Everything posted by Hurmeez
Bonnet holes and humps aren't really part of the look I'm going for, unfortunately. As much as the idea of winding 30psi into a stock block with no issues sounds appealing, the iron block is less so for me. Also, them revs! That said, check this out! It's going to be close but I think I can actually get away with it. I'll use the Mazda injectors and bung the throttle body injector port. I may have to flatten the very top of the front driver's side runner to stop it knocking when the mounts flex but other than that it should work.
I think I checked it that way but I just don't think I have the bonnet clearance. I suppose I could have a go with some flattened runners but to be honest I was a bit gutted and pushed it into the corner and felt sorry for myself for a bit. I must get back out there and have another look.
Everything you do is one less thing to do later on. That's what keeps me going mate
What a sweet gig!
Love it
Also what do you mean by "joints" being supplied? Surely that's not what I think it means?
That's interesting. The interwebs reckon the RX-8 box is 46 kg dry so that gives us a nominal weight of ~185 kg give or take. Compared to 31kg for the Type 9 gearbox, plus 135kg for a "fully dressed" pinto, gives a total of ~170kg. So ultimately they appear to be very similar. Theoretically anyway. Makes for an interesting thought experiment.
I just pulled the motor and box out for the next stage of work and yeah it was pretty heavy but I could still lift one end at a time unassisted. I'm really curious to know the weight difference. Maybe one of these days I'll sling the pinto and type 9 up on the hoist with a scale and compare the two. I'd say the iron block on the pinto should make it a fairly even match.
@yoeddynzI'd be embarrassed to tell you how many times I've watched the video of your first startup Alex just to keep myself on track. That and videos of MX3s with ITBs dorting in some kid's driveway. I can tell you I am so looking forward to hearing it zing up that high. I might take you up on that offer of your maps too. I was originally going to go ITBs, even got so far as importing a set of BMW ones from Germany, but it turns out with the space that I have and my now somewhat reduced budget due to the said unusable ITBs, your style of manifold is my only real option. @d.p.n.s It's a sickness for sure!
Preaching to the choir there mate. I often think about how many kms I could have already done if I'd just stuck with the Pinto and thrown a lumpy cam in it. May have even driven the car to school before I left. Instead, here I am still bashing my head against an alloy v6 that barely fits. But hey, if I wanted it to be easy I could have bought a finished one in the first place, and where's the fun in that?
Ah, gotcha I was thinking of something different then. I was thinking this: And you were meaning this right? The CalTracs are basically the same as what you've got but with a bell crank that pushes down on the part of the spring that is bending up during the wrap, rather than a free-swinging arm slapping away. The crank pivots around the front spring mount and gives you the advantages of both looking cooler (in my opinion), and eliminating the noise and fatigue of having the bar hitting the underside of the spring. I might use a spare set of spring hangers to begin with, and make a temporary setup like you said to see if I'm willing to put up with it, before possibly going to a full-on CalTrac style setup later on.
Really? Is that all it takes? I've read that tramp bars only really increase the frequency of the tramping rather than getting rid of it properly but I suppose you'd know far more about it than me. I have been looking into a CalTrac style of thing though. They look like a good bolt-on solution without many drawbacks other than the fact that I'd have to build my own version because they don't make one for an Escort. I feel like if I was going to go to the effort of putting in anti tramp bars then I might as well go the whole hog and four link it with fairly short top arms.
From what I've read it's a perfectly workable suspension design for the street or light driving but where it tends to fall down is hard launches and burnouts etc. Because of the way the axle wants to twist under acceleration it will be lifted up into the belly of the car and away from the road surface. This means you'll lose traction and potentially still have axle tramp/wheel hop when you drop the clutch, both things I was trying to get rid of by thinking about a link system in the first place. So all in all, it works, it's just not worth the effort for what I'd get in my application in my opinion.
Yeah those stickers are pretty hardcore aye. Every single one we stuck on my old man's Escort pulled the original paint off down to the primer. Pit of a pisser really. Had great fun on the drive though!
