Triumph2000
New Members
Everything posted by Triumph2000
  1. a few more pics from last night https://www.facebook.com/media/set/?set=a.548665301948203.1073741834.403215843159817&type=3
  2. Hey guys recently moved back to Auckland. I'll try my best to make it to this meet with my old girl. I will bring my cam as well and take a few pics.
  3. Hi, yes it is. Im trying to figure out how to add images haha
  4. Hi guys, sorry for the late reply been a lot busy. I replaced the Voltage regulator last week and since then there is no problem at all. The amp and everything else works fine. I found a new regulator for $16 and installed it and everything works fine now. Thanks a lot guys
  5. yeah amp shuts down and then voltage spike. But I dont think the amp doesn't hit thermal overload because sometimes it happens a couple of minutes after engine start up, it cant get that hot in a couple of minutes. Anyway to check this is the problem for sure. cheers
  6. Yeah thats right, the battery connection is fine and so are the connections to the alternator. The sub/amp red wire from the battery does not have a inline fuse with it just after the battery but she has been working fine without it. Does the inline fuse work as a check valve
  7. Yeah it could be but im trying to find away to make sure it is the amp, any suggestions
  8. Hi guys, I have a Triumph 2000 that has a Lucas ACR15 Alternator on it. Sometimes it spikes the voltage upto 15v+ and the subwoofer cuts off because I'm guessing to save itself and all the lights brighten up, after a few minutes everything goes back to normal and the sub works fine. But recently I had to change a few bulbs because they couldn't handle the voltage. Is it the voltage regulator thats causing this? I saw in a few other forums that if the battery is always dead due to not charging its definitely the regulator but in my case the battery is always charged and fine. Any help would be awesome. Cheers
