Posts posted by Transom
Had a spewpercheap auto darken helmet didn't last was crap
bought a 99$ one from a welding supplies guy on trademe in Nelson works good for price has grind setting and was in faux carbon cos it's hard to find one without some horrendous graphics these days
10/10 would trade again
I have been looking for the same size
does it need the bead rolled onto it to hold rad hose properly ?
Bunnings do alloy tubes and angles in 1m or 3m sticks not sure if they do tube up to 35mm?
yes Aliex has the joiners cheap as
so this just passed the 1 year in the shed mark
and i have been plugging away at small things trying to make sure it all fits
made a cut down sump using the bowl of another sump ... it was ugly welding and looked too small on capacity and leaked like a sieve
so i made mk II version deeper and with new 2mm steel much easier to deal with made 1 flat plate right thru at cut line and then made the cutout and bowl for ford v8 pickup
very minor weeps on testing and i just hit it with the full POR tank sealer system to sort that out
oil filter remote and oil cooler mounted and plumbing mocked up
lots of little bits to sort so they dont try to occupy the same space under the bonnet
3
Also if if was sold as another name/ brand in the USA then check the listings for that model on rockauto
were mitzis sold as dodge or something over there?
No you buy the correct o2 sensor and tps from aliexpress china using the original part # to search and identify them then you get the correct sensor with the right range and factory plugs etc
my $300 O2 sensor that was $150 on eBay was $40 on aliexpress
Aliexpress for cheap 02 sensors and tps
find the oem part number and search using that - cheap just takes a week or 2 to get here
4 hours ago, cletus said:
Clamped to the floor, and vented to outside passenger compartment, either via a sealed box vented outside, or use the vent holes with a tube to outside, like oe on a lot of euro cars. Cable needs to be secured and not sit on sharp edges,and if it's not in a box I would suggest something over the terminals to prevent ergs escaping in a violent manner
Would a fully sealed agm style battery pass without sealed box ? (Mx5 battery in boot stock not sealed from cabin)
That front wheel does not look very rusty ?
And what's that in the photo? Blue sky - can't be Westport
Dereg =new cert sorry
How many abs systems have to be plugged into a dealer computer to cycle the abs system while bleeding ?
A few I have heard of
For alloy - cheap oven cleaner in the can spray
DO NOT leave it to sit too long.
rinse off with water Scrub brush on the stubborn bits and rinse the hell out of it with water or it will etch into the alloy
toxic as hell -outdoor use only -catch the runoff and kill gorse with it or something
will also remove anodising from alloy
Cig weld 135 has 5 position amp setting and variable wire speed -300-350 bucks supercheap or Bunnings on special was the best cheap option when I bought -didn't really want a hwa fong unknown no parts available brand and they were dearer anyway
cheap arc around 100$ these days
spend much more than that and you may as well go to coupla grand plus multi do everything machine
if you are learning then avoid stick/arc it will be frustrating as on thin steel
budget on a good auto-darken helmet too
cheaper to get someone else to weld your exhaust but once you have a welder there is so much you can do/fix /make learn
I have done lots of 1.2 mm steel tubing with arc
spot s only is the way -don't try to run a bead
actually found thicker rods better -more filler and more heat going back into the rod
If you can take the exhaust right off the car it's doable all downhill is easier
new arc sets are so cheap now but cig weld gas/gasless mig from super heap for $350 on special quite often
3 grinders - 1 for flap disc
I wish I had room for 3 drillpress
anyway nice workshop show us more please
Ah that makes complete sense
Looks pro
need red paint on your drillpress filing cabinets too
drill mill and 2x drills ? Why the 2x drillpress ? Different setup or just cos?
Old mini 4" is 101.6 mm
old small ford is 108 wtf is 103?
Ok so since I'm about to buy a new clutch too ...
What would you use to remove surface rust/glazing/oil residue off a steel flywheel without getting it ground?
Wet and dry with brakekleen?
4 hours ago, yoeddynz said:
In other news... I just delivered this J3 to Motueka from Marahau. Second gear, just, up over the Riwaka hill. The tappet cover started pissing out oil over the exhaust manifold and smoking me out from the cab, my double de-clutching skills needed lots of testing and down the other side I didn't know how the brakes were faring but they certainly got hot. It was missing from the word go and got worse, hopefully just the points closing up. Yep it was a mighty 214 consuming vast quantities of petrol and not going very fast. The fella who has bought it has never driven a truck before and has to drive it over the mother hill to Takaka.
Rather not be him.....
Nice looking though.
Fuck driving old trucks on takaka hill with no brakes
if it's just going there to park up and die then convince him to AFrame or straight bar tow it behind something modern and huge
4
7 hours ago, NickJ said:
I used 5 min epoxy for a leak, little bit of fibreglass mat to bridge the gap, held on for over a year until I got around to fix it, just got to get it clean I guess was the trick
I hit it with the zapper some more -down to a couple of weeps no drips but the steel is getting too thin to grind back more
looking at the por 15 sealing system and cleaners to seal inside and out
So I almost built a sump from 2 sumps and some sheet metal
a passing seagull shat on it to hold it together -pictures coming to design disasters thread soon
got a few pinholes I am sick of chasing - what's a good gooey solution to paint inside and out to help it hold oil???
Really strangely - Yes preselect gear you want then press clutch right to the deck within 20 seconds
gear is indicated on the dash and shows what you have preselected to goto next
gear lever is like a holepunch - even makes the same noise - big lever forward and back gives you half a gear up and down - little lever on the front of it gives whole gear up or down if you do 2 clicks
sometimes when changing down for a corner etc it seems to throw a dice and give ya whatever gear it feels like - usually not the one you wanted
worst part is the hold clutch right down til it clicks - seems unnatural after driving RR boxes with clutch brake at the bottom of clutch stroke (never push clutch right down when moving or you do damage to the clutch brake)
and there is no room or dead pedal to rest your left leg on - its hard up against engine cover no room to stretch
would rather have this ....
that seagull outboard really needs to go onto a boat made from an old car bonnet for max OS car points - have seen a boat made from a table up there
usually a very fun weekend may come up for a cruise as its almost not really halfway to here
I need a new welding helmet
in Tech Talk
All the reading I have done about arc eye and auto darken helmets suggests that you won't get arc eye thru the lens even if the auto darken is not working
not that keen to test it out too much myself but I did google the hell out of the subject when my cheapy helmet was cutting in and out
any welding professionals wanna enlighten or endarken us more about that?