So I said it should be sweet. Was I fuckin right or what?! I started by making each face of the new wing in separate pieces of steel and tacking them together. There was a time when I would have tried to fold it all out of one piece but it was much easier to do it this way. With it all tacked up, I snapped it off the pedal box and welded it fully. Then tacked it up again and welded it to the box properly. Then I marked and drilled the appropriate holes to mount up the master. The bottom bolt is a bit of a pig to get in and out because it ended up right on the wall of the original pedal box. Eventually, I think I'll swap it for the studs that the master originally had but shorten them a little and run a nut on the inside of the pedal box. Should make the whole situation a lot easier to mount. Finally, here is the pedal at clutch fully out, And fully in. Next I knocked together this little fella, And filled up the old clutch cable connection point. Their powers combined they make this: A neat little adjustable pedal stop with a rubber button from the original Mazda pedal. Much better than putting a nut and bolt through the floor like I've seen suggested on some pages online. With that, the pedal box modifications are finished (at least in the clutch department anyway). Now I just have to get on to mounting it. To start, I ground off the return on the doubler plate and clutch cable conduit where it would foul the new wing. Then I made an extension for the doubler plate and welded it on. Finally, I had to drill and cut the holes to allow the master cylinder to penetrate the firewall. It just so happened that the center of the main hole was inside the clutch conduit hole so a hole saw would have made a terrible mess wandering around everywhere trying to cut the hole. Instead, I bolted up the pedal box and used it as a template to make the two smaller bolt holes. Then I made a temporary support for the hole saw and bolted it to the bulkhead with the new holes. Which let me cut it out from the other side. I might weld up the oval parts of the original penetration but it works fine as it is for now. As tempted as I was to bolt the pedal box and master cylinder straight up, I figured I'd get a little more fab done in the area while I was here. So I made up this little guy, And tacked it in place on the firewall. I also threw the pedal box and master on while I was there, Before mounting this sweet piece of kit. It's a leftover from my old man's roadster when he mistakenly ordered the wrong kit for his braking system. I reckon it fits really nicely in there and I'll only need a short 90-degree elbow to connect it up. The whole thing came out looking kick ass and I'm really happy with the result. It's going to be fantastic when it's finished and running. I'm just leaving the mounting pedestal tacked on there for now until I find a brake master cylinder that will work in case I need to shift it to make it fit. That leads me to a request for help. What brake master cylinder should I use? Bearing in mind I plan to use princess four-piston calipers on the front and I'm not sure exactly what on the rear yet. I am going to use the R31 skyline diff that I have but I'm not sure what brakes to use on it. I don't have any for it yet and I'm looking at probable disks of some sort but I'm not sure which and I'm open to suggestions. I'm looking at a Datsun B310 master right now because it's the same bore as a standard Mk2 Escort master but it has the under and over mounting holes. I'll have to run a remote booster but that won't be an issue. My only concern is whether or not it would be compatible with disk brakes in the rear due to its internal residual pressure valve. I'm open to suggestions if you have any. Please let me know here:
As far as I know you are allowed to weld the pad on just nothing on the arm itself. I think the idea is that if the pad breaks off you can still push on the arm somewhat, but if the whole arm snaps or bends then you and all 50 of your horsepowers go a screaming 30kmh up the ass of a particularly grumpy Kev at the lights in his lifted Colorado.
Yeah I'm aware of the whole "no welding brake pedals" deal but I'm not too worried about the clutch pedal. I haven't even looked at the brake pedal yet.
It did only end up taking a few hours but finding the few hours took a while. Never mind though. Started with the cardboard as per usual then moved on to the steel. As a bit of a side note, this is what happens when you use the wrong tip on the Rivnut gun without realising. After they were all done I welded them on and mounted the rad properly for the first time. It's solid as a rock now. I'm really happy with how it turned out. With that done, the front panels are almost all fabbed up. I still want to modify my original replacement radiator mount panels to tie the slam panel down a bit more solidly. I'll cut them somewhere along these lines and fold up a flange to give them a bit more strength then weld them between the inner wing and slam panel. I would have done them next but I wanted a break from the panel work and I've been wanting to have a go at the clutch system for a while now. So that's what I did. I bought a second-hand clutch pedal assembly from a wrecked RX-8 with the plan of essentially replicating it with the standard Escort pedal. This is the Mazda pedal on the left and the Escort on the right. You can see that with the pivot points in similar positions the pedals are actually fairly similar in length and shape. You can also see the pushrod, clevice, and pin that the Mazda uses to activate the master cylinder. This is somewhat different to the cable that the Escort uses but I think I can make something work. I started by assembling this assortment of bits: Which come together to make this: I fully welded the bracket and turned up a quick bronze bushing to take the clevis pin. It comes in handy having a bunch of Grandad's old boat building bolt stock around sometimes. This should last much better than the crappy plastic bush that was in the original Mazda pedal and remove a lot of the slop that was present. Then I welded everything together and cleaned it up. You can also just barely see the bush that I tapped in there. Finally, I assembled everything and had a look at how it was going to turn out. It turned out mint actually. I'm fizzing about how well I managed to pull it off. I threw the pedal back onto the box and mocked up the master cylinder in about the spot it looked like it wanted to be. It turned out that it would end up about 20mm further from the pedal than it would have in the Mazda so I extended the pushrod by 20mm. The rod I used was a little larger diameter than the original but it works fine. This is at full engagement: And full disengagement: I made a cardboard template for an extension to the pedal box that would mount the master cylinder You can see how close it's going to end up to the brake tower mounts. This won't be an issue though because the brake tower won't fit anyway. With the exhaust system and the radiator set further back than factory, it never stood a chance. My plan right now is to find a brake master cylinder that has essentially the same internals but has under and over mounting bolts. That way there'll be shitloads of clearance between the two. Then I'll put a remote booster under the dash or inside the inner wing or something. The plan for tomorrow is to turn the template into steel and start modifying the firewall to take the new pedal box layout. Should be sweet.
