Posts posted by sheepers
this is the old compressor from work. its been on a pallet kicked around from place to place for the last 10 years or so.
its Italian, 44CFM 7HP 3 phase with a 270L tank.
and because of that its fucked in many ways. the pressure switch is smashed off, the inlet filter is completely gone, the shroud around the belts is badly broken, the wiring for this thing is all up the shit also the electric motor shroud is all smashed in.
it hasn't run in many years and when i picked it up from work it wouldn't even turn.
i took it home, waterblasted it and pulled it to bits.
So when I left off the motor was back to completely disassembled.
I got the cap machined and now it's back together with the correct crank end float.
The other thing is that I got the head flow tested with the porting and bigger valves.
It shows about an 11 percent increase over stock.
I was kind of hoping for a bit more but using the "no science just hog it out" method is probably why 11% was the result.
Anywho, now it's time to get the head all sorted and I can bolt it on.
Need new valve springs, new spring washers and retainers - all of which will need to be custom or at least sourced from some other engine.
In preparation for this I shortened the valve guides to suit the machining that the head needs to clear the higher lift.
3mm off the exhaust and 6mm off the inlets
- 31
yea i shed a tear when i saw that picture.
i followed the build thread when he was doing it. and i was at that track day.
total bummer to see it like that....
- 5
Surely you know I'm not just going to do that.......
not keen on harley davidsons tbh.
old compressors?
well tuff shit I'm going to put it here anyway.
just got given this.
its an Italian thing that used to run our factory about 10 years ago but has been sitting on a pallet getting kicked around for the last 10 years or so.
its fucked.
in many different ways.
but im going to have a go at getting it running and functioning semi decently.
things wrong with it - everything. the motor cover is smashed in so the motor wont turn, the pressure switch is smashed off, the inlet filter is smashed off and missing, the tank is rusty on the outside, the wiring is a disaster (it used to run a drier or possibly two and also has no way of putting electricity into it its really bizarre) and the legs are completely collapsed/wheels missing.
its 1246LPM, 7.5 HP 3 phase.
let see if i can get the thing functioning.
- 8
Story time/ going down the rabbit hole.
The issue- I never did any homework at all when it came to buying this blaupunkt head unit. If I had of I would have very quickly been made aware of how crap it is.
Is unusable as far as changing the volume, shipping tracks or doing anything.
Its physically impossible to change the volume accurately, and most of the time is not possible at all.
Totally my fault for not checking a single review or anything.
So, present day me (well yesterday me actually) was yarning to Nick the sparky about steering wheel controls and clock springs and whatnot and he said "I've got a 2013 Highlander steering wheel, see it that fits"
It does.
I needed to make a indicator canceling wheel to adapt the new wheel to the hilux.
Not super difficult, made a frankinstien rig up to machine a parallel diameter in the back of the wheel.
Them made a ring that I will shrink onto the back of the wheel once I confirm its fits the truck.
Then the next hurdle will be getting signals through the clock spring. It has 3 spare wires that aren't used so we can use those to send signals to the head unit. But there are probably other clock springs that will fit the truck that have more wires if we need it.
- 18
Nick recharged the AC system and now it works fucking ace.
Couldn't feel my fingers by the time I got home so I'm calling that a win.
Installation of new discs and drums.
Front was easy, as you'd expect.
Rear was a bit bit difficult to get the drum of due to the massive lip on the inside.
However once I got the drum off I discovered the thinnest brake shoe I've ever seen.
And of course the wheel cylinder was leaking so I'll get new bits next week and re- do the whole back brakes.
Also I found the reason why I'm now the best 4wd driver in NZ. Auto disconnected sway bar for max flex bro.
That's what the 4wd people say, you wouldn't understand.
- 16
- 8
Yea it was semi not terrible to get out with the dash apart.
Was a cunt to put back in
I'm a bloody farmer now you fucking ignoramus.
Anywho,
The heater drive motor has stripped a gear and thanks to the Nicksparky I got a new drive motor.
Also the AC compressor I ordered had the wrong pulley on it so I had to swap the new bearing into the old pulley.
I didn't want to smash the new bearing with a hammer so I machined the pulley away from the outside of it.
Once I got the old bearing out I chucked some metal glue on the new bearing and pushed it into the old pulley.
Jobs a goodin
- 7
All of which I have on order.
- 8
The seats actually came out looking quite good.
So I put them back together and put them back in the truck.
Fuck, so much more comfort. And now both seats have adjustable lumber support.
Then I fitted a cooling fan I had to the AC condenser. I made a bracket and it's in there pretty good. I made up the wiring loom for it but it got dark so I'll fit it tomorrow.
Also I bought new discs and drums for it.
- 22
I are a pulsterer.
I pulled the other two seats apart and have collected the best bits from the 4 to make two good ones.
The seat covers weren't super gross but I decided a turn in the washing machine wouldn't hurt them.
Tbh they didn't come out looking much different
They might get another turn in the washing machine I reckon.
New AC system.
As previously I bought one of everything from rock auto.
Then I installed it.
It was quite the job to get the TX valve out but yea whatever.
I still have to fit a fan to the condenser, factory they don't have one which doesn't do the rest of the system a lot of good and is the reason why the TX valves shit themselves.
Also shit I forgot to mention that I put the rear bumper back on.
This was harder then it sounds but basically I pulled all the brackets apart, soaked them in evoporust for a few days then painted them all.
I beat most of the dents out of the side bits and then bolted it all back in.
One of the mud flaps was broken in two so I welded it beck together with a soldering iron using cable ties for welding rod.
Is it good as new? No.
Will it last a thousand years? Also no
But it's back on the truck and works until it doesn't so I'm calling it a win.
- 22
What, for the whole truck?
With no idea what I'm doing I decided to pull the seats apart and see if any parts are interchangeable.
Long story short, the cushions can be swapped over.
So I did. I now have a fucking ace drivers seat and a fucked passenger seat.
Then I found a pair of good looking seats on TM in the same colour so I bought them.
Between the 4 seats I should have no issue making 2 good ones.
Stoked tbh
- 16
Is it a gofasteradi?
sheepers tries to fix an old compressor.
in Other Projects
once id gotten the thing apart i had a look inside the tank and it wasn't great, it also wasn't terrible but yea. im sure there are many, many tanks being filled with compressed air every day that look way worse but still i wasn't keen on having it explode in my face.
so i took the tank to get pressure tested.
the joker said it was too rusty for him to certify but that's cool with me, i don't need any documentation, i just need to know its safe. so its at the testing place now. once its tested i will get the tank blasted and then ill paint it some colour, probably whatever colour i have enough of to do the job.
then i had a go at fixing the belt shroud. i had to make a bunch of metal brackets to bridge all the breaks i could and bolt it all back together. I also had to make a big aluminium bit to fill in a huge piece that was missing completely.
when its a whole unit its pretty strong, ill make a bracket to support the far end of it (the whole thing hangs off the 4 bolts around the crank spigot and thats it) once i put the thing back together on the tank.
