Posts posted by Toucan
Looks good in red but they missed the tyres!
25% off at supercheap ATM, just picked up a new one for the boat
Here you go, pics are all dead unfortunately!
//oldschool.co.nz/index.php?/topic/19521-gazs-67-mk2-cortina-omg-an-update/
So I read on the internets there was such a thing called a colourtune, made by Gunson. Its a spark plug with a sight glass essentially which lets you see the colour of the flame. I was pretty interested so I had a play last night and made myself one.
Smashed all the porcelain and other innards out of an old plug. Taped over the top and poked a bit of wire through the tape that will be the new electrode, then mixed up some epoxy and filled it up to what I thought looked right. I let it cure overnight then put some heatshrink over the electrode and soldered the old plug top to the end. Just put it in one of my cylinders before and what do you know I can see the combustion. Pretty far out concept and I'm surprised I haven't heard of it before now.
Vid: http://tinypic.com/r/16i5q9/9
Only tested it for a tick, you can see the spark is arcing across the top a bit but I already have ideas on how I'd make version 2 better. Main problem now is I need to get a screw driver short enough to actually get under the carbs and adjust the pilot screws while it's running hah
Have a new set of correct plugs but smashed one of the old ones getting it out, watch this space etc
Yay for epiphany!
Still need to grab 4 matching plugs but I went for a hoon an did a plug chop just for interests sake, sooty!
Manual asks for 8's, the left there is a 7 and the right is a 6, so should be at a better starting point to tune once I have a matching set of correct plugs in there
Def keen to do a flatter seat and change up the rear end, I have an original tail fairing that might make its way on. Old superbike style.
Haven't really thought past that, just been focused on getting it running reliably for summer dorts.
Cheers for the offer I will keep in mind if I ever get stuck
Had some issues with it running on 3, so have had the coils off and cleaned up some more dodgy wiring there, all back together and running on all 4 again.
While I was trouble shooting I had the plugs out to clean them up and realised I have some 6's and 7's. Is it normal to have different heat ranges on an aircooled motor? I didn't take note of how they were before, but I put the hotter ones on the outside cylinders when I reinstalled them as I figure they get better cooling than the middle two
Also petcock rebuilt and refitted with a new gasket. Extended the fuel and vac lines to the tank as they were barely long enough before, lots easier to get the tank on and off now.
Thats mostly up to date. Starting and riding quite nicely now given I just threw the carbs together. The hard part now to fine tune them, fun fun!
Carb bodies didn't come up as mint as I had aimed for but good enough for now, soaked them in gun wash then ultrasonic bath in simple green & hot water.
Carbs back together, went up a size on the main jets, bench synced
And after heaps of waiting, exhaust arrived. Great look and sounds vastly better.
- 6
Before I left the UK I also picked up a Dyna S ignition so I could ditch the points.
Had to take 0.5mm off the top of the rotor to allow the mechanical advance to work, its all in and running now
Picked up a second hand reg/rec off a wrecked polaris, they are a series type and meant to fix the burnt out stator problems the shunt type causes on old bikes. Its physically huge but also one unit rather than seperate regulator and rectifier which I had before.
Made up a bracket and wired it in, added some fuses as there were none before. Seems to be charging still, win I hope
Still waiting for bits etc so polished the cam end covers on the drill press
Bought this sight unseen while I was still over in the UK, got it shipped to parents garage to await my return. Was keeping an eye out for next project and was stoked to find an early model GS with wire wheels, non cv carbs and a kick start.
Original auction photo
Fast forward a few months and I finally got to see it in the metal. It was obviously in worse condition than the pics showed, but I'd been craving something I could spend time tinkering with so it still fit the bill. Somewhere in its past life it has had the back end cut off and the seat modified, which wasn't done as tidily as I'd like, the side cover clips are all broken, the wiring was a mess, and to top it all off, the whole thing has been sprayed black with little to no prep work, so I have paint flaking off here there and everywhere whenever I touch it.
First things first I opened the headlight and fixed numerous bad connections and melted wiring
With a new battery, most things were working, still some trouble shooting to do here.Ripped the valve cover off and checked that the valve clearances were in spec.
Put some gas in the tank and fired her up without too much trouble, she didn't want to rev nicely but idled long enough for me to grab my helmet and so I took it for a quick ride down the end of the road and back, man was she loud! Time to take off the exhaust wrap and see what was hiding...
Many exhaust leaks! These aren't even all of them. I gave them a wire brush and took to a friends place to see if I could weld them up, but with the thin metal and my amateur welding the holes just kept on getting bigger. Next option...
Next up I wanted to get the carbs apart.
Gave them a bath in simple green and hot water to start with
Boom!
Took note of jets and whatnot as I stripped them, all looks standard
Borrowed mums jewellery ultrasonic cleaner, splash of vinegar and simple green with hot water did a good job on the brass bits
Before & after, only 5mins to get them clean. New set of orings installed thanks to cycleorings.com
Sat like this for a bit while I waited for overseas parts- 1
Aa plus... and partner gets half price
I did not know this, will investigate chur.
Been with AA plus 7 years and have had two tows and been happy with service both times
So good!
Gonna be busy in the pits!
Off the crane
I had one of these and the petrol/oil was mixing in the tank without my knowledge. Once I worked it out I blanked off the oil pump and put premix in the tank and she ran fine for then on. Was all stock mind you
Looks mean as with tank colour on it
Hoping for forward foot pegs for added clown riding position
Yea dumb, but put it all into the 65 and keep dieselling around
Yuh yuh, gotta be a manual for me. Like low kms and prefer something zippy too
This thread is relative to my interests, been browsing the tard lately and can't seem to find anything that tempts me. Feel like I sold the Civic and the Mrs Accord too cheaply two years ago cause equivalent cars are like twice the price today. Whoops!
fuel's smelly Magna
in Other Projects
Brown on brown on brown, I like it