After having a proper look at the rad I was starting to worry that maybe it would turn out to be too big and I was starting to consider a chin spoiler to cover up the rad poking through the front valence. I started pricing one up and found that it would be $250 for a brand new fiberglass repro or the same for a slightly sad original rubber one. Then I thought, why spend $250 to fit a $65 part when I could find a rad that fits more easily for another $65 and spend less than half the money even with the wasted radiator. Before I wrote it off though, I checked the fit one more time and with a bit more fiddling I saw that I'd be able to make it work. It'd be tight, but it would work. So I set to and made a CAD template. This shows just how tight I have to make it with the cutout to get around the bottom hose inlet. Then I transferred the template to steel and started forming everything. I opted to use 2mm plate for doubler plates for the captive nuts behind the ARB mount brackets. Ultimately I probably should have just welded the corners and done a few stitches because the warping that I got was a bit more than I would have liked, even with moving the heat around and not letting any one area getting too hot. Then it was the captive nuts. Then I had to try to fold it without using the brake because it was too long. In hindsight, I should have made it in two pieces and welded it in the middle but I didn't think of that at the time. I made it work in the end anyway. The first mockup went pretty well. It fits in the gap anyway. Next, I had to make the cutout for the bottom hose. Holesaw: Grinder: Paper: Steel: Somewhere along the line someone messed up a measurement and the inlet was touching on the cutout so I smeared some neverseez around to act as a transfer medium to tell me where it was touching. It ended up being a fairly drastic adjustment with the bottom of the cutout moving down about 10mm before I was done. Unfortunately, I was head down bum up determined to make it work so I didn't take any photos but rest assured I made it fit. I also made up some pieces to locates the factory rubber mounts after modifying them to be far lower profile. I wasn't completely happy with the clearance between the cross member and the rad. It would probably end up with the core touching once it was properly mounted and that wasn't something I was going to be ok with. I sat and thought and tried to figure something out but ultimately I had to slice along the length of the top and narrow it by 5mm. The result left me much happier with the gap. There's approximately 10mm clearance at the closest point between the core and the cross member now. With that pretty well sorted, I had a look at the brace that would have run vertically between the slam panel and the original radiator support panel. To my surprise, there was actually a good amount of room to work with. I was planning on modifying this piece to just come forward and weld to the valence. Now though, I realised I could put another cross brace between the inner wings to make up for the panel I took out. So, cardboard: (I reused the template from before, hence the cutout) And then steel: With that done, the next job would be to make the top mounts for the rad. To do that though I'd need to put together my nice new slam panel to have something to build to. And that's where I got up to. It shouldn't take long to make up some small upstands to pick up the original rubber mounts so I'll try to get that done tomorrow. As far as my rear suspension idea goes, I found out why I haven't really seen it used anywhere else, despite how simple it looks to me. It turns out there are some dynamic aspects that I hadn't considered, all explained extremely well by this website: http://www.trucktrend.com/how-to/chassis-suspension/0804st-rear-suspension-design/ I'll save you the whole read and paste the part relevant to me. So I guess that means I won't be doing that. I think for now I'll probably stick with the standard style rear suspension and be gentle on the clutch unless the road's wet.
