Posts posted by mk5corty
can you get to the back of it? If not then dent puller or homemade dent puller, if the peice of the panel is an easy shape to make out of sheet steel then it may be easier to cut the damage out, use magnet clamps to hold the steel in from behind and tack weld and bog, however i donty think that suits you.
Anyways get your hammer, panelbeating set if you have one if not then an ordinary hammer will suffice. Either hold something on the panel (dolly if you have one) or use your leg to brace the steel so the dent takes the force not the whole panel and use many lighter hits to try and get it as close to flat as possible, if you over hit it, goto the other side and bash it back, block sand with a low grit like 80 so you can see the low and high spots, fix them as best you can by bashing back and forth and then bog.
its less porous than normal bog, tested that shit, but still no good, was useful for covering up what looked like 10 1mm drill holes that were on my door, fuck knows how they got there.
if you need to use newtech then chances are you should be welding anyways, but muzzie is fine.
yuh, ruins bodyfiller aswell, means you have to fix all that again, i would only use where i cant use my DA and 40grit to strip with.
also depends on the stripper i have used some stuff that seemed only to degrease lol and stain the paint, the crc stuff seems to get a good rep.
would prefer the shelby it looks to be based on but still sweet as car.
the fiat multipla is a fucking hideous beast, what about that one that was called the worlds ugliest car, was rare as and just got restored, bwahah here it is
looks like an icecream truck from the back, would be almost as aws as the noahs ark van that was on trademe lol.
only one i have heard of is schutz application guns for applying underbody surfacer etc
need a proper rotary buffer that spins at a few thousand, not a shit orbital one. 1200 grit the 2000 then meguires medium cut on a wool pad then meguires fine cut on foam and swirl mark remover on foam if need be. thats what i do anyways comes up mint, dont have to use meguires tho.
351 cleveland doesnt fit as well as a 302 windsor does, already investigated this for my cortina., unless your going for a 302 cleveland?
If you going 302 windsor get the clevo heads and make it a boss engine, takes a bit of work tho.
IF its a windsor then 6l is too far, 347 cubes is the practical limit.
satin finish lol, hit it with a scotchbrite and have matte black woot.
got any colour left? do what i said then bung it on the car and coat of clear, should only be like 1lt of clear.
280ks pretty decent life tho lol.
Isnt that over twice the price of coby's then?. Got some brand new 4-1's off trademe woolf muffler brand prob shit as but cost me $80.
lol, if he cant be arsed buffing then hit it with like 400-600 and spray another coat of clear and leave it there, a bit orange peel but shiny. or you using SS? guts about the 20v
chrome, factory alloy, factory painted ?
durty windows stz cant see shat. meh 35% on a sheet of repco crap looks light but once you do all the windows looks darker.
wheres that exhaust site link, we had this discussion before and im sure we came to the conclusion that unless it is a well worked engine the differences are negligible.
maybe misinterpretation, i think he means the vg30 is a boat anchor
600rwkw
http://www.nizpro.com.au/images/DSC_0161.jpg
streeter lol. can you say too, much, money. But fully aws.
bore AREA x stroke then x the number of cylinders
so 9.24 x 9.24 x pi (3.14159) / 4
bore area = 67.055
stroke 7.695cm
= 515.99 cc per cylinder
=2063.965
std pinto bore 90.8 = 1993 cc
xr6 turbo ftw, hmm 1976 xc falcon xr6 turbo.... now your onto something 300kw with ecu retune.
we could go on forever with this if you had a block one.
RT is right.
Show the ricers you dont need VTEC EH BRO to go fast in NA
littel off topic but RT brought up v8's
I was going to put a 351 in a mk5 cortina but then though fuck it , shes a hideous beast and the conversion would cost as much as buying a much nicer looking XC falcon with one already in it. Stroke to 6.7litres (408ci) quad carb, flows etc go hard as. slap a blower on there with a few psi.
yeah theres a few different bolt on heads but that and the cosworth are apparaently the cheapest ones. Can get custom ones cnc'd out of solid blocks of aluminium and shit. Someone was trying to make them to sell big but costs were too high, had the ports and everything perfect.
crap 350 at the treads on 15psi, thats awesome, what ford 2l? pinto, zetec...
underseal??!!!
in Tech Talk
i removed alot of it to get to the rust, it didnt seem to have served its purpose very well.
Anyways didnt try dry ice but did use a heat gun and a scraper worked pretty decent.
