cletus
Moderators
Posts posted by cletus
  1. Bike it complete. However due to lack of clutch the technique is to start it, dump the back wheel on the ground and take off.
    This technique so far has only resulted in the bike stalling or flying out from under me in a rather humorous fashion.
    Need a clutch.
    this didnt have a clutch, rev it up and nudge it off a kickstand. might need more power though
    GUu9P3CKSMI
  2. yes thats correct- half a degree more than factory range of adjustment
    Does that mean adjustable camber tops won't be certifiable if they can be adjusted outside the 1/2 degree allowable? (me thinks yes not certifiable)
    i doubt that would happen. it would be unreasonable, a factory suspension adjuster could be adjusted outside of oe specs.
  3. its been in the pipeline for a while
    bought about mostly by drifters skidding off the road and killing themselves
    and also hellaflushfitmentpokestance form>function
    youd be surprised how many cars get knocked back for tyres rubbing, and the owners idea for a fix is just get some camber arms so they can wind a heap of camber in, or preload the springs or put the shocks adjustment on way hard so it doesnt have any travel.
  4. if you change the steering at all, you will need a 1D category certifier, you could try Mark Stokes (i work for him) Neil Fraser, or Lance Walsh.
    I dont know about other certifiers but we do a preliminary inspection for under construction vehicles with major mods, we charge a part fee which comes out of the total cert cost. ie if its a $600 cert we might charge 200 the first time and 400 to finish it off
    the reason for that is some people will get us out a couple of times and then use someone else to finish it and we end up out of pocket
    cert cost varies a bit depending on the level of mods, i start at about 440 incl gst for trade customers
  5. such an awesome weekend
    highlights for me include, but not limited to;
    -velodrome racing is much faster/dangerous than i thought it would be, special mention to uterus on the trutesticle
    -meeting more gc`s from the south island, good effort from those chaps
    -lee's corona conversions on any drink
    -getting 15 people into brockolees corolla
    -poker run antics, found more pretzel stuck in wiper blade today
    -car not breaking or using so much gas
    was sweet!
  6. the only BC stuff that cant be certed at the moment is the ones that have a casting welded to the strut tube, this is not just BC but any brand that is made that way. the only applications that i have seen where this is an issue, is ae85/86 front struts where the strut tube is welded to the spindle, and late model honda struts where the cast steering arm is welded to the strut.
    otherwise there is no problem with them, BC are a very good quality brand from my experience
  7. yes bolt on adaptors can be certed.
    going from 5 to 4 studs will probably be an issue, the rule book doesnt specifically say you cant do it. however there is a rule where if you fit a heavier engine into a car you should upgrade studs to the same as the donor vehicle.
    before you buy them i would suggest going on lvvta.org.nz, there is a q+a section there, the guys that run it are the technical advisors at lvvta. i would think that going from 5 to 4 studs for cosmetic reasons would be not allowed
    What sort of car is it and what mods have you done?
  8. it sounds knocky all thru that road test video. but the most noticeable times that you can hear are when it is at higher rpm than idle, but low load, ie a throttle blip or when you are going round an intersection. if you listen at these parts, you can hear it clearly.
    1.44- 2.02
    2.17-2.20
    3.03- end
