Posts posted by d.p.n.s
1 tub completely done and 1 to go
made a start on the rear tub..(its only a mini tub just as far as the chassis rails)..started on the drivers side.
so im wanting to run a 9" rear wheel (10" all up ) not greedy. and i do have a banded 13" steel that is 9"........handy ay...it does fit but under any form of suspension travel it will rub
so i cut the rear half of the guard out and left the front half in place
i removed the old lip and clean it up as well as the steel that was left over all the way to the chassis rial.
i welded it back in and added a strip of metal
so now i have 12" gap........huge
re fit the rim
heaps of room now.
just need to weld the supports to the tub and make 2 small filler panels and then do the other side.....but very happy with the room now..well worth it.
- 17
small update but another thing ticked of the huge list.
battary box.
i just fitted a new battery to the mk5 so i just took measurements from that and made a box.
the good old mk3 has a different chassis rail on the right to the left...the right has more room as the filler hole /neck was there....and the box will fit so i made a hole
the box will hard up against the the side wall so i thought i would clean it up and POR15 the area first
sank it in and welded up.
made a top
still heaps of room for mufflers on each side.
- 19
now that the mk3 is back on the rotisserie i thought i would start .
the valance is pretty rusty (have seen worse ) in and out and pretty hard to get hold of here in nz ...and ive been thinking of changing it up anyway.
i wanted to cut the valance back up about 3" higher and make end caps and little recesses for the exhaust tips.(twin exhaust from motor).
so i marked out where i wanted cut back to and cut everything out.
it wasnt the best in there so i pulled it out side ...cleaned the area...metal prepped it and gave it 2 coats of POR15 in there
there was a bit more rust at one end so i did that next and plug welded the panel back down
then i started boxing it all back up...starting with the middle section
then i had to figure out where i could get a muffler in on each side and where i wanted the exhaust tips to sit...the exhaust will twin 2.25" from motor so i made cut outs out of 3"
next was making caps to box the inside with
and then last was boxing it all in
..next on the list might have to be mini tubs......thats a 9" rim so 10" over all and i really like the size.
i know your going to get it all in and running basically standard and get a cert then build a motor......thats when the updates will be needed..
i havnt seen or heard of anyone doing anything with the old ford v6 in what feels like ever.
7 hours ago, J-W-G said:
@d.p.n.s im going to build it for all the boost....
there.....fuxed you comment mate
holy shit.......the last update was april 2016...
as for your motor for the mk3 ....probably the engine build im.most interested in ....in a long time.
so as you know if you have read this topic this year i swapped the original motor out (because it was starting smoke real BAD!!)
i put the one that came in the parts car i bought in after swapping all the shit from mine onto it......and all was good with the world...it started ,ran well,and didn't smoke..... this one
and then one day on my way home from work it started rattling ....and it didn't go away.....and it started bleeding oil all over everywhere i parked.....(at this point i knew J-W-G was selling his 2.0 out of his mk3)
so thought i would try and fix/fuck mine
2 things happened that night ...1 i didnt fix/fuck it....2 it sounded better and the rattling when a away........................................for 9 hours.
so i bought J-W-Gs motor and he kindly dropped it off for me on the Saturday....i didn't do anything with it till the flowing Monday... Drove the old girl to work and it was getting worse so came home and pulled the motor out swapped the flywheel ,p-plate,clutch ,inlet and carb onto the motor(3rd this year) i got from Jesseas i know they worked well on past 2 motors (and against my better judgment not the water pump or thermostat) ....put it all back together and it ran like a dream fried straight up and didn't sound like a diesel...after a couple of days it did pick up a slight knocking sound (that when away when the clutch pedal is even lightly pushed (so wasn't to bothered )..and had a massive hesitation when you put your foot down.(found that to be coil to dizzy HT lead........the hard way......heeeelll of a jolt).
then this monday i left to go to work and got a few ks from home and temp was well over half way(normally the fan is just kicking in as i get to work )...it was a hot ass morning tho.
got it back home and it was very low on water.....so i bit the bullet and pulled the motor back out ....replaced the water pump and thermostat from mine......i know....i know.
found the knocking to be a stone jammed in the sandwich plate ......before you ask ...fuck knows.
i also decided to give it a blast and quick paint...and water last the engine bay and put it back together.....
and give the old girl a wash......shes happy as now and back to being 100%.
cheers all
just a thought mate but the SC manifold inst blocking a water gallery off ?
it cant be a massive airlock can it.?.
it does sound like a water flow restriction and it doesnt take much...1 small hoke covered by gasket and coolant temps go crazy
i hate coolant temp issues so i feel your pian mate.
the factory head gaskets should be fine...ive seen 500hp turbo 1uzs that havnt been pulled apart ( not long for this world...but 1 of them has made it almost 3 yeara so far)and the they stay cool with factory coolant setup and radiator.
i would be so tempted to pull the heads off and check that there isn't an issues with the gaskets....wrong side....wrong way around....stuffed..
apart from that ill keep reading replys
well after being in storage for just over 2 years now...the old girl has been sold.
its gone to a mate who only hounded me for 20 months.....and has big plans for her.
so everyone wave good buy to the mighty mk2.
it has been replaced with another cortina ......and that has taken up its space in storage.
