cletus
Moderators
Posts posted by cletus
  1. Clint, re: bucket seats, I haven't got the rails and don't plan on havin the car road legal but if do I one day, is it ok to weld weld steel pipe/bar/WHY to the car and bolt seats direct to this so they have no movement?
    Car is a sedan and will likely be caged but not certain yet.
    if its for motorsport use then that will be ok
    there is stuff in the hobby car manual describing how to do exactly this
  2. im not a towing expert, but have towed a few bigger cars on an unbraked trailer, and id be very wary about going any distance or on open roads like that...... tow car is commodore wagon, so its not little, but with an HQ ute on the trailer it was a bit of an effort to pull it up
    as mentioned above, if you are going to build one, may as well make it big enough to tow anything you are likely to......which may mean dual axle and brakes
    heres some nerdy info as well
    http://www.nzta.govt.nz/resources/glove ... ml#howmuch
  3. I think those gps speedos are a good idea.
    a speedo can be one of the hardest things to sort out with some conversions. have had a few blokes with latemodel gearboxes with only an electric output in old cars with cable driven speedos that have spent $1k to get it working accurately- needs a box that converts elec input into spinning the cable at the right speed
    even getting a cable operated speedo calibrated properly can be pricey
    for those using an electronic speedo, jaycar sells a DIY kit that allows you to calibrate your own speedo. I used one of these in my last project, adapted a nissan electric drive onto a340 toyota box
  4. Cheers-Its getting more fun to drive as I get used to the handling and usual 'old car quirks'.
    I have priced up some carpet today. About $260inc will cover the cost of 1.8 x 1.8m red automotive carpet and getting them to bind the floor mats after I have cut it all to shape. That includes them putting a heel mat in place too. Does that seem OK ? I have never priced up carpet. I think the carpet was 120 alone plus gst.
    id do that. ive just fitted an autodec carpet in my heap. it doesnt fit the floor very well around the tunnel- the tunnel is big up by the firewall and small near the seat. im no expert auto upholsterer but i cant see how it would ever fit nicely as its only got a couple of stitched cuts in it to get it to match the floor shape- it really needs a cut and stitch right up the middle to tighten it up at the small part of the tunnel. also it doesnt fit very well around the rear of the back footwells
    the guy at autodec was good to deal with, ill give him that
  5. Imo grafting another front clip on of the same model would come under 'repair'.
    yes if that was the case you would be correct
    what seedy is talking about is chopping the front off an old beam axled drum braked leaf sprung truck and fitting the front clip off a camaro or hq or something ifs/disc brake/way more slam/much nicer to drive
  6. repair cert only covers repairs, ie accident repairs, back to original spec.
    any welding when its to do with a modification, is covered by a low volume cert.
    repair certs can be a pain in the ass specially when the cars been painted. had a look at an hq ute a while back, had nice paint...... had to be stripped back to bare metal for repair cert because it had repairs in the sills, then paneled and painted again. that would rip my undies
  7. yes can be certed- as long as its done properly. as andy said in your other thread there are a lot of scary built things in the states. if you want a nice job id look at doing it yourself, as redoing a previously fucked one is harder than doing it from scratch. or at least making 100% sure its a good one from millions of pics or someone looking at it over there
    what year f100 you lookin at?
  8. Quick question about additional welding to a car body. Restoring mk1 escort at the moment, and to be fair the factory welds are pretty shite. Any reason why i'd be pulled up come WOF time if i've added spot welds here and there to panels to give them more strength? Likewise I see gusset panels available for the car, anything preventing me from adding some DIY ones or is this a no no? Some areas just don't seem all that strong so it would be handy to be able to just add in small sections as I progress. Purely for examples sake: Example Car isn't going to be doing anything than normal driving, so may not be required, but more so asking out of interest if I come across a section I want to strengthen.
    Yay and nah on that sort of thing? Cheers
    strengthening like that would technically require a cert, as it is a modification to the structure
    adding some spot welds- youd probably get away with that if it all looked factory
  9. Dear Clint
    Just went through check point, the guys from land transport checked it out, all good bar one issue that he spotted.
    He measured the height of suspension from the center of the wheel to the top of the guard,
    I read the Average car height is 300mm. Mine Reads 570mm and 540mm, which is way out! says my car has like a 3inch lift kit in it. Was there a different way of measuring back in the day? ( cert plate is old) He said i wouldn't get a WOF with that mistake (BS anyway as i do)
    So my options are just leave it and risk coming across an unreasonable cop
    or pay $400 for a new plate? Or is there another option, what do you think
    Thanks
    Horse
    as far as i know its always been measured the same way. ie hub to guard
    email this bloke, hes very helpful justin@lvvta.org.nz take a photo of the plate, i doubt it ever would have been that height as you say. it may have been printed incorrectly and never picked up. explain your situation and he will be able to help you out. worth a try before getting it re certed
  10. Dear Clint,
    Whats the deal with welding for cert?
    Who has to weld what?
    What has to be welded in MIG, TIG ??
    As a Full time welder in paid employment can i do everything myself?
    Regards,
    Chris
    theres only a few things that need to be TIG welded and crack tested, parts considered "critical function components" ie brake caliper brackets, front suspension arms etc
    chassis/engine mounts/body etc can all be mig welded. you dont have to be a ticketed welder, if you can weld properly youll be fine. the rule book says welds must be done by a ticketed welder OR someone who has demonstrated to the certifier they can weld. i have seen a few ticketed welders do shocking birdpoo welds on cars because they are used to glueing 6mm plate together all day and are quite good at blowing holes in 1mm sheetmetal
  11. Hey Clint/ others I've got a question for you.
    ok so here goes.
    I just bought a 88 turbo cefiro. I took it for a wof today and the guys wrote this.
    "Supply LVV cert for: Driveshaft hanger bearing, All Intake mods Inc Structure"
    It has a cut 'n' shut front facing plenum, and a front mount intercooler. The cooler piping does go through the inner guard under the battery and the same on the other side. 75mm ish diameter hole.
    I also had to cut out some of the bumper iron in the middle for the kit/ cooler.
    The hanger bearing is completely factory
    What I want to know is weather hes right in failing me on this and how I can sort it.
    Can supply pics of setup if you want...
    Thanks, Adam
    has it got a cert already?
    would need one for holes in inner guards.
