Posts posted by Testament
as above ^ lowering the cross member will probably change geometry for the worse, especially if you are planning on lowering the car.
nothing ever just drops in on swap like these. you chop the firewall and move the heater and some other things will have to be changed too no doubt. not that its bad its just how it is.
hacking the sump and moving the engine around in the engine bay is probably easier in the long run unless you are looking to get the motor in a certain location for weight balance or some other reason.
16 hours ago, My name is Russell said:
Cheers
I'm actually trying to find one more wheel, as I currently have 7 of them but would like a spare set just encase they come back wonky from being widened or the WOF man doesn't like the stretch
. Small ford spares are bloody hard to find these days!
Anyone want to sell a type 9 gearbox?
have enough bits kicking around to put together another powerglide
every time ive thought about the idea of using two stroke boat motors in non water based things I have wondered if you need to change your piston to bore clearances, like your coolant cirucit in a car is never going to be close to that of once through water cooling. maybe thats just my engineer brain over thinking it though.
I think the v4 jonsons were 90hp in boat trim so 150hp with intake spannies and more rpm sounds about right.
definitely interested to hear if it sounds wildly gargly like the boats but angrier
anyway good job, keep up the good work!
will probably do better than 15L/100km if driven with economy in mind. maybe even down to 11 or 12 is not inconceivable but does depend on how much effort is put into tuning low/part load, overall weight, wind, aircon, tyres. the old motor would have been bad if it had a big cam and only medium compression with a loose convertor meaning you would end up having to lean on it at lower rpm before the lockup would engage just to get it to move around town.
are you sure the LS9 gaskets are OK on the 4.8? the 4.8 has a smaller bore (same as LS1 I think) and tbh any of the MLS type factory gaskets appear to do the job well and can even be reused in a pinch
yeah normally should only take 30secs.
my take on the lc-1/lc-2 is they aren't as bad as people make out, its usually shortcuts in the install that are the issue. like a lot of electronics they are real picky about grounds and esp common grounds between ecu, gauge and controller if you want to see the same numbers everywhere. I have found even then needing to have a voltage offset in the ecu but that is almost certainly to do with my own wiring issues. probably because i've got it running off the same relay power supply as the fuel pumps. the warmup and fault outputs as well as a bunch of other things can be adjusted with logworks - which is one of the other finicky things that I find. you must have the LC1/2 on and reading (i.e. car running or unit powered on) BEFORE plugging the usb/serial into the laptop and opening logworks. for whatever reason it wont find it as an active com port if you have it plugged in to the laptop already and then start the car/power up the unit.
if you want to do it without the car running you need to unplug the sensor from the wideband - which is the number 1 pain of all the things using the bosch sensors - that damn plug design is such a pita to unplug. my thumb hurts just thinking about it.
The good thing about the lc1/2 is that they are full digital and have great response time which was way better than a lot of the competition for a long time as well and being the best value then too. not sure now with some of the newer options like the 14point7 and Spartan being pretty affordable and imagine things have mostly caught up now with the price of electronics components etc getting so low making processing speeds etc. a non issue.
3
will depend how grabby the clutch is too. i.e. it makes it trickier with an on/off puk clutch but with a full face that that's less grabby you probably wont notice it much as you have more time to react with the clutch or throttle
because he wants the job finished not piles of mess everywhere a broken brand new fence with no one else to blame
8
bonus points for finding the submerged power stations
actually that reminds me I need to go see the first geothermal generator in NZ, powered the spa hotel in 1940 or something like that. apparently there is a little musem somewhere near the airport that an old barry opens up during school holidays or something and he has it there, might even still be operational I dunno.
5
On 23/02/2018 at 11:29, My name is Russell said:
Yeah is quite similar now you mention it, perhaps a tad darker. Will jizz on the roof etc. etc. to match
17 hours ago, V8Pete said:
Do you have a list in Excel format or something?
