lowlancer
Posts posted by lowlancer
Yeah will be sweet as shit in summer.
Fire issue a kernt due to council needing consent for wood burners? Spose they will need specifics as well so retro-fit = problematic.
As a building industry profesh I say just install one and don't even tell them.
You needa insulate under the slab though right? Hmm
Stops large scale thermal bridging between slab and ground, along with polythene. Aka stops heat leaking out of slab into ground via conduction.
Dbh or whatever that sack of gays is called thesedays states minimum beers to fuss ratio must exceed 20:1 at all times follow chch earthquake
Is legislation and you cannot argue with that.
Also, freely admitting that I have not really read what others have said in full detail...
I don't know your district plan - you may be sweet to build a certain sized whatever with no issues - the soakholes were an indicator to me, however, that this is not the case!
Forget producer statements.
The reason I mentioned anything is because councils will require a list of LBPs (designer (shed company, engineer (shed company), builder (???), plumber, drainlayer etc etc before (often on the actual application form) they even bother allowing you to book inspections, and those LBPs generally produce some form of producer statement prior to CCC as evidence of their work being to a certain standard. The example I am thinking of here is whomever is performing the building work and whether they are LBPs themselves.
If the building work isn't done by a LBP, then you may have issues booking inspections/getting shit done. If I'm barking up the wrong tree then I'm glad!
Question cletus - on what grounds do you consider a low car unsafe? Presumably there are reports, studies etc? Or is it simply driving it on our shitty ass roads?
I am curious as to the actual real-world repercussions of having a super low car, as in, is there sufficient recorded evidence where a number off accidents are attributable in some form to the suspension of a car being unsuitable.I get this uneasy feeling of a blanket rule which as you rightly stated is garbage.
If it comes across as me having a go, I just wanna say I'm definitely not, I've just always been curious. -
height isnt the be all and end all...... He clearly states 20mm lower is on bumps and therefore would be a no go for cert.
The reason I said it, which in the context of this thread is quite obvious tbh, is that he is pursuing a certain style of which lowness is a huge part. He's made mention of shakotan before and of the fact he wants to go low. Couple that with the images he posted of guard gap I could fit my sizeable head (IRL not possible don't hold me to that) in made me think he was trolling a nigga, statement regarding legalities and bumps inclusive of trolling.
Boost some pics up. Been following this build silently with high hopes.
I'm calling bullshit, surely?
How high is that shiz -
Are you doing this with someone who is licensed/do you have someone signing/issuing PS4 the actual building stz off?
Is early stages
Will divulge once shit kicks off.
How much does it cost to engage an architect for house type thing?
How much you got?
Differs wildly. Impossible to say - house size, detailing, finish level, whether it's managed by you or them, etc
We just picked up a job doing a container house, cept it's like 48725792379 of them all smashed together.
Will use all the great information delivered in this thread by wildly unqualified persons to ensure the job goes smoothly. JUST FORKLIFT IT BOL
7
Smaller tyres look rad, but fuck that front guard is distracting. Any plans to paint this thang?
lol dat construction industry
Everyone in it, from design through to finishing are useless fucks in this country.
Keen for pics
Cut in half. Get dane to punch each half in place, just paint a cop face on each one. Then bog up joins.
fuck yeah architecture
5
Chuck some pantyhose on them g
No idea, will ask the joinery dudes tomorrow and report back on gas cost/sealing stz/penis sizes etc
I'm not a QS but you shouldn't be insulting Mike's profession - those in glasshouses and all
Anywho - trying to be helpful to Manu, so he doesnt have a panic and think he needs double glazing.
Still keen to know what awning roof is made from, clear or shaded?
wut. Shit me, always thought you were. Project manager of some sort? Or frame dweeb, or am I thinking of ryanfels there?
Shit son, those building industry ID problems -
Ooooooooo QS fight is brewing. Throw all the nails you're no doubt counting at each other pls
In SHGWAG's defence, from BRANZ
"For designers to show compliance using the schedule method ofNZS 4218: 2004 Energy efficiency – Small building envelope,they are now required to use double glazing in all the climate zones ofNew Zealand.Because the Building Code is a performance-based rather than aprescriptive code, the use of double glazing cannot be made a mandatoryrequirement, but its use is recommended as the most cost effective solutionto reduce heat loss through windows and the likelihood of condensationforming on the glass.Designers choosing not to use double glazing will need to prove thatthe single glazing complies with the Building Code through the calculationmethod or the modelling method of NZS 4218, or by using the BPImethod." -
Thermally, double glazing doesn't do that much tbh, we're talking an R value increase from 0.15 to 0.26. Real gains are had through argon filled/low E and thermally broken suites etc but even then, better spending the $$$ on better wall/roof/floor insul imo.
No it isn't shgwag. As long as the building performs to H1 you can use single glazing, depends on the method you you to achieve requirements, aka calculation, schedule etc
Common and erroneous belief.
Edit: sorry sound like a jerk there dogg
Board and batten inside? Interesting.
Have you done some form of H1 calculation for it? Aka thermal performance. Be keen to see how that shiz performs.
Get some old fagg at a dulux shop to mix you up some sweet lacquer using the facotry paint code. Assume you have a compressor so buy a gravity fed gun, mix in some turps/thinners, rough old paint up, clean with grease remover and boost in on nice and even until you use all the paint up. No need to be all fancy about it.
Is how I did it back in the day and ended up alright once I cut it back. -
Ship danger up to sort this out
Had a feeling I would see this post on here after reading in the Herald this morning. Hoped I wouldn't.
All the best in recovery of a sweet car, and congrats on reacting in the appropriate manner.-
my new wagon.
in Other Projects
lol^
Nice bargain. God it looks crisp
