustables back down now
    Have had a electric thermometer probe mounted in the intake for the last couple off days to see what the intake temps are like.
    Theres little room for the intake and pod filter under the seat so it sits behind the radiator.
    Intake temps range from 28degrees up to 52 degrees :shock:
    Temps that high cant be good for performance or fuel economy so Im after ideas for a decent cold air intake.
    Was thinking of throwing one of these ricey filters in there with some ducting rigged up to the factory cold air intake that runs from the bumper up the passengers chassis rail to where the 2C-T airbox used to be.
    Found these shiny brake discs that will be a straight fit on so will look at getting some when I have the coin
    http://www.dcperformance.co.uk/cheap/343915/toyota/nitrac-drilled-and-grooved-front-brake-discs/nbd275d.html
  4. Will look into all of this, finding a manual 1kz bellhousing could be hard and expensive. There are engines sold on trademe with auto bellhousings, could one these be of any use?
  5. Has anybody done this or have an idea on how to do it?
    Reason I ask is that pretty much all 1kz engines have an auto or 4wd box behind them so no factory 2wd gearboxes that I know of
    W55 with an adapter? Do they share a common bellhousing pattern with another toyota engine?
  6. Can I interest you in a 3SGTE with ecu, loom, afm, alt etc?
    Also, how wide is the F series estima diff?
    I want a disked one. Would it handle 200kw?
    Gen 2 3sgte? What ya wanting 4 it?
    Unsure how wide the estima diff is, havnt got round to doing a measure yet will let you know though