I see what you mean. My setup would basically be the same as yours other than having two top bars rather than your single one. Regarding the Watt's link versus the Panhard bar, we learned it physics at school last year that when you're describing an arc of 10 degrees or less then the line is so close to it that it can be mathematically considered a straight line. If the Panhard rod is 700mm, which would be about right for the axle width, with a 125mm suspension travel, which would be about what I'm looking at, then using some trigonometry I can work out that the arc described by the Panhard would be 10.2 degrees. That also means the total deflection of the axle will be 3mm maximum over the whole travel. Ultimately there is far more than 3mm of deflection in the sidewall of the tires during heavy cornering so I think that the added complication of the Watt's link over the Panhard isn't actually worth the relatively minute amount of deflection it might avoid, so if I do go down the four-link route I think the Panhard bar is the best option. It makes sense in an application with more travel, like in a lifted 4WD, to use the Watt's link because the deflection would increase an awful lot, but I don't think the relatively small travel of a lowered road car like mine warrants it. All that said though I might have completely missed something so feel free to correct anything I might have cocked up.
It's just printer paper so I'm not too worried
I made a trip to the wreckers for a browse, looking for a center section for my diff and other miscellaneous stuff and took a tape measure with me. Using that I managed to find this: This just so happens to be the largest radiator I could possibly fit. It has about 5mm clearance on either inner wing. As you can see I'll need to completely re-engineer the radiator support/anti-roll bar mount cross member and the side panels, and the radiator hose will have to do a couple of tight turns to get around the anti-roll bar as well but other than that it's pretty much perfect. It has no radiator cap in the top tank, just like the original rad out of the Mazda, the bottom inlet is on the correct side, it is thicker than the original Mazda and compared to the original Escort rad, It probably has twice the effective area. So the combination of size and the modern design means that with a couple of fans there should be no way in hell that I'll overheat it at all. I would be absolutely astounded if anyone is able to tell me what it came out of. In fact, I would bet money that you couldn't guess. Additionally, I've been knocking some suspension ideas around in my head. Being young and dumb and full of the proverbial, I know there'll be the occasion where I want to make a speedy exit of an intersection or leave a traffic light hard or something. I've seen people try this on leaf springs and the axle tramp that results is often quite embarrassing. Now I'm no stranger to embarrassment but I do prefer to avoid it if possible, along with the hammering that the axles get when the occasion arises. So ideally to avoid this I'd need a four-link of some description. Yes, I'm aware that anti tramp bars exist but from what I've seen and read, they're not really that effective and the effort to go from installing them versus a full four-link isn't a huge leap. But then my annoying requirements come in and complicating everything. I really like the idea of the car looking fairly bog standard from the outside and retaining as much factory functionality as possible without sacrificing any for the upgrades. Specifically, in this case, the folding rear seat. In Escort estates, as with most station wagons, the rear seat lifts the base up and forward and lays the back down in its place to form a larger cargo area. If I was to use standard four-link boxes they would end up in the same place at the seat base. Even if I used the earlier style with shorter arms, they would still intrude too far into the cabin to allow the standard rear seat functionality and so according to my requirements, they're out too. For a while, I was stumped. Then I thought, why not use the raised rear floor to my advantage? Who says I can't send the top arm backward instead of forward? So I made a quick little scale mockup to see if it could work. I end up with about 75mm bump and 50mm droop with very minimal axle deflection at either extreme of travel. This being so small scale it's difficult to rely on the accuracy but I ran the numbers through my old physics workbooks from last year and the Watt's link type off effect shouldn't cause the axle to twist significantly over this sort of travel distance so the driveshaft angles shouldn't be a factor to worry about. This GIF shows a mock-up driveshaft to illustrate this. I'd probably use standard style turrets set back far enough to not affect the latching mechanism of the seat and a typical Panhard rod or Watt's link for the lateral location. This is all just ideas at the moment. I'm interested in your guy's opinions. Let me know what you think here:
Yeah love the turbos! They're such a neat old mag and yet I've seen more on trailers around town than cars!
After degreasing the engine three times, I threw it up on the stand and set about swapping the sump over. This is what I found when taking the original sump off: So I swapped on the windage tray from the other engine on. I had already modified it to fit the new sump. It's a lot of material removed but the new shape of the sump acts as something of a windage tray anyway so I'm not too worried about it causing any issues. In any case I'll have my eyes glued to the pressure gauge for the first few miles anyway so should there be an issue I'm sure I'll catch it. So then we have a sump on, And an engine in a car. It could definitely come down by 30mm or so but it's awesome to see it sitting on its feet again. Now I've seen it though I need to lift it back up and pull it apart again to get some more work done. I'm not really sure where I'll go now but I'll figure something out.
I was originally looking at a Link but seeing as I'm looking at being a poverty-stricken student next year I'm starting to like the sound of a Megasquirt more and more. I'm sure you'll be one of the first to know whichever way I decide to go though.
