Truenotch
Administrators
Posts posted by Truenotch
  1. Yeah it's still worthwhile doing IMO. Isn't cheap but often the centres that you have will be WAY cooler than anything new on the market.... And a set of something half decent like DTM Banzai's are $1200ish for a set of 15x8 +-0 wheels. Works out for the best in the end I think.
    How much does Bateman charge? I want to get wider bands for my simmons eventually.... but only outers (which are small) and I hear he charges the same for any width band?
  2. Would be way meaner slammed on 14" dish.... Although the chassis rails might end up under ground.
    I like it, and think that the engine won't be too bad. My mum has an NA forrester and it goes surprisingly well for a heavy 4wd with a small N/A engine.... I'm sure there will be developments on the engine that make it better than your average poverty pack subaru - and hopefully it has more balls down low.
    You can see why they did it though, a Boxer engine sits low and can be mounted quite far back, which meant they could have a low bonnet line while still conforming to frontal impact laws. So long as it handles well I'll be happy.
  3. I think it's a good plan, and so long as it was put together well it would be viable-as.
    If we chose the right range of cars and arranged them in the right order it would be fairly popular to the outside market. Something a bit different, and halfway between original and modified old cars.....
    P.S - Will this be being sold with an issue of Pinto Magazine?
  4. Go for a flowmaster type with offset entry/exit. You should be able to fit it as a rear mufler cause there is a lot of room under the boot floor. Easiest option for you would be offset entry with a centred exit, cause then you won't have to change the U bend and will be able to shove it out the back with a U bend. That's the way I did it for Totemo's car and the same as all my ones have been in the past.
    Basically like that if it helps. Never been too loud on my NA setups.
