Posts posted by Truenotch
Hey guys, Im actually curious, how does one get a wider stance on a car?? Is it just by the offset of the wheels? Im talking about 70mm wider each side, so going 3" wider mags isn't really practical. However, I guess if you have 6" mags with a 0pt offset then that will give you your 3" extra width?
Are there any other methods of doing this? 70mm spacers aren't exactly a good idea.
Regards
Dave.
Whats the offset on your 17's? If they are 40p offset and you went to the same width wheel with a 0 offset then the wheel would sit 40mm further out. If you want 70mm each side you'll have to run 8's with -25 or something silly and it'll look like a dirt track car.
Interesting stuff from kpr's build thread, I've got a few queries now since everyone seems keen to try it. The idea is simple enough - slice and weld, or just head a spot and let it tweak when cooling.
My main query is whether this would mess up the geometry if done to a car with 4link etc. Since KPR hasn't welded his shock mounts or links on yet he has a blank canvas for correct angles... but if you did this with an existing 4 link it would leave them twisted all the time (not by much, but 4 links are known for binding when angles are wrong).
Do you think it would work sweet or not? Discuss.
In my case I've got a good parallel, even length 4 link setup and a floating axle solid diff (which will allow for more 'natural play" due to having a spline on each end). I'd like to try to get some camber, but don't want to risk ruining the geometry.
Flowfast 1 in 1 out offset mufflers are about $100. Get.
That's really cool! Looks like you have a degree or so in there. I'd be keen to do that to my rear end, floating axles means there's two splines worth of "natural play".
As sharp as you can no matter what man. Need a nice straight edge and a hard, sharp tool that wont bend when you plunge it in.
I ran BKR7E's in my car for a while and they died pretty quick..... but who cares when they're that cheap to replace
Got perfect fitment?
Visit please?
Really interesting stuff! Agree on the addition of a castor arm to keep it all under control and re-location of the ARB as well as adding an adjustable link to the ARB?
You could almost use a Japanese coilover for the front setup. You would just have to choose the right length ones and play with camber plates / bottom mounts to get it right.
Sweet! Looks like it's running fairly well and isn't desperate for a tune?
Looks good man! Will need those spacers to balance everything up, might appreciate some longer lower arms as well?
1st pic looks like you've slammed a dirt track car.
Shouldn't have cooked the link, mines been through heaps of shit since I've had the car and hasn't dropped a tune yet. Ran with an alternator that wasn't charging for a while and had an issue with a switch that was killing all my voltages. Shouldn't have a prob.
Yuh, links aren't keen on low voltage. Alternator charging sweet?
SHGWAG - SW and AW handle totally different from eachother. I've always found AW's are more stable.
P.S - run in mission to the Manawatu wouldn't go amiss.
Mid engine = more traction in the rear KY. It won't be as bad as you'd expect and will get more drive to the ground than a combarible FF or FR car. Privided the spring rates are all good and ben chooses decent tyres there won't be an issue. It'll be good old fashioned groupB style safety-fun!
Will report back after I've begged ben for a fang
*begs ben*
Yeap, go see Rodney - he's good with carbs.
06-3551293 in Pirani Place off Tremaine.... But you probably knew that.
I'm jealous of this fellow.... Have only seen one in my life and wanted it - sports model too.
My other car is a.....
The Ratrod:
How could you change your mind about that?! Good work!
Meet you at U-drive at 3:30 for skids in my mums Wagon?
Didn't have a good weekend this time. Went out for practice on Saturday and sheared an axle, which the nom-nom'd the bearing cage on the diffs carrier bearing and put a stop to my racing.
Diff:
How it should look:
Sponsor:
So the plan is to get some nice chrome moly axles made up with hardened splines before the next event (not till november or so). Will be getting them done by Howat Engineering in Nae Nae http://howatengineering.co.nz/ .
2x Matty B pipes going straight out the back with an angle slash on the end would be sweet. MX5's are for having fun in, not ricing up....
Front guards on the back is smart.... Makes a lot of sense.
whats next?
Saw a 620 rolling round today. Blue, flat deck with wooden crate stz on the back.... Reminded me of you.
70's car vinyls aka DATSUN DEALER OPTION
in General Car Chat
