Avenga
Posts posted by Avenga
Started work on the fuel system.
I am keeping the original fuel tank and the fuel pump and filter are sitting between the old tank and the side of the car.
Then there is a surge tank behind the original tank, there will be a lift pump on the other side of the original tank which will fill this tank.
Then the surge tank will go off to the main pump.
Finished off the transmission tunnel
Stripped the car down ready for panel and paint on Monday
Engine bay and transmission tunnel from below.
Rear end fully stripped
Finished stripping the body loom. Removed about half of the wires. Still need to make a new fuse box and a few connectors for where the engine loom and dash needs to connect.
Traced and labelled all of the wires on the old loom.
Big box of wires that I cut off the old loom
This is the old wiring diagram. Everything with a cross through it has been removed.
Brought an alternator only pulley tensioner from http://www.thecartunecompany.co.nz/ I am not running AC, Power Steering or the hydraulic cooling fan, only running the alternator.
- 20
Created the inlet for the air filter
Looking down in to the air filter
The air filter comes out the hole for the old heater and sucks air in through the vent up by the window.
Created a box around the air filter.
Created the mount for the ECU.
Tack welded all the seams in the engine bay
Also tack welded and gusseted the suspension strut mounts
New custom drive shaft and hoop.
Finished off the transmission tunnel.
While I was taking out the demister duct I saw this cool sticker. It looks like it is the ID tag for an order of 50 left hand demister ducts. This one must have been at the top of a stack of them.
Hey Cam!!!
Yeah, it has been way too long! I'll send you a PM.
7 hours ago, Shandangles said:
I hope you have good earmuffs. That induction noise will be ruthless in the cabin 10/10
I like induction noise so it should sound pretty cool. I am going to build a little enclosure around it so it will suck air in through the plenum.
21 minutes ago, MRT1TRD said:May I recommend using N2O for a heater when it backfires
Haha, good idea.
I have already brought my new heater. Using this electric one https://dcthermal.com/product/sa12-4000-12-volt-brushless-cab-heater/
Designed an Avenger Hydra logo and 3D printed a couple of different sizes and colours
Tested them on the tailgate of the wagon.
Not quite happy with the H so modified it a bit.
Still not happy so gave it another tweak but I may go back to the drawing board. If any one know a font with a cool looking H then let me know
Pulled out a collection of old badges sitting around to see if any of them suit the car.
Ended up quite liking this pentastar on the front of the air cleaner.
Here is a view from further back
Also tried the Chrysler badge on the other rocker cover. Looks pretty cool. I might design and print something more in the same font as the other side. I will probably leave the Quad Cam V8 on the other rocker cover so it might look nice if they both match.
Ordered the air cleaner. It is freaking massive. K&N RD-1450. 7 in (178 mm) Diameter, 6 in (152 mm) Height, 4 in (102 mm) Flange
It is actually going to sit inside the cabin. Where the heater used to be.
- 19
Yeah, they do on the hotwires. I like the first one better anyway. I used to have hotwires on my old Avenger race car so I sort of wanted something different and have always liked the look of those first ones.
Damn, these look nice, They say they can make them to order with any offset http://www.performancewheels.com.au/product/challenger-forged/
Or they also do hotwires
Awesome. Thanks for those links.
I will check them out now.
I am running 5x114.3 all round.
Started work on the air cleaner
It is going to seal on the bonnet, so the top will be open so you can see the trumpets when I open the bonnet and then the actual air cleaner will be in the firewall at the back of the engine bay. Still need to design the front plate, Not sure if I am just going to just use plain ali or do a logo or something else cool
Also test fitted some wheels to see what kind of offset I will need. It is actually a lot less they I thought. I and going to use 15X7 wheels with around a -25 or -30 offset. I think I am still going to have to go steel wheels because I can't find any alloy rims at that offset. If anyone know of any alloys with that much negative offset then let me know.
Next up I finished off my dash. I had to recreate this little lip around the bottom of the cluster.
So I drew it in CAD
And then printed it out
Fits perfectly when installed
It just closes up this little gap at the back of the dash.
- 21
Tested the fit of the bonnet, and it closes!!!! I won't need to do a power bugle or anything. Stoked that we could squeeze the big V8 and trumpets under the bonnet. It is going to be such a sleeper.
It is pretty tight under the bonnet so I am probably going to go for some slightly smaller trumpets and maybe drop the crossmember and engine down an inch
Added even more strengthening, this time on the panhard rod mount
And made a gusset for the other side.
Ran the rear brake lines. The flex hose connects up to the standard mounting location so I can use the existing brake lines from there.
And the other side. You can also see the new upper arms and strengthened lower arms installed
- 22
Same here. It was nice to catch up with the EX guys. Pretty awesome turnout and it was pretty cool rocking up to the hotel and seeing the Lancers.
I snapped my clutch cable on the way back up so I had to get it fixed in Taupo.
The little clip on the end that connects to the clutch pedal broke off.
Took it to a local workshop and took the cable out of the firewall
Then welded the clip back on
Didn't get home until about 8-9pm so it was a long drive for me.
Yeah. I will need to do all that sort of stuff when it comes to cert time. We are checking as we go with the certifier, so it should be all good for the cert when it is finished.
Finished the lower arms. We did some more strengthening by adding a gusset over the top of the lower arm.
Painted the Diff
Finished all the mounting brackets
And the other side
Some more progress on the exhaust. Did more of the Y pipe.
Started designing my new dashboard.
I designed it all in Fusion 360
Then printed it out on one of my 3D printers
Did a little test fit. Fits perfectly.
