I've only used my reverse twice in the past year. Once to check it worked before going for a WoF, and again during the WoF.
With a track-only B.E.C. you simply do not need a reverse, and with most weekend and occasional use on the road it's not needed either. A little forward planning on where you are going, where you are parking, and the occasional "Fred Flintstone method" backing out of a parking space at Hell's Pizza, it is no problem. The VERY sensitive clutch and lack of ground clearance are a much bigger headache than reverse.
If you were genuinely going to use a B.E.C. as a daily driver then that might be different but this is NZ, buy a cheap runabout as a daily.
And thank you to Bullitt for posting up a pic of my car. Saves all the hassle.
