Truenotch
Administrators
Posts posted by Truenotch
  1. Hahaha oh to be 15.
    Thats haggard :D
    :P , I've still got it somewhere if you need a muff for the 7A? Steps from 2" to 2.5 " to 3" with blobs of weld inside to create a venturi....
  2. May as well get them as close as possible to make it easier to mig / tig later on.
    It'll still be a challenge :P ... I used an arc for my first "exhaust" attempt for my AW11 when I was 15...... Blew holes, then had to fill them constantly. Might have helped if the welder didn't have a broken heat adjustor...
  3. Ditto here.
    May as well give it a try though... Just get some thin arc rods ~2mm or so and crank the amps right down. Just use the arc to tack everything into place and get someone with a mig or tig to touch it later on after you're happy with the shape.
  4. Have a play with re-locating the hole to change the roll centre, it's a good idea - the same concept as using RCA's on later macpherson strut setups.
    As far as those ideas on creating a similar arc between steering arm and lower arm, there are simple ways to figure out where the best spot for the steering arm is. Basically you want to make both arms share a common arc, and if you can do that there will be much less toe fluctuation = less bump steer.
    I'll tell you more when I get further into my book.
  5. Pics? ... does your have a leg gaurd :mrgreen:
    Broke one of the exaust bots last night DOW so got to work out how to get that out tommorrow.
    2 new tyres and all new pads monday mean.
    Sand down the needle, make an exhaust with a small coby as expansion chamber with a tiny exit pipe. Then roll with "choke" open at full throttle and gain 7-10kph.
    Mines a blue one, with blue seats and white guards. 2 speed trans from FS with the big wheel on the back = 70kph on the flat when it was fresh. Was lucky cause mines a late model with the different rear spindle so the wheel went straight on to the FS box.
    Pics when I can be bothered :P .
  6. Glad to see you got a new guard man. Still thinking about using a different diff ratio? I'll dig the van diff codes out if you want them.
    Was good to put name to face at the trackday last weekend, but it's a pity neither of us had our cars there!
