Roman
Posts posted by Roman
  1. Hey guys,
    Basically I've got a few areas of my car which I want to protect a little better from exhaust heat, and for the exhaust manifold I want some type of shielding that will stop radiant heat from cooking the engine bay or melting things or whatever.
    Exhaust wrap seems PERFECT apart from the fact that the friggen stuff is useless and discintegrates almost just after you've finished putting it on. bah!
    Ceramic coating of the exhaust manifold is an option, but $$ and does this wear off, or stop much in the way of radiant heat? I understand why/how it works but I cant help but be a little skeptical that such a thin coating can prevent a really hot manifold from radiating heat in the same way that exhaust wrap could...
    For another area, I just want a patch of (xyz material) to be stuck to the underside of the car, so it's not being heated where the exhaust is very close.
    Any reccomendations on what would suit, in each case? (that isnt exhaust wrap)
    I had limited success heat wrapping the 2-1 section and then hose clamping a 1mm thick aluminium sheet around it to protect it, but this isnt going to work for the 4-2 section where the shape is more complicated.
  2. This is one of the greatest thing I have ever seen. 8)
    I commend you and your fine automobile.
    I reckon there's no point to the complexity of dual plenum, for an NA motor at least, especially with quads.
    Single throttle engines want to minimise plenum volume for throttle response, so they balance between that and having large enough to give comparable flow to each runner.
    You dont have same issue with quads, so bigger the better for plenum is better.
    Lower air speed in the plenum and intake pipe means there arent the same issues with biased flow towards uneven cylinder filling.
    Is that cosmos floworks, or a newer version of Solidworks which has it integrated?
  3. RX8 is a nice enough car to drive, but it really does fall into that gap where it's not exciting enough to be a weekend only car, and not practical enough (gas wise/space wise) to be a daily driver compared to similar offerings.
    FD RX7 is the best freaken thing in the universe however, do want!
  4. That stuff is so thick, I managed to pull most of it off by unpeeling it off at one corner, and just rolled up into a... roll when it unstuck off the floor. Hah. (On a hot day)
    Thinner stuff is definitely total win to do it on a cold day with an air powered chisel, smashes the shit out of it in big slabs.
