Posts posted by CaMpylobacter
The one dealer I've worked at didn't get charged for key codes. They didn't charge a lot for it either.
Maybe others (car dealerships) are different.
The whole dealership culture in nz is so lame and needs to change tho. Hugely top secret. In Europe they are forced to make info available by law.
I think the dealers in other cou tries do way better than here. In nz people only take their shit to the dealer when it's new. If the dealerships were more forthcoming they'd probably do a whole lot better.
- 6
Yeah weird. I guess they're all fuzzed up about it at the moment.
Lots of old truck barries fill out their own 5th wheel ones without issues (and no obvious disturbance of said coupling) and the form says you can yourself so yeah. 2 years for the next one so meh.
4085D form is tje one to fill out for this. You can do it yourself if you are competent at maintenance. I'd say that means you
I can't see why you can't do your own form for this? You're allowed to for 5th wheel couplings and skid plates...
I've heard of heaps of motorhome people getting failed for not having wheel chocks on board? Is this the case?
Also you're meant to have a sticker saying it has a cardon shaft handbrake or something now?
That beddy is sick af
Can't make it this year guys!
Xox see you next time
have you thought of 10 helicopters
yeah I always turn my fuel off and run the carb bowl dry before putting away so it has fresh fuel in the carb every cold start.
also I usually pop the air cleaner lid off and give a squirt of crc 5.56 which is volatile enough to work as a safe starting aid for the single pull thrill.
probs ken to support if required
xox
I was gonna say get your massage at china palace.
$20 for old mate that makes the cocktails
$30 for his mrs behind the counter
$0 for grandma. she'll pop her teeth out and appreciate the warm drink
Discos are way better than prados tho
Shit it's coming around quick.
Got myself a 1190 for this year
not much has 14" 4x108 sadly.
for steels, look to Peugeot 405/306 or citroen bx.
14x6 with a 20P offset is spot on usually.
you may be able to clock hubs 90 degrees and redrill to 4x114.3 as well which opens many doors of course
can't really redrill to 5 stud, though. if it was 4x114.3 you can reuse one hole and drill out to 5 without enoughmeat no worries.
if you need new hub/rotorassemblies you could go to 5 stud also
better living
yeah i switched to citroen BX 14" steels on mine with 185r14c commercial tyres after having a 13" commercial tyre overheat and blow out,ripping all my cabinetry to bits
oosh
looks like it has trojan MK3 calipers, so you can buy brand new cunts that'll bolts straight on.
my pioneerhad mk2 which you cant buy much for anymore, so i bought conversion set to go to mk6, but they didn't fit without lots of clearancing. weird.
i just carry cheap tools in an aliexpress molle pouch. they get wet but when they're cheap who cares.
just do itup real tight and have a bit of flat bar/tyre lever cable tied to the front fork to use as a lever to undo it
I'm cheesin'
would love a 400 burgman to ride around like a boomer.
- 5
I'd love to know what it's worth to you
Kicker's Nifty
in Two Wheels
ooosh af18 nifty is amaze.
get a high speed variator on there STAT
blizzo's one used to pin the speedo needle right round as far as it could go with me on it.
so good.
