Posts posted by brocky41
Just fixed up the thread a little bit - hope to have a few more updates soon.
WOW i havnt updated this in a long time since FEB 2009 whooppps - will have to catch the thread up when i can but anyway.....
Well i got a few things done today and one was slotting the FJ20et in the space where the CA18 was.
Stocked it actualy fits in the hole as they just dont in a 1200.
Looks to clear all the major stuff although its sitting on the crosmember so will need some scolloping (mmmm scollops)
Clears up some much needed room in the shed now too lol - ive been going through all my stuff and there is lots to get rid of - parts for cars i dont even own now lol.
//oldschool.co.nz/index.php?/topic/24645-brocky41s-1978-datsun-120y-aka-tufdat/?hl=tufdat
POST UPDATE FROM NZDATSUN 25 APRIL 2012
Well after a mammoth weekend on the Y, i think shes ready for the Southern Cruise
Started on Thursday night prepping the new gearbox with the Genuine seals and Gasket from Scott @ Cockram Nissan. Got all that sorted then realised the Clutch was gone. Took all the parts off including the flywheel in the hope someone could do something on a Friday for me
Rang Tony @ Clutch Systems in town said to send it round and he would sort it. I sent it on a one hour courier from work and no shit, within 2 hours Tony rang and said it was all done - Flywheel grind aswell. Went in at lunch time and he had a standard type plate, usually for a diesel engine and a Heavy Duty pressure plate with release bearing already pressed onto the carrier ready to go.
What a GC, he didnt charge me for the Flywheel grind or the pressing of the release bearing either - highly recommend them for your clutch stuff, Tony really knows his stuff.
Was super stoked so got the clutch fork etc back into the box on Friday night and also took the front struts out.
Saturday arvo - had to re lower the engine down by unbolting the crossmember to get the box to go back in and to reach the bolts - bolted the flywheel and clutch in with the help of john and his torque wrench - had the box up on jack under the car - getting dark by now - couldnt get the dam thing to line up to get in the hole, it was jamming on the splines.
Little did i know, thrashing around with the box that the jack had slipped out from under it and when i went to take a rest the box slipped out out and landed on me - the little out piece in about the middle of the box got me square in the chest. I was already out of energy in the arms (not that super fit aye) and i couldn't move it of me. Luckily when i yelled out John and Lisa came running out (so did Millie the cat) and i crawled out from under it.
Not the nicest of feelings getting crushed - wont be doing that in a hurry as its still pretty sore.
John and I trucked on and had the bottom pieces removed from the new front shocks (forgot Brendan had the originals machined to suit as they have a stupid spacer on the bottom and you cant screw them into the strut tube. And also got the new wheel bearings fitted to the new discs (1 piece hub and rotor)
So that was the end of Saturday - but i still had alot to get done.
Sunday - up bright and early, all be it very sore - i got the front shocks fitted to the struts with the new discs and pads. When fitting back to car realized i had had the struts round the wrong way this whole time - and a quick Google search revealed the calipers go on the back of the disc not the front (thanks R31 House). Swapped all that shizz round got it all bolted in. New rear shocks bolted up aswell (thanks John -SKDMRX- for modding those too, what a GC).
Time to have another go at the Gearbox - using different point with the jack it went up at the correct angle and 'bobs your uncle' straight in.
Got everything else like the cross-members and drive-shaft back in - remade the manifold flange gasket (third time lucky i hope)
Went to bleed the clutch up and the dam thing wouldnt (i know your frustration datochriswagon, and after alot of cursing and a thrown hammer at a rusty 260c guard it finally started to bleed up and then proceeded to self bleed the rest of its travel : - finally fired her up at about 5pm.
Took for a test drive -
Gearbox quiet - tick
No Exhaust leaks - tick
Brakes bedded in and all ok - tick
Suspension tight (stiff as in the back now) - tick
Hooray, finally got it all sorted - there's a few other things to do when i get back from the Southern Cruise like the diff and drive shaft joint but ran out of time to get it done.
Hopefully everything holds together on the cruise - i don't want to do another gearbox for a while - definitely widening the tunnel as much as pos on the 1200 to make removal etc easy.
The left over boxes - have been collecting this over the last year.
Did the wheel alignment tonight - just needs a clean (got a few cobwebs to blow out literally).
