Everything posted by peteretep
http://pap.co.nz/catalogue.asp?action=b ... ategory=26 tried them? dunno if they do your stuff but maybe
haha oldschool house styles
how do you get so much money methodz100?? i want your job
you need pinto mounts and you need to have your sump cut and rewelded to suit, there are many threads relating to this subject
yeah i just had a 2m length of pipe to undo the bolts
probably i forgot, has something to do with kent though:S
because the 1600 ohv crossflow was designed by a guy called kent and the pinto ohc, being a different engine is named after the ford usa car that first used the engine and was called a pinto
you dont flip the leaves, escort vans have like 6cwt i think on them which means they have heavy duty rear leaves to handle extra weight, so without any weight in them it would sit as high as a kite. the way it is made stiffer is by ford adding an extra leaf, so take it out then your leaves are like a normal escort
because its a van it has heavy duty springs so maybe you could just take out the extra leaf then get it lowered
you can get the leaves harder too
i was quoted 220 a 5 months ago, though, when i was thinking about getting it done so i dont know...
at snells costing 220
for 220!! you can have anything done to them. ie original factory, lower it 2 inches and have another leaf added to it or whatever, im getting mine taken down 45mm and having another leaf added to make it a bit harder and as a cheap way to stop axle tramp, not that i'll have the power.
i got that quote from snells the other day, just about to get my leafs reset... 220 is for both leafs... so i dont know where u get 120 from
yeah resetting leaves is 220 and you can have anything done to them all for that price
excorts mk2 - NO FLAMING, discussion only, including me!
peteretep replied to atropine's topic in Project Discussion
haha, shouldve gone with sidedraughts i reckon but if money is an issue or whatever then its definately unique -
yeah lets all undo bolts with our fingers!!
pull really hard and maybe hit the back of it with a soft hammer while you pull, u may need more than 1 person, its very well stuck on
somewhere around newton i think, i forgot
as long as the timing is right then theres really no damage it could do. maybe ford made their own dizzys in the 60's and changed to motorcraft when the escort came out...
i have a big artticle in a old classic ford that has everything about installing it and wiring it all up, too bad i dont have a scanner aye
Getting the Lead On Applying metal body fillers by Harold Pace Customizing with lead body filler was so popular in the 1950s that it gave us a new term, Lead Sled, to describe a radically customized sedan slathered and smoothed with the soft, pliable metal. Today the advent of high-quality, easily applied plastic (polyester) fillers has reduced the number of experienced lead workers to a minimum, but lead still has benefits other fillers do not. In fact, "lead" doesn't even have to be lead any more! What It Is Lead was the first popular body filler, used by auto factories and repair shops alike. It was melted into gaps and along seams, but if improperly applied it would crack and fall out just like the cheap plastic fillers of the 1960s. However, a good lead man was much in demand by premium body shops and customizers. The technical term for "lead" is "body solder." For auto bodywork, it is actually a mix of lead and tin, usually a 30-percent tin/70-percent lead alloy. This is different from solder used for electronic repairs, and the two are not interchangeable. Although handling lead-based body solder is not harmful, breathing lead dust is dangerous, so hand filing (instead of power grinding) and the use of a respirator is recommended. Even better, a number of companies are now selling body solders that substitute copper and zinc for lead (still combined with tin) to form safer filler materials. But why use lead at all? There are some instances where metal body fillers are better than plastic. Joints that are subject to stress and warping are more likely to crack plastic than metal (although lead is not a cure-all for improper engineering or assembly). And plastic easily cracks away from the thin edges of fenders or doors. Lead is also considered more appropriate for high-end repairs and restoration on collector cars. How It's Done Working with lead is simple, but like all crafts it requires continual practice to do it well. The basic materials can be bought in kit form or purchased separately. First, the metal area where the lead will be applied must be cleaned of all paint, corrosion, dirt and grease. A sanding disc or wire brush is used to work the metal until it is clean and bright. Next the area must be "tinned" to provide maximum adhesion for the lead. There are various tinning compounds, but most are in paste form. The area is heated using a torch (propane or acetylene) set for a soft, cool flame (a blue flame with no yellow is best). The tinning compound is then applied with an acid brush. The compound is heated until it melts and "tins" an area slightly larger than the repair area (to allow smoothing-in later). Now it's time to apply the lead. The torch is played over the surface to keep it warm while the lead, which is in round or square stick form, is touched to the area and the end heated as well. The solder will stick to the surface, and the stick is twisted to break it off. Lead is applied until there is enough to fill the work area. Experienced bodymen know not to overheat the panel, which can cause warping, so they stop and allow everything to cool from time to time. They use just enough heat to do the job, and work slowly. Once the lead is on the panel, it is kept just warm enough to maintain a semi-solid (plastic-like) state. Now it's time for a new tool, a wooden paddle to shape the lead (a combination of flat and round paddles allow for easier shaping). The paddles are dipped in tallow or beeswax to keep the lead from sticking to them. While the lead is soft, it is shaped and smoothed as close as possible to the final shape. Excess lead can be removed and reused if kept clean. Taking time to get the lead smooth will save finishing time later. The area is allowed to cool naturally (do not quench with water), and residue is removed with a scrub brush and water. Now it's time to finish out the repair. Vixen files are best for hand work (and ideal for beginners), but if you are using lead-free body solder and have lots of experience you can use a grinding wheel. Although professionals sometimes brag about not using any plastic filler, most of the time a small amount is needed to fill tiny pinholes and imperfections. If done properly, leaded repairs or customizing should last longer than those done with plastic fillers. However, if the surface is not cleaned properly it is possible for contaminants to get trapped in the lead and attack your paint job down the road. The importance of cleanliness cannot be overstressed. As with all such projects, practice on an old body panel before you turn the torch on your pride and joy!!
