Posts posted by Vk304
Focus shifted to making engine bay look tidy, had couple hours free from kids and work, made a fitting for the crank ventilation valve as it was a bit of a messy look before, painted top covers, nissan white 2k and black, dabbed raised lettering with a sponge worked well and fits with black white theme , almost want to get a pplate with 'panda' on it lol
- 9
Nah awesome panelbeater did it for $50 so its passed wof now, he just welded it back up haha, yea i should habe made it look factory ... but i doubt it is 'structural damage', cheers for lsd option ive got welded 4.3 head and 4.1 open atm swapping them all the time sux but ive got it down to half hour exercise now haha
My muffler cracked all around and pretty much fell off after wiggling it.
so have started a twin pipe out the back, replacing the rudimentary 2.5 inch twin to 3 inch that i had, will now be twin 2.5 inch all the way, its tight but i think itll work
https://youtube.com/shorts/GDzSZxZ_5k8?feature=share
Couple more runs, 7 in total, just doesnt seems to go any faster with the mods i did, i suspect its gonna need drag slicks and ecu/turbo upgrade to push it faster
But im not gonna go there this time being its already aerodynamically challenged..., so this may be the last drags, still only on 11psi boost, but any more and it'll risk potentially damaging motor without some kind of ecu or wide band to keep A/F ratios in check soo yea
Good fun though and no sketchyness at all really, quite predictable and the drivetrain is solid
Lakewood slapper bars came in the mailfeaturing my toes, pants and little hands welded spacer on to clear shock/spring mount bracket and push it closer to spring eye, and trimmed exess plate off corners probably wont like speed bumps now but they are really only on there for drags, and are only clamped on springs so can remove pretty easily ... ready for another drag day hopefully with improved launch and overall speed
So i got rid of the simple and laggy bleed valve in favour of a new turbosmart boost tee, and i can say it made a huge difference ,this valve has a spring and ball type system that builds pressure keeping the gate shut untill it lets go and provides a lot more boost over the rev range, and comes in a lot harder, where as a simple bleed valve lets the waste gate open too early
And did a dump run , weighed in at 1280kg with me in it, ive since removed the spare wheel/housing and heavy towbar, and without me in it should be around a 1100 1120kg kerb weight now...
Planning to do another drag day soon
Then a deep clean and install some lightweight carpet in the back, install open diff head aand .... probably sell it after that to start a new project...
Some key differences with the 2 diffs, the original one is out of the 87 sgl vanette, its 3.88 ratio H190, i welded it to do drags, so thinking ill get another to be a spare for road use ..... i brought one off trademe
This new one is out of a 92 nissan largo diesel, is H190, same third member and bolts, 4.3 gears, thats when i realised its non compatible with my old one...
l wanted to keep the 4.3 gears for drags etc, so that meant swapping them onto the old welded centre, but they are a different offset aand carrier housing width so one complete centre couldnt fit in the other because 3mm wider on the bearing faces if that makes sense...
So housing/centres are not interchangeable, that sux, i had the idea then to 'unweld' the old one and swap spider gears/re-weld into the 4.3 centre.... so i did that and well the spiders, pin are all bigger in the new diff
f#ck, so i welded the new one together and now ive got a 4.3 welded diff, and some 3.88 spare parts lol
Ill try find another open diff as i need the 3.88 gears for road driving.
But all this means is i essentially upgraded to a stronger and better ratio nugget for drags... for 150$ ... not too bad
https://youtube.com/shorts/RDo5gtXzAkA?feature=share
My best run for the day
- 6
Super good day at drags, was my 1st day drag racing and first os event, and was a bit out of my depth at first ,.. but yea good to see people and talk to some, van had a lot of wheel hop but managed to limit that with soft launches at the end and got to 14.7.
Thanks to everyone at the track and making it a some what easy experience for a 1st timer lol
Next time maybe slightly more than 10 psi boost and a little rear suspension work...
Thanks again
- 16
VK304’s sr20det 88 vanette
in Projects and Build Ups
gonna tidy up radiator, basically everything as i know it all works well now