John and i have had a clean up in the shed too
POST FROM NZDATSUN 04 September 2011
So the Y spat the dummy at the supermarket - died just going into a park - had to get towed by "Broke" home with the 620 using a small tie down which snapped once (terribly embarrassing in traffic)
Blew a 2nd VL commy (2nd hand) fuel pump so had to fit up the surge tank iv had for ages.
Got a new External Pump and Lift pump from work - all Airtek items - The Vl one is the one listed for Vectras and some Alfa's too.
Decided to filter the fuel from the tank, then into the lift pump, up to fill the Surge tank. I have then mounted a Subaru filter (that i had the bracket for of the WRX STI i wrecked out) to filter the fuel from the surge before the External pump. This will hopefully help keep the pumps in good shape for alot longer. (still running a filter before the engine so TRIPLE FILTERS - what does it mean!!)
Wired it all up and took it for a strop - has never run better.
And also both pumps are very quiet - normally the lift/facet pumps are noisy but these are not - cant here running when car is idling even without back seat.
heres the pics
POST FROM NZDATSUN FEB 04 2011
Havent updated for a while - got a few pics
after another failed WOF (man this thing just dont go straight through) ive got some work to do.
Rust (again) small patch inner rear sill and firewall (again) should be easy fix this time
Indicator light covered by Tacho - (wiring RH light to LH switch so dont have to move Tacho
Drag link
Ball Joints
Exhaust - Wof man said its only just over what it came out factory with a in his eye - 1x resonator will fix.
Tyres - Got 35,000-40,000 kms out of the AD07 Yokos - Now have 195/50r15 Bridgestone RE11's (thanks Chris) - time for EXTREME GRIP.
Drag link out
Bottom arms and ball joints off - will give everthing a new lick of paint before going back in.
All the new bits ive been collecting -
Ball Joints - wide option - which this al :thumbsup: ready had.
Inner tie rods - may as well do these as the outers were replaced not that long ago
Drag Link - rebuilt by HBI in Sockburn - 3 day turnaround - and they are tapped.
Front springs are getting another coil off to stop the shock being on max extended length all time - will slightly lower the front to :thumbsup: and have got new bearings to use in the tophats as the old ones were poked and missing balls etc.
Am also putting in strut cusions or "bumpstops" as is recomended factory for R31 shocks and will help keep the dirt etc out (they come with rubber cover) and extend shock life.
POST FROM NZDATSUN 25 JULY 2010 - UPDATE
We went for a drive out over the port hills yesterday and got a few pics
These ones are my Fav
Ky is correct - sedan and hardtop (pillerless) have a different rake therefore different screen. Pretty sure the hardtop coupe will be the same but those are even rarer.
Is is custom autoglass in Auckland can't remember exactly
C230 and c231 are very hard to find - I had a gold one and the guy that brought off me had a screen lined up at Smith and Smith but turns out it was for a C31
Â
Â
Turns out I do have another one coming - although I want to keep it complete and hopefully put back on the road.
Â
Is yours the same shape - just with round headlights instead of square??
Â
If so ring Franz also ...
So the WOF ran out and i smashed a rear taillight so yet again time to get some work done on this thing.
Its so cheap to run - but with high kms it works out about the same as a petrol, cos i have to keep replacing stuff but hey its rare and it gets a few looks lol
so out with the old
Uploaded with ImageShack.us
and have brought some new (over the last 2 months)...
Lower Control Arms (with ball joints)- actually loose in the mount they were so worn - should have been picked up at last warrant naughty VINZ
Outer Tie Rod Ends ($5+each at appco)
Castor rod bushes - these were so haddit the rod had worn right through the steel sleeve
Sway bar mount bushes
Swaybar Link Rod bushes and washers
Driveshaft Centre Bearing
Just got to wait on the new Rotors and pads aswell as Front Wheel Bearings.
Ive so far done one tie rod end and bolted up the new Arms - Just got the new ball joint splitter today as the fork was hopeless.
I also parted out a Hatch wagon - that was originally L20et but had had a diesel in it. Scored all the interior which is the red seat you can see in the first pic
There are 2 of those Honda Accords in CHCH - both from the same era - I personally got to sit in one (yay) of them (Crompton/Thompson car) no wonder they were hitting each other all the time, You sit so dam low all i could see was the wipers at the bottom of the screen not even the start of the bonnet.
Â
Also, if you didnt know already, all the panels are factory steel - that was regulation - by christ they are heavy. You see the crew flinging the bonnet or boot up on tv like its a fibre glass one but without the gas struts on them make it hard work lol.