I had to print it in 2 parts because it was too large of my 3D printer so I made a little joining plate on the back on the dash. Also those little square bit up the top fit in to where the indicator and other lights used to be so I can screw it in from the back.
Installed the carbon fibre wrap. I will see how it looks in the car, might swap it out for just a matte black wrap.
Installed it back in to the old housing
Cut a whole in the back for all my data and power cables, you can also up the top see my where I screw the front panel on, the old dash was held in by screws on the back of all of the gauges that went in to the old PCB.
Tested it with the surround in place, there is still one more part that I need to design for it, which just goes around the side of the surround, where you can see a bit of light coming through
- 20
Started work on the exhaust. I am running dual pipe down to just after the gearbox, then single pipe out the back.
Had to modify the factory exhaust headers on the drivers side so it goes around the steering column.
One runner sits on the left of the steering column and the other is to the right of the steering column
The passenger side is easier.
Still got some room between the exhaust and the body.
Mounted the diff
Fits in there quite nicely
Just have it tacked in at the moment.
Also made up the new upper arms to replace the old broken arms. You can see the old one at the front, and the new ones at the back.
There was about 150 cars.
Here are some photos.
We all parked up outside the old Admin building, which is now the headquarters of MMC NZ. There was another big field of car but I got there early so I could park in front of the admin building itself
There was this nice Avenger GLS Auto
And Miles with his Tiger
After that we went in the admin building for a presentation about Todd motors history by Mike Todd and Neil O'Callaghan (Service manager for Todd motors who has worked there for 45 years and retired at the Heritage day)
I have always wanted to see inside the Admin building because it has the funkiest 70's style roof. Each of these panels are 2.5x2.5m fibreglass panels made specially for the Admin building.
They had a whole table full of old service manuals
I loved the 50's cartoons on them.
After that we cruised up to the Southward car museum. Followed a Charger for a bit
At the meet up outside the museum I talked to the owner of this sweet single owner Valiant wagon. He ordered it custom from Todd Motors with a 318 V8 way back in 1973.
And also Mike Todd had his genuine E49 Charger there *Drool*
They put on a nice lunch there and then we got to look around the museum
After the museum everyone went their separate ways but as my hotel was literally right next door to the old factory I figured I would drive up to the factory itself and have a look around.
It is truly massive, at the time it was NZ's biggest factory. Now it is used as a distribution centre for tons of places like Big Save furniture, and is also home to a few freight companies, and a NZ post depot. But the one that I was interested in was the Placemakers because I saw they had a drive-through, it was just for timber but I drove inside the actual factory and got some photos of where my car was built 43 years ago. Pretty damn awesome bringing my car back to where it was built, a homecoming of sorts.
And then took a photo outside. You can see how long the factory is.
Then a rainy start to the drive back up to Auckland the next day- 11
Yup. I do still have the bellhousing. PM me for details. Not sure if it is 1JZ but it is the bellhousing that came on the R154. Here are some photos
34 minutes ago, japlish said:
still got the 1JZ bellhousing?
Yeah. I think I do. I'll go check my spare parts stash tomorrow.
1 hour ago, Thousand Dollar Supercar said:
Good to see you back, dropping half a build thread in one day!
The digital dash caught my eye. Manufacturer's product page if anyone's interested: http://aimsports.com/en/products/mxs-strada/index.htm
You're replacing modgies with modgies?
Kidding - I expect there are limited choices available when you need to be able to specify so much about the wheel. What's happening with the suspension, front brakes etc?
I started the build about 2 months ago, over on the Avenger forum. I wanted to make sure that the V8 would at least fit before posting it here.
Slightly more different modgies. My rear diff is about 100mm narrower than the standard Avenger diff so I am going to have to run quite a bit of negative offset which sort of limits my wheels. They are pretty much going to be the chrome version of the black D windows on my 75 Avenger.
Yup. That's the dash. It's an AIM MXS Strada, street icon version. It's pretty cool. Has really good software that lets you design how you want the dash to look. and then you can store 6 layouts then just switch between them on the fly. You can add a GPS and it can do lap times etc so if I am doing a track day then I can just switch over to one of the track layouts and it will show all my lap times etc.
21 minutes ago, brocky41 said:Wow nice work, I do like a good high revving V8 - please lift factory limiter a little
Yeah. I will be lifting the rev limit. The throttle bodies and better exhaust should let me pull some more revs. I have the link ECU so I will run it up on the dyno when I am tuning it then decide where to set the rev limit based to the HP curve.
Yeah. It’s staying stock other than the mechanicals. I have hidden all the reinforcements under the body and I hope to get the trumpets under the hood, so it should look really stock, until you open the hood or start the car.
The modgies are going. I am going to replace them with 15x7 chrome D windows.
Yes, the diff was built by @johnny.race I brought it off him on trademe, didn’t know he was on the forum. He did an awesome job on the diff.
8 hours ago, nzed said:
This looks like it will be so much fun to drive!
Are you doing the fab/panel work yourself?
I’m getting Bygone Autos to do all the fab work for me. They did really great work on my other Avenger
53 minutes ago, mjrstar said:Fuck
Yeah
Should be a sweet little sleeper!
Yeah. Should be a really cool sleeper because nobody would expect a V8 in a little Avenger Wagon.
Thanks guys.
It should be pretty fun to drive when it is finished. I'm going to try to keep it looking like a total sleeper, so hopefully I can fit everything under the bonnet.
Avenga's 1UZ V8 powered 1980 Avenger Wagon
in Project Discussion
I brought it from Kelvin at Cartune. Been chatting to him via emails.
He was really quick, brought it on Trademe on Wednesday, arrived today.
I don't know anything about their history other than they have done a lot of 1UZ conversions.
