Posts posted by PedRac3r
Not sure if you can buy just the rear housing, but it comes when you buy the water pump. Cant remember exact figures but $100-140 seems right. Cant get the head outlet from Toyota any more!
This thing is badass! Definitely worth robbing the 4AG from the Trueno haha. Maybe just take this skidding instead?
Cheers guys. Have done a few track days in it (fixing shit in between days haha), but I should probably drive it more often!
Replaced the rear wheel studs with some longer items after the orginal ones had been crudely hacked off for wheel spacers. It had these eyesore rear caliper mounts on it, so fabricated up some cleaner mounts to replace the previous ones, pictures say why... Gave the calipers a good clean and some paint too.
Ordered some new outer shells for my front wheels. Set the wheel up in the lathe on a jig I made. Here is the wheel which I had just finished parting the outer shell off. Makes it a lot easier when your doing a few when you have a jig, rather than clocking each one up in the 4 jaw chuck.
Shells were ordered from Gavin Bateman. I had to drill 6 extra holes to make them 12 bolt, like I did for the rears. The spacing between the standard 6 bolt is just too far, when I was seating tires on the rears for the first time after widening them the pressure (took 80psi to seat...) was enough to deform the lip around the bolts.
Wheels all done with some fresh rubber.
Speaking of wheels, I had bought a pair of 6.5j SSR Starsharks, in fairly good nick too!
Put a G1 Link in it, in hopes for some more power and for future purposes, made a ridiculously high power figure, 180.1kw, oh no sorry its only 80.1...
But still (just) enough for skids. Thanks to Kris (kpr) for the video and pictures
http://www.youtube.com/watch?feature=player_embedded&v=9VtLrnRg5GI
- 9
Ive also used Gavin, have got about 14 shells from him now and have been satisfied with the work. Last order I did with him was for four 4" wide 14" dia shells, all polished at $260 a piece (I split the wheels, and drilled the PCD).
Looking at the front of the wheel it would be pretty easy to make those wheels 2 piece, bolt on a outer shell to get the width you want, only problem with that is you cant select the offset you want.
Carrying on from my last post. Engine back in after all the suspension done
Dusty photo of it all back together
My mate Goob and I made a new exhaust, to get a bit more ground clearance.TIG'd a section of stainless pipe on the end of it
My mate Graeme doing a bit of welding on the new collector section off the headers
Ended up being stupid loud and sounded just as shit, so put a reso in and that helped, sorta
Did a few drift days, ended up stacking it at Meremere after the fuel pump stopped working mid drift.
Pulled a little to the right after that... Ended up bending a few bits, like the LCA bent from the gusset outSteering rack, cracked the housing and bent the rack
And chassis
Figured this would be a good time to improve a few things, so I begun the search for all the parts I needed to get it rolling again. Was luckily enough to find 2 AE86 manual racks. A mint guard which was absolutely rust free and most importantly unmolested. Picked up 2 KE30 LCA's which are 10mm longer than AE86 stuff and off to the panel beaters it went. Took it to West Coast Panel and they did an excellent job! Did more than I asked them to do and for a good price. They straightened and repaired the chassis rail, lower rad support and fixed the bent edge on the bonnet. These few weeks were pretty hectic so I didnt get alot of photos unfortunately.
So here is the rail after a bit of paint
Everything back in now, new rebuilt steering rack, tie rods, ball joints etcMade up some small alloy braces in an attempt to strengthen the chassis rail where the subframe bolts through. Battery tray now removed also
New guard.
Got the engine back in again. Bought a new RWD water pump from Toyota which has the proper thermostat housing on the back of it. RWD water pump pulley, top water neck and alternator bracket now also fitted. Picked up a new radiator too. Was sick of trying to find a quality alloy radiator, so I got this dual core Racing Gear radiator made by Koyo
Bought a new front lip to go on the new front bumper, got a duck bill at the same time all from Mike Shaw. His fibreglass work is pretty good! Took it down to Meremere again, car ran perfectly.
It was then time to sort out the engine bay, out came the engine and started working on pulling anything else out that I could to tidy up.