POST FROM NZDATSUN - 22nd JUNE 2010
Well as you guys probably all know this thing blew a water line (heater) on the back of the engine after two weeks of being here.
just thought id update you a bit.
Engine and box are out - thought it would be a good time to hit the leaking sump, front and rear main seals and to change all the water hoses etc so i don't run into the same problem. Also the box was on the way out so throwing the spare in which is hopefully better. Also replacing exhaust gaskets as they let go on the big trip down too. :baseballbat: :baseballbat:
Dan also came round and rid the engine of all "not necessary" water hoses, pipes and vacuum lines. :thumbsup: :thumbsup:
Front struts have been out, again, and I've spruced them up with a lick of paint etc. :thumbsup:
Also decided to fix the rust in the firewall which came about due to the "panelshop" replacing the rust with "liquid steel" instead of REAL steel. And filling up the holes in the floor from cutting the gearstick hole to big.
Man that's sweet the gold on mustard looks awesome - well done
Great work - love that you went with that colour - looks amaz balls
Hes swapped the rotor part out for a 4 cly engine to go on the L20B. That was also a L20E one, Def go electronic ignition - the idle and general running of my l26 is loads better than the old one with point iginition
PM a guy called BROKE on the datsun forums, I gave him my old 280zx electronic dizzy. -
Ive got a 3 speed column shift gearbox with everything shifter wise to sell if someone wants it - no pedal etc coz doing manuals floorshift on my 330
Love the Porsche esk rear wing
Due to me wanting to start moving ahead in life and not being stuck in the same position for another 10 years this is now up on trade me.
A little gutted but hey i might buy another one one day in the future - parts are still readily available ex australia so would not be a hard project in the right hands - there is alot of rust but easy rust if you know what i mean.
Heres the Tard Me listing - ive given her a bath aswell.
http://www.trademe.co.nz/Browse/Listing.aspx?id=586609882&ed=true
By brocky41 at 2012-08-24
Had made a start on the rust - those ramps make things pretty easy.
Well is looks like it last had some work (if you can call it that) in 2003 - due to the Christchurch Press 2003 jammed in the front of the sill :o
It also had some funky bondo plastic sellys no more nails shiz in there - typical of a home job aye ;)
Well its gotta be done so will start grinding her back along the sill and see what else is there
Been a while Soooooo......
We sold this one a couple of months back due to the rust etc - it went to auckland to a car dealer for restoration :thumbsup:
Meanwhile i brought this 230 sedan which initially was going to go back on the road but decided better to save a few other 230's around (parts gone to Ivans (RBLOVER) blue sedan and to Snoozins red sedan so far. It wasnt rust but was missing heaps and was fully seam welded - like fully - not stitch, fully welded and wasnt welded great so was never going back on the road, had had a fire inside when he was welding the floor and burnt out all the interior.
Illl be using the rebuilt front xmember and front arm assemblies aswell as a couple of doors bonnet and guards etc for the 240 wags
Came with great bumpers and surrounds for the front too.
Also brought these sweet rims - 16x7 3 piece welded - but may be able to flip them - already got tyres on in 205/55r16 - they are a jap brand will put up details soon
Also still got the dash and a few other bits left over from the derby car from 2009 - heres some pics for the guys that havent seen it
Will be working ont eh 240c wagon once i get the y up and running again
Discussion - posting.php?mode=post&f=18
Millie Loves it too
Pics that i took just before i sold it - it went to auckland - i had just started to find more and more that needed doing......
i was reading the trailer registration fact sheet the other day, and while they say that there is no minimum height for a trailer, if its below 100 mm then it needs cert apparently
Seeing a trailer with a cert plate would be LOL as.
Id be checking the Roleston Scrap / Wreckers yard for these as they get alot from around here - may still be stuff left unsquashed
DEF do the the rocker cover gaskets etc first - i used to work for BNT and sold these daily to peaople like KK . even using sealant on the old ones does not work - buy new (about $20-$30 per side or you can get a set with both sides from memry and save a bit - ripco etc should have them too and it should fix it- good luck
Removing a glued in windscreen
in Tech Talk
the last 260c screen I took out just used a heat gun to heat up the sealant - its not as good as the new screen sealants are and just hold a small amount of pressure against it - feet etc like you would when removing a rubbered one.
only took me and another person about 15 minutes to remove both screens
