Honda Ass Dragger
Posts posted by Honda Ass Dragger
Progress has been made and the Manifold is nearly done
Just need to sort the External Wastegate positioning and the then sort the down pipes and the external plumb back piping
- 7
20 hours ago, sheepers said:
Yea neither tbh.
But how else is Yella from Liverpool Krispy Kremes going to know your Plazmaman Equiped
Can you not go full Yella Kebab Spec?
- 5
Fcking frothing for the 2GR
The Ray Hall GT86 seems to boogie
All back on the ground with 20mm spacer (Was concerned things might go Mexico) but came out spot on tyres still within the guards
Next stop fabricators once Covid stuff ends
- 6
Finally fitted the Alcons - now just need order some spacers to clear the wheels
- 5
Ordered Lines and Fittings to re-do the fuel system good by $1200
Then got the final parts needed before car can go to Fabricator for Exhaust Manifold, Downpipe, Intercooler Piping and Exhaust (TurboSmart Stealth 40mill Wastegate & TurboSmart PlumbBack Blow off Valve)
Mechanic coming latter this week to start doing lines and fitting the Alcon stoppers then its off to the Fabricator
Congratulations on finishing such an awesome project, so good to see this thing come together after so many years
Gearbox has been rebuilt
Brand New 2nd, and 5th/ / Reverse
New Synchros
New Bearings
New Clutch and FlyWheel fitted
Need to do a 1000 km then change gearbox oil
Finally then its time to go to fabractors for - exhaust manifold, down pipe, exhaust, intercooler piping and all plumbing- 3
Needs a Ecoboost n 6 speed
Guessing you have trawled this site for F-Con info - https://1jzmerc.com/hks-faq/home/
Brought a BBK
Alcon crb343 calipers
Forza rotors 295mm x 32mm
Hawk dtc70 brake pads- 3
On 24/02/2021 at 13:23, Roman said:
I think the reason the regular traction control setup uses ignition and fuel cut %, is because it can respond instantly.
Using something like boost control or e-throttle and there's latency involved and so weird shit can happen.
Plus with the normal traction control you can setup a slip limit, your tyre can put down its best grip while it's slipping at say 10% faster speed than non driven wheels.
I think the best way to set things like e-throttle angles and boost control, is to control the torque output proactively rather than reactively, then use reactive measures like ign cut to trim it from there.
So develop a table that represents how much power the motor is allowed under different conditions.
I've had some ideas about speed based boost control though, basically you'd build a standardized table that represents how much horsepower the car can put down without wheel slip under "standard conditions"
Horsepower has a fairly basic relationship against mass air flow so you could have an allowed mass air flow number at a given speed.
So for example to output the same torque amount to the wheels you'd need twice as much HP/air at 200kph than 100kph.
Then the load axis could be a trim pot or some maths channel automagic that perhaps looks at ignition cut % and trims the table up or down if you're wheel spinning too much or not enough.
Then boost control would work by having an "air per cyl estimated" target for a given speed and trim value.
So "theoretically" if you started wheel spinning at 80kph you could adjust your trim pot and it would rescale the rest of the map to still give you highest torque at the wheels that the car is capable of at each speed
/Just get slicks haha
This is some good food for thought - I've noticed a lot of Emtron users are using a ETB to bleed off boost (I think as a method of boost control)
I'll have to do some further thinking on this
Anyone played around with the Maths Logic on the G4X?
Was thinking to use it for boost control - by using a comparison between front wheel speed and rear wheel speed and adjusting boost until both match
Thoughts?
24 minutes ago, shrike said:
Considered going for an electric powersteering setup by using a corolla/GT86 or prius electric steering column?
How strong are MX5 diffs and how much power are you after? Id be looking at GT86 rear end and front components as well
3SGE are getting old in the tooth now as well, if you are going to a newer engine something like a 2GR might be fun? or if you want to stick with 4pot there are a few newer options (depending on if you want port or direct injection)
Also if the 12a goes you could look at going to a 13b or a renenis option, still lots of places sell rebuild parts. How long do you think the 12a will go for?
I was also going to suggest a 2GR - they are such a sweet motor and would sound so good with ITBs
Well I had a offer to re-spray the car I took it up - Looks so good in fresh Milano Red
He also re-did the Carbon Fiber Spoon Wing
I just brought a House so now I'm broke so gearbox rebuild and fab work for turbo won't occur until Mid to end of the year now
- 5
8 minutes ago, Roman said:
Jesus what does that flywheel weigh?
9.5LB OR 4.3kg I didn't intend to go that light but matched best with the new clutch
Flange has arrived PRL CNC cut Head Flange:
Progress is being made
Turbo is all assembled and ready to go - have got all the turbo flanges and v-bands required just waiting on the head flange and can start work on an exhaust manifold
JDMYARD 4 Bar Map senor has been purchased along with a PWR Racer series intercooler
Once above head flange arrives can look to send the car to the fabricator
Well after 3 long Months this arrived
Xona Rotor 5757s with Tial .82 V-Band Rear Housing
N/A has been fun but I've watch to many youtube clips of the TopFuel Ek9
Honda EK4 Civic
in Other Projects
More Progress
Larger Radiator fitted and Intercooler Mounted:
Manifold Now has Wastegate Fitted:
Dump Pipe Completed - except for wastegate plumb back waiting on a bellow:
