Posts posted by RUNAMUCK
https://www.aliexpress.com/item/4000151271784.html
Must have bought the 5 pin one?
I bought some relays off aliexpress.
They had two "power out" wires. (Could be an earth trigger if so desired) one was live when the relay was energized, and one was live when the relay was not energized.
We're going to fit one to dads Car, run a 12v+ feed off the key to the switching side, and a 12v ground off the oil pressure sensor. So the fuel pump wont pump gas until the motor gets oil pressure.
Conversely if the vehicle suffers a series upset/crash/etc, and the driver is unable to manually turn off the key. Then the power supply to the fuel pump will stop as soon as the engine oil light comes on.
Not as fast as a modern vehicle with EFi. But if the driver has injuries preventing them from exiting the vehicle under 5heir own power, it prevents a small fire becoming a very very big one.
Modern problems require modern solutions.
18 minutes ago, EpochNZ said:
You're gonna want to switch out those tyres for something better suited to off roading.
I say send it.
I've always liked flares. Even 5hough the ones on my old tanga were the shitty generic TE27 Levin flares.
On 04/01/2023 at 10:51, tortron said:
And now its a mini camper.
Going to build a bathtub type base out of ply to attach it to, so it can all slide off as one piece (and have some decent mounting points)
The idea is to make it a pop up, with canvas sides. It's about 76cm tall inside, so with 1.2m of canvas sides it should be pretty good inside.
Will build a bed base/storage/kitchen bench into the ply base so it is all contained
Looks perfect for displaying a dead person for a state funeral
^actually I think Tony once said he was the man too. (Which is high praise, cos Tony is a good cunt)
I dont know if they still "make" clutches as such. By Tony at clutch systems NZ in chch is the fucking man with clutches.
Yes you're tired by the end. But you'll have bugs in your teeth from smiling so much....
You say that now, but you wont want it to end when you're there.....
I dont think they sold a manual, but a turbo Caldina should be able to get out of it's own way.
Unless you have massively soggy engine mounts that allow the motor to bounce all over the place, I'd be very surprised if the clearance you have there is a problem?
Just happened across your thread for the first time. You have all the drag link clearance! Mine is tons closer. Defo pays to check your full range of steering too. On some vehicles, the link raises and lowers although its sweep. And some it moves forward and back.
Shinko SR421 is hard to beat.
1 hour ago, HighLUX said:
Removing dent from a fuel tank? Car sat on the ground sans wheels so a portion of the tank got pushed in so more of a depression than a dent
Have got popped half of it out hammering a wooden pole thru the fuel pump hole but cant get to the corner to finish the rest of it off
Tack weld a nut on the base and slide hammer it out?
Make up some blanking plates and use a waterblaster to hydroform it or compressed air?
I'd try compressed air tbh. Put 120psi on it, and warm the dent with an oxy acetylene torch. Set up camera to film the dent popping out.*
*pleez dont.
But compressed air is what I'd try
Finished work early yesterday, and had a crack at my CT110. Put some power on it, and gave her a few kicks. Nada.
Pulled the plug and gave her a few kicks. She was sparking like a champ.
Gave her a lung full of starter fluid. Rev'd up fine. (Then died) tried it again, and while it was revving out jammed my hand over the carb. Naturally it flooded up. I found if I flooded it, and lifted off it would rev up again. (All testing done at WOT) rinse and repeat.
So the carb had to come off.
Stale as is yuck as! This fuel is likely from 2014. (When the bike was last on the road)
Carb is all cleaned out and minty fresh now. Gave the gas tank a drain and sluice out with fresh gas. Otherwise it wasnt too terrible. (Bike is an '08, so it stands to reason it hasnt had the chance to get really horrible yet)
- 6
A bunch of pests pesting
Early chrysler autos had two pumps. So you could tow start them. (Or so I've been told)
Find an auto rear counterweight, then you can bolt on a neutral aftermarket flywheel. I'tl need to from an engine weight the rotors as yours.
BBW,
BIG BEATIFUL WHEELS!
If you watch the video in that link, the guy points out that the mazda has a centrifugal supercharger on it........
The problem I see is, if the cylinder miss fires, theres nothing to pull the piston down the bore, and it would lose contact with the wavy thing. From there, theres probably no recovery? Also I dont get how it starts without the combustion to keep the follower in contact with the ramp???
Tortrons it's old school now wingroad
in Other Projects
Does this thing go Zutututu yet?
