Posts posted by 120why
The sill was replaced and a new B pillar by Wildman Custom metal. Spear doors from my collection of bits were used
Hours spent wire wheeling running gear and suspension components. Rust killed, prepsoled and the painted in the booth by us
Engine stripped and taken to Regal Automotive in Tauranga for reconditioning
Discussion for my sisters project
Project thread:
Some before images, this was around 3/4 years ago.
Car was sitting with a ministocker ready to have the running gear taken, the lady who owned it before managed to T-bone it though a roundabout. Luckily this just bend the B pillar and the doors.
Out came the engine and running gear, into the rust. Sister was on the wire wheel doing the dirty work
So this would be my sister Jessie's car, a family project which we are restoring to its former glory.
Rather a lot of work, ill let the pictures do the talking
Discussion:
Hows this going? Also looking at this mod for my h165
Long time no update. Family has shifted back to Katikati in the BoP so havent had much time with the car as im still in welly studying at uni. But cars been running well, I have been mucking round with the jetting and adjustments when I come up on breaks. On a trip to Auckland I managed to break one of the diaphragm pump shafts which link the throttle arm to the diaphragm, had to limp it home for 2 hours.
So a new one of those went in and also some new rubber gaskets which have made such a difference - old ones were flogged.
Been to Pauanui, the mount and rotorua, hasnt been doing as much travelling with me being away so gets locked under cover in the shed
- 6
At the NZ Datsun Nationals in Oakune my mechanical fuel pump shat itself while driving up the mountain. The metal plate which holds the diagram was rusted out and not working as it should have. hmmm 40 odd year old pump, had done around 38,000kms with me with no issues. With the A14 being bigger than the A12, the carbs we running out of gas at high RPM for a while. Heading up hills at 5000 rpm it would start to stuggle.
So I purchased a small Facet cube 7psi pump, Edelbrock 1-4 psi regulator plus all the fittings/fuel line/clamps/thread sealant. Also got an Edelbrock 1-4psi Regulator.
Mounted the pump on a large rubber block, I installed it upside down above the tank with a filter before. Tucked away and stays quiet. Wired it in through a relay from the ignition and battery.
Set the regulator to 2.8PSI for the dellortos.Working much better now and I can rev at 5k for as long as I want
- 5
Been busy over the last few months
A12 out and A14 in!
Ended up building a fresh A14
9.8:1 Compression (pistons flycut)
Cam with 2500rpm-6500rpm range
9.4kg Flywheel (2kg lighter than standard)
Firmer Kelford valve springs
Ported and polished head & manifold to my ability
Twin 40mm dellortos & extractorsNew alloy radiator on its way, also have to install the e15 electronic dizzy at some point down the track.
Here is a quick video of a small test start with single carb when I first installed the engine...
Pics following
Pistons flycut for clearance
H89 head, water jackets tapped and grub screw inserted. Also drilled a small hole to locate a roll pin from the dellorto manifold to keep it alinged
Discussion
- 15
This car still around?
Nice build love the old Datsuns. Had a worked a12 and it went pretty well for what it was.
That chin spoiler looks good where did you get it from? Looking for something similar
Cheers! Yeah I have been tossing up whether to work thevery a12 or the a14. I have decided with the a14.
Chinspoiler came off trademe about a year ago, they are for a mk1 golf. They come in two pieces and you have to trim the center down to fit it to a datto. I haven't seen one for sale in a while, paid about 140ish plus shipping from memory
sounds cool. what have ya done with the fuelling side of things? sealing of carbs, pressure reg etc?
Also keen to know! also how have you fabbed the exhaust manifold? This thing is where its at!
I like this thing, a lot!
Anyone know anybody who is worth while taking my b210 to?
Not much of an update... but the y is running sweet just clicked over 23 thousand km's in since march last year.
Gave her a full service including gbox oil, will be getting a wheel alignment soon so i can get the 15x8's back on!
Went for a loop drive from Wairarapa to Kapiti coast then back over the Rimutaka hill (400 odd KM). Went happily with no trouble.
Welded an extra muffler on in the morning to keep the girlfriend happy. Have been working on my sisters 120y as well, rust cuts underway.
Classic dat with rising sun. lol.
//oldschool.co.nz/index.php?/topic/48815-120whys-75-datsun-120y/#entry1646709
- 7
Cheers guys, yeah ditched them, too much!
120why's Other Datsun y
in Projects and Build Ups
Some rustees would be good for this bumper
[/url
