Posts posted by cletus
The steel wheels on it are very heavy.
When it did its quickest time it had some very light cragar super tricks on the front. They were popular in the 70s but the internet reckons there's not many around these days because they were prone to failure. I bought them ages ago from a guy who took them off his car because they made creaking noises when doing tight turns, they were very cheap.
They weigh as much as a bag of chips and are a bit sketchy, also the tyres were right on the limit speed rating and load rating wise. Plus I had to run a 5mm spacer which I did not like. I only did 2x passes with them on and didn't like it
So I've had my eye out for a second set of wheels suitable for drag racing
Being an impressionable teenager in the 90s who read street machine magazine a lot I've always wanted a set of weld draglites.
They don't come up often second hand, I found a set a while ago but they were not wide enough. You can still buy them new but they are pricey
Picked these up today, 15x5 and 15x8. Tried them on then got the tyres off, they are very fucked.
They need a polish but should tidy up well
Anybody know a good polishing place in south auckland?
- 21
Yep. You would likely need to add something back in to make it strong enough/roughly the same strength as it was. Wouldn't need anything complicated
3 hours ago, SiRge said:
Anyone gone through design approval process with lvvta/TAC? Ol' m8 Julian thinks my cars too modded and wants to put me up against the design approval, but aside from lvvta website not sending the CCM, the Internet seems pretty quiet on it.
It's not particularly difficult
It is intended to be used by people modifying cars, to help them with their projects.
there is a range of people with different abilities sending applications through and they all get looked at, they are not viewed as wasting anyone's time. Some are hundreds of pages long with cad drawings and FEA paperwork, and some are literally hand sketched drawings. Photos are very helpful in an application
You will probably struggle to find someone to teach you how to do your particular project as it's quite different , so there isn't going to be anyone with a recipie for exactly what needs doing. Certifiers can guide you along the way but, time is money, if the certifier is willing to help design the car/mods you're wanting to do, it gets expensive quickly
Time is the biggest factor when getting people to help you. It's not uncommon for me to spend 2-3 hours a day on the phone, talking to people about their projects, emailing , looking at parts etc etc. This ends up eating into the time I have to do work I can actually charge out- there has to be a balance and this is why it can be hard to find people who can help you
lvvta.org.nz you can download a design approval application from there
There are also infosheets on design approval
https://lvvta.org.nz/documents/infosheets/LVVTA_Info_11-2012_LVVTA_Approval_Application_Guide.pdf
- 6
Not required
Will need mud flaps though
2 hours ago, Adoom said:
Do I recall something about proximity of things like fuel line, battery cable and brake line to the propshaft when routing under the car?
Or does it not matter where I run them as long as it's secure, not going to hit the ground and can't touch things that move or spin?Yes.
Fuel and brake lines.
I usually recommend running them away from the driveshaft where possible, as a rear loop on a solid axle car is (a) hard (b) looks stupid (c) not particularly effective
Not quite as bad on something with IRS
22 hours ago, kp60nick said:
Question regarding plating chassis rails for welded in tube crossmembers. I made a cardboard template of what I wanted the plate to look like but once I made it and bent in 90⁰ it lost length and no longer spans the whole height of the rail. Is this a problem should I remake plate? Picture for better explanation.
Probably fine, by the time there's a weld there it will be pretty much at the bottom
What's a good running K24 worth? I had a look on trademe but there's none on there at the moment
I'll likely have access to one soon, and it's in a handy take home package
I remember reading about them as a kid and being "whoa" at 2l turbo 4wd in a hatch
Never had much to do with them apart from fixing one for a tight arse car dealer customer we had, it was a fill in job for when work was slow so it ended up taking 4 or 5 months , it broke a ring land so the car dealer supplied 1x second hand piston. Did it with the engine in place, getting the head/intake manifold off counts as one of the worst jobs I ever did
Also due to the fact it took so long just doing bits here and there, when I started it I'd forgotten I'd removed the oil filter. It was on the hoist, fired up, pissed oil everywhere, I reached in the window to turn the key off but it had a turbo timer down by the console so I had to do a panic dive in the window to turn it off, the boss thought that was quite funny seeing me with my legs sticking out the window
- 5
- 5
i cant see a problem with that if its all factory parts, and the work is done well, welding is good, sealed and painted etc
Does it need the clutch on the s/c? Looks like minusing that would give you a bit more real estate?
As far as I'm aware, it can be applied to all vehicles, whether 14+ years or not
Can still do holes in single skin panels, that's fine.
Lvvta have recently said that you can make a new front beam , but it requires finite element analysis, and approval from lvvta, to prove it is exactly the same strength as original
I have not heard of anyone doing that yet though as it's obviously not easy or cheap
Cert= can't cut that bumper beam unfortunately
Nope. Which is kind of weird as you can't read speedo at night without a light
Has to have high beam light and something to tell you the indicators are on, that's it
the best barry bullshit yarn i ever got was from someone that claimed their 186 powered land rover was capable of dropping it into 3rd gear on the motorway and spinning the tyres and beating xxx type of cars at the lights etc etc
- 5
On 27/02/2024 at 21:04, Raizer said:
Code: 259506484231715084
expires on March 29, 2024
chur, saved me $25
Yessss!
I look forward to progress on this one!
Would it be worthwhile swapping mechanicals into a normal spec one?
there is some stuff in the suspension chapter of the CCM but its quite specific for mounting lower coilover mounts
it doesnt really cater for what you are doing exactly
If it's all standard steering, and just roll center spacers, bump steer check is not required
For Questions Regarding WOFs/CERTs/NUMBER PLATEs
in Tech Talk
Yeah something like that would work