Subframe and steering rack, both looking pretty tired.
LCA’s and castor arm/sway bar mounts, looks like theres more surface rust than paint there… Took them to work to gusset and bead blast them back to new.
Now that all the suspension was out of the way I was able to paint the front inner guards with POR15 like the rear.
Front castor arm/sway bar brackets done. TIG’d a couple stitch welds to keep it all together.
Lower control arms have been gusseted and bead blasted too
Subframe and rack got the same treatment
Pulled the master cylinder apart, bead blasted it and put it back together. Bought a new clutch master as that was leaking down the firewall, added a braided clutch line to replace the roller coaster inspired hardline/softline.
New coilovers to replace the Kei office coiloversW58 and Nite Parts bell housing after a good cleanMachined a new shifter bush to replace the mangled one in there. Looked like someone had a go at removing it then gave up.Using a 4AGZE 225mm clutch, had the pressure plate uprated to 1890lbs, nearly double what it wasBought some T3 knuckles and castor arms- 10
If you want to go with Wilwoods, call MRP and speak to Barry Manon. He'll be able to sort Wilwood calipers and pads, brake lines and he carries adaptors to suit the more common stuff.
Discussion: //oldschool.co.nz/index.php?/topic/48043-pedrac3rs-1985-ae85-levin-discussion/
Hey guys, have been casually browsing these forums for a few years now, thought I would finally sign up and share my AE85 build with you. Ive had the car for about 4 years now, has come long way from when I first picked it up.
It wasnt factory spec when I bought it, someone had already swapped a 4AG in there, with a W58 box, hilux diff and some minor suspension and brake upgrades, 14x6.5 and 7.5 SSR MKII wheels, bolt in half cage which had been welded in, a pretty rangi surge tank, some of the rust had been "repaired". Although it was pretty rough around the edges I thought I had myself a fairly well set up car, until I had been driving it for a few weeks and all the problems started piling up...
Engine bay after a bit of a clean up. Forgot to mention it had been painted a champagne gold colour.
First thing was sorting out the clutch. Was using a 85 pedal box adapted to suit hydraulic clutch, didnt really work, was hard to shift gears and the car would roll forward slowly with it in gear and clutch disengaged. Swapped it out with 86 pedal box from Japan, problem solved. Next problem was the intermitted external fuel pump hooked up to the surge tank. Decided to remove it all run as per factory. While pulling some of the interior out I noticed some of the wiring was pretty rough!
Spent a few weeks going over all the wiring and removing a lot of unnecessary wiring and dodgy solder joints, which there were plenty!
Ended up with a box full wires!
With that mostly sorted, I began on tidying up the rear end a little. Pulled the rear axle out to paint it up, along with a bunch of other stuff, clean up the tubs etc. I had the 4.3 LSD shimmed and went to put everything back together. Getting the bolts through the control arms/diff mounts was a cunt, I figured whoever welded the mounts on the Hilux rear end welded them on the piss so I got the measuring tape out and sure enough, left bottom mount was 20mm out... Would have been causing some serious toe in/out and binding issues. As quick fix I drilled a new hole in the bolt-on traction bracket to correct it.
Made the decision to get a proper cage now that the bolt in cage had been removed and it was rolling again. Herbert Fab did the roll cage.
I took the chance while the car was away getting the roll cage done to have my rear wheels widened. Wheels are SSR MKII 14x9 at -11 offset. Only did the pair for the rear, and put the 7.5's on the front.
Then we had the task of painting the cage. Was a pretty big job prepping and masking everything, but came out pretty good in the end.
Looked pretty red there, but once everything was back in it looked okay
Ill leave it here for today, will have another update soon!
- 20
PedRac3rs 1985 AE85 Levin
in Projects and Build Ups
Pretty much carrying on from where I left off. I made a new shifter... The old shifter looked to be part W58 welded to 85/86 stuff...
And the new parts I machined up
Because I lengthen the selector end by 25mm to reduce the throw of the shifter, I had to make this space plate to compensate for the difference in length
And all together
Put a bend in the shifter, towards the driver side and back a little bit. Big fuck off shift knob installed too
