macwood
New Members
Everything posted by macwood
  1. I have one of these chassis under a glass 33 ford coupe body. To clean up the front end, I took the control rods (which run forward from the lower suspension arms to the front x member) and swapped them left to right, flipping them upside down. That way they point down, rather than up. Then I cut the front of the chassis off just in front of the front suspension and made two frame horns out of 3mm plate and 50x3mm flat. I welded them on with a pipe between and now the hole thing looks a bit like the front of a model A or 32 ford chassis. Sorry, had the engineer make mounts with rubber/steel bushes going across ways that screw onto the flipped over control rods and welded tags under the front pipe to mount them. Sounds like a lot of work but when you see it, its not that difficult and makes the front end look that much better. I actually mounted the swaybar underneath also. (flipped over also). PS after doing this I found it all works well but the front end was still to high. I cut 1 complete coil off the front coil springs (not with the gas axe) With that done, the original shocks still hold the spring tight as required. I am running 3l turbo diesel gear in this car and wanted 5 stud front end to match the 5 stud toyota rear. I got L300 discs and put them on, but make sure the discs are the same ie vented / non vented. Hope this helps. Watching with interest. Macwood