- 5
if you dont need the money ...keep it man...bloody clean car.
and if you want to be able to jump in and drive all over the country without issue and good on fuel.....mx5 the bugger
you would regret selling it mate
and they fit pretty well......even with a wu-tang war whistle hanging of the side
- 7
so start of a new year (even tho its February now lol).thought i would clean the garage out and that met putting the mk3 back on the rotisserie and also making casters for it so i can move it out side....ive got some metal prep to do before POR15 and that en voles being able to hose it down..and dint want to do that in the garage..
bit of a bloody mess
all cleaned and ready to go
WOF yeaterday...again another clean sheet..so all leagal for anothe 6 months.
when i swapped motors i also swapped the 4 speed back in...( live in chch..fuck all motorways...flat....my work school home round trip is 32ks) and i prefer it to the 5 speed. also put a quick shifter in and it makes it heaps better.
almost had ghe old gjrl 3 years now and love it...second longest ive owned a car. lol.
- 9
started seeing if i can get the interior in and see what broken and what goes where.(they will need a good upholster to sort it all out...has been painted black and lots of rips.)
started with the back seat.
the bottom clips in the car that hold the bottom of the seat have broken off so i drilled hols and riv-nutted them.
the back seat frame will need to be straightened after sitting around with crap on them for years.
as for the base and as most of you know the base is held in with these little thin tabs.
and screws into these small hole with what is basically a PK screw
so i cut up some 3mm thick box section and welded them on and cut the old ones off
drilled new holes and used rivnuts
back seat all bolted in.
i bolted the front seats in and realized im in a situation ive never been in before.(i have moved seats,bolted in other seats,,,)
but im not a small person and normally everything isn't where it should be for me...like controls .gauges facing me ect ect.
but im still yet to weld the dash and everything in place ....so i could make things better for me while im at it..
i bolted the EPSC in place (still fits as same pedal box as facelift) and put gear stick in gearbox and sat the center console in as well.
now i can start putting dash all in to suit me....still need to make it all fit around the wiper motor and heater i made to fit the facelift dash.
on a side not ...1st time i have ever had seats in this car .........of cause i sat in it slamming it threw the gears making engine sounds.............i am human
got the dash support painted and put the rest of the dash together......very happy with it ...
pre face lift GT dash
now bog standard face lift.
car has a new owner as well....i have my mk2 stored at a mates and he dropped the other mk3 seats off for me today and couldn't take his eye off it (it is a bloody good body)
so we struck a deal and hes going to put it in storage until he has all the bits to put it back on the road.......its a good day...dash lloks mint....cars going to a good home
got the re face lift dash support out of the parts car and the face lift one welded back in.....first time ive ever done it....this was the worst part...think the one going in my car will be easier.
can start puting the parts car back together with all the shit i dont want/need and sell it on.
- 5
well i havnt build the new motor yet .....because i have other shit to play with.....but the old pinhoe has been getting worse......blows shit loads of smoke and sounds like a diesel...
the mk3 parts car i bought had a mighty pinthoe in it... so i pulled it out pulled the clutch ,flywheel,pressure plate,inlet and carb , thermostat and water pump of mine and slapped it on to the other one.... reason being mine ran and i had done them last year.
some new plugs and oil.....and man it starts first pop.....no smoke.....and so quiet .
old pinthoe
other old pinthoe
blooody good
- 17
when i bought this it was a shell and i was missing heaps of parts but the shell was the starting point for me.
i did buy some seats and door cards as well as the rectangle lights and a few grills (i like the look of then and the 1st ones to come along)from a mate but still needed lights and lots of other stuff..so i all ways thought that one day ill stumble across a parts car..
being a face lift 76 it has the same dash as the mk4/5 and i dint hate it but lately ive been thing about after market gauges and maybe subaru b4 seats front and back or maybe bucket seats in the back as well.
then a mate rings me on Friday morning and tells me he will around soon with a trailer......and later that day i had a parts car...........oh what a parts car.
its got everything that makes a GT a GT in it.
so i stripped it out on Saturday and got a pile of GT goodness.
the seats are pretty bad and will need an expert but they are all there.
the only part i dont need is the steering wheel and i have no idea how much they go for so i put it on trademe at $1 reserve..
the body of the parts car is pretty bloody good and has live plates and tags..so the plan is to take all the stuff i want and put all the stuff i no longer have a need for back on and sell it on to someone whos after a project.....far to good to just cut up...theres rust in the rear panel and i think thats it.
the big job is the dash steel back part....the face lift and pre facelift are totally different as you know so they need to be removed and welded back in ..in the other cars.
so i have removed the facelift from my car today
i will fully weld up all the areas with it out now and clean and POR15 what i can before i remove the other one from the parts car and weld it in.
cheers
- 22
1 hour ago, ProZac said:
Nah mate, Black one I'll have forever I think. Can't explain it, but have a good connection with that car. I've been collecting parts still, and I've got pretty much everything I'll need to do a really nice GSR-V replica. 12V DASH head, all the big driveline, later model interior... Should be good :-).
thats awesome mate.
oh good...i tnought you sold the lot mate..
im a huge fan of the starion and you dont see enough around anymore....or the early l200 utes.
love the old l200s mate....
and man life was so much happier (for me) when you worked at repco...
did you sell both stations Zac
made some panels to covers... the firewall recess
- 16
d.p.n.s mk3 cortina
in Projects and Build Ups
well thats both tubs all done now and what i thought would be a major ticked off the list.
and also under the advise from the oldschool GC brain trust...i finally got around to adding 2 small mounts to the rear of the gearbox mount for support.