Transpower put out a map with all the power stations and and substations
it should be expensive. it's fiddly time consuming ball busting work even if a lot of it may be made up of "simple jobs"
On 1/03/2018 at 23:31, Giant said:
I remember hearing they turn natural gas in to engine oil via some magic process
not all but some. it is a process used. fully synthetic is made somewhat like that in some processes. basically if you throw enough energy and science at things with carbons and hydrogens you can make whatever length chains with bits on the end that you like. you can start with gas, oil, or even coal or trees. then you just have to burn a lot of coal or trees and expensive proprietary catalysts to get it to fall to bits and stick back together in the form or whatever else it is you want out.
1 hour ago, kyteler said:
Shouldn't the V12 be going in this? Surely it is?
no.
M119 + 88mm choocher
is that the same colour as lees ranch?
On 2/18/2018 at 18:07, Roman said:
Yes being fussy.
But more specifically what I am meaning is that when differential pressure changes, so does your injector deadtime by a much bigger swing than if you keep differential fuel pressure stable.
So if you tune your fuel map at a particular IAT and ECT, when you come back later and these have changed your compensations wont work as expected.
Especially if you had a VE based fuel model where IAT and ECT are part of the fuel calculation at the start, rather than a fudge factor afterwards.
Now of course pays to keep in mind that ECUs like early Links didnt even have deadtime information at all, and a car will still run perfectly fine for the better part either way.
But if you try to get your cold starts and your hot idle and so on setup nicely, having this work as good as you can to begin with saves chasing your tail around...
Again though each person has a different idea/expectation of what they want from an aftermarket ECU.so you are saying there is a material difference in the injector opening time with differing fuel pressure DP in the range of 4 to 6 bar?
while we are talking opening times in the order of 1ms i suppose, but I'm going to need some convincing on that.
it doesn’t seem to me that it should effect the operation of the solenoid that much. if that made that much difference then so would engine bay/injector body temperature
On 2/13/2018 at 13:06, Roman said:
Yes but its a lot nicer to tune when your fuel pressure differential is stable (As in, your FPR is manifold pressure referenced)
As it keeps your injector characterization more stable.
In which case you obviously need your regulator near your manifold.
Admittedly I'm fussy but I'd only run returnless if I had 3d deadtime data from the injector manufacturer. (And the ECU capability to use this)you are being fussy
the flow of the injectors is still going to be repeatable, its just as boost rises/vacuum decays the amount of injector opening time for the same additional volume of fuel wont be perfectly linear but neither is is engines need for fuel necessarily - hence the need to tune rather than just going about this whole business 100% mathematically. plenty of modern cars run like this too.
but the main point of it is that it is alot tidier in some respects, a little cheaper (less fitttings and line needed) and if the car never had a return line you can use the original hardline which makes things super easy.
so nah not "ideal" but definitely works just fine
ceramic heater tap?
On 3/02/2018 at 20:56, ajg193 said:
Distributor drives pump.
I'll cry if no distributor.
One crank wheel + sensor = far cheaper than coil packsyou only need one crank wheel and sensor to a run wasted spark coil pack setup
nice car just I cant help but see that plate and I think more jacked up bum with slicks rubbing on the wheelarches
modulistic terror
a foul sadistic feast
there's only one way out of here
going piece by piece
to the laundry that is
might be able to do some washing soon
17
you really really want to put a fan get air flowing through from the top (cold air from outside) and down into the engine bay.
air to airs ontop of the engine are so compromised on 4x4s offroad because you have no forward speed for the scoop to do anything, instead you end up having a chimney where air heated by the exhaust, radiator and engine block is flowing up through the intercooler and not doing anything good for IATs.
I don't recall it saying anything specific in the HTCM to do with minimum droop but 40mm is probably reasonable. Reality it is a function of vehicle weight to wheel rate/effective spring rate
e.g. super stiff circuit car spring rates might only have 10-30mm of droop and give a skittery teeth rattling ride on the average nz road.
or the other one is if the shocks have been shortened so much to keep super short springs captive that could also limit droop depending on the specific details of the suspension in question.
Thousand Dollar Supercar's 1988 Jaguar XJ-S 3.6
in Project Discussion
except british and rubbish?
I guess if you fit a six throttle intake and squish your head a lot it might kinda look like a Z?
jokes aside, I hope you have found yourself a sparklingly sweet lemon mr supercar!
