Posts posted by Bearded Baldy
Car got relegated back outside so i could use shed to build a kids playhouse then mucked around with the ute a bit. Quad bike is next for a quick refurb before winter missions so car will be outside for a bit longer yet.
But i did a deal the other week for some spare glass. Now i have 3 spare rear screens, 2 spare sets of rear screen chrome, and 2 spare front door windows. Need to find a set of rear door glass then i will be happy. Ish.
Test drive report is a success.
Left wheel was grabbing slightly on the brakes so backed it off a touch and primo.
Rh side backing plate must have gotten a tweak on the way home and was catching on the drum when turning sharp. Drum off and found the highspot nice and shiny. Fixed via percussive maintenance.
Currently blocked in with wifes car so will test drive again tomorrow with gps to verify speedo.
Fingers crossed.
- 9
Big thanks @MaxPower, sorted me an lsd head from a gen 2 to play with. Quick measure up and they are interchangeable. Stripped it down, washed in old 2stroke mix, dried and now ready for reassembly with the 3.9 gears.
Like the sound of that idea. Will get this diff sorted then see what i do next.
Well shit, that escalated quickly.
Got it on the bench at work and took the axles out. Looked like relatively fresh grease on them, feel smooth enough too. But what can only be described as mud on the splines. Hmmm
Looked at the pinion trying to decide whether or not to spin it and ruin my day. Pinion bearing growly as the dog.
Pulled the head out and checked it over. Bit of wear and pitting on the teeth, all bearings rooted. Have it all stripped down waiting on a waterblast now. No rush as the first place to price bearings came in near 460 dollars which ain't happening this xmas.
Will let my fingers do the walking tomorrow.
- 5
- 5
Have been putting off doing anything to the utes for a long time, funds and inspiration are lacking. Pushed bluey onto the mowed part of the lawn tonight and lightly buffed the label on the diff. 3.909 ratio!
Will jack it up this week and pull the diff out, put it on the white ute and take it to work for the xmas break.
Be nice to work on things without interuptions. New axle bearings, brakes, and a rattlecan resto on the housing is the plan.
21 hours ago, cletus said:
79 is when rear belts became a requirement, so technically, you won't need them.
Good idea to fit them though, if the holes are there already.
Haven't looked for mounting points yet. Need another storage shed before i take the rest of it apart. Can't rush these jobs.
Cheers for the info.
1978 falcon. Never had rear seatbelts. If i was to cert for efi upgrade on the 6 cylinder, later diff with discs, aside from brake test and driveshaft hoop is there anything going to trip me up? Will i need to fit rear belts? Reg on hold not lapsed.
Recommendations for blasting and priming?
I need to take that out too.
17 minutes ago, yetchh said:
Baited breath to see what's going on up the front... Knowing falcons..
That is future baldies problem. Still trying to figure out where i am putting the bits i have taken off already.
Bumper is off. So is the towbar which won't be going back on.
Rear corner chrome trim came off with minimal surprises, on one scaly section out of 8 screwholes so pretty happy with that.
Tail lights are giving me arseholes, nuts are siezed onto the nolongercaptive studs. And all my vicegrips are at work....
Tail light panel.
- 5
Went through the boot today, found a few gaskets and other bits and pieces i had stashed over the years.
Removed the carpet and ran a screwstick around the seams before waving the vacuum around and looking for speedholes.
Worse than i thought but still not as bad as it could be. Yet.
Still need to remove lights and bumper to get a better idea.
Soaking all nuts and bolts with crc before i start that fight.
Bike spam thread
in General Bike Chat
Been offered an ag200 with no key and owner is pretty sure it ran before the bf lost the key.
Gotta be worth 50 bucks right?
