Everything posted by Not-a-number
Bugatti T57/59 Engine Project
Not-a-number replied to Not-a-number's topic in Projects and Build Ups
Got the runner and other small moulds sprayed with the same stuff. Way easier/quicker than using wax release! . This will save me a ton of time going forward. The runner is 110kg so its going to be in 3 pieces. Just finished printing some partitions. These are the jobs this printer is made for! Instead of spending hours making something from wood I can spend 30 mins on the computer and then its done by the morning!- 143 replies
- 25
That worked quite well. Used a different mould release, sand just fell out of the pattern. Rods are holding it together well by the looks.- 143 replies
- 32
Filling the inner core next. Its about 75kg so cant fill in one go. Going with a partition again but Im going to tie it together a bit better. I think a few threaded rods should work and Ive put some deeper keys in the partition wall/plate. It also needs some lift points so ill put some eye-nuts lifting off the threaded rod. This is where the part goes. Suspended in the middle of the main mould.- 143 replies
- 28
Now I need to drill riser and vent holes in it. Make the big inner core, big runner system and 2 small cores. Fit it all together. Decide if im going to bolt it all together or not. Im concerned its not going to get enough pressure in the top of the pattern where the thin fins are. So im going to add some extra bits which is going to take some mucking around. Then see if the El Camino can carry it (pretty sure it cant!)
Got it flipped over without too much drama. Then removing the pattern was a lot of drama! Took a whole day of slowly wiggling it out with pullers. Usually you pack the sand and 10minutes later pull it from the pattern when its still a little soft. With it sitting for days it was as dense as rock so I had a hell of a time. Came out ok enough. A few cracks and damages to the sand and a few to the pattern!- 143 replies
- 32
Got the rest filled up. We're at 170kg! . Thats a lot of mixing. Now need to figure out how to turn it over without dropping it!- 143 replies
- 34
Yeah thats me. Still have the 7 in NZ, wrapped up in a tarp. I started this blog on there but they had issues at some point and it got deleted.
Starting to fill the main pattern. Got about a 1000lbs of sand on hand at the moment. Should be enough to do the sump Also trying out a proper foundry spray on pattern release. Hopefully it works! Because if my pattern doesnt come out that would be a terrible day/4months worth of work! Have the pattern half full now. I had originally planned more sections but Im having a go at doing it in 4 pieces. That means mixing upto 50kg in one go. Thats hard work! 80kg so far. Another 90 to go!- 143 replies
- 32
Yeah it’s a good point. For me I don’t really care at the moment. For someone replacing an original part they probably would want it to match the engine better. It would be hard to replicate the porosity and dross they have in there so I havnt looked into that. I have looked into aging the Ali though. Can boil in oil, cook in a charcoal dirty fire, acid wash and some other tricks. Will give it a go one day.
Got the camgear covers sent over. Looks like the real deal.- 143 replies
- 32
Pulled the bellhousing inner core. Came out ok. I fill the pattern with raw sand first to get an idea of how much I need to mix. Messed up by 1/2 a kg so had to franticly mix more which meant I didnt pack it well enough. Still more than fine to use.- 143 replies
- 35
Finished the runner system pattern. So now all the sump patterns are complete, waxed and ready to go! . Only took 4 months.haha- 143 replies
- 32
Its about 40kg
Estate auctions I guess. Yeah it does. The modern ones are wasted away. Technically its statically balanced without 'counter weighting' but I have no idea about dynamic balancing. These lived a lot longer than the 59 cranks which were a different firing order. T57 is 2-4-2 dynamically balanced where as the T59 was 4-4.
Did an awesome trade today. I now have a T57 crankshaft. Pretty lucky that it was less than 2hours away from me and the guy was awesome. Traded a bunch of my Lotus stuff + few $, he definitely did me a solid! Crankshaft from Engine #210 Rods from Engine #293- 143 replies
- 63
The last inner core patterns prepped. Now just have the runner pattern and box to figure out.- 143 replies
- 20
Put discs on as it had scary braking. Same old story, get in to install the discs etc and find the ball joints are gone. I get new ball joints and when I get to the 2nd side I find the upright is flogged out (scary). So I do all ball joints and uprights. Then when installing the new booster find that the proportioning valve is in a completely different place with different sized fittings. So replace all the brake lines!
- 13 replies
- 26
Adjusted rockers. Still a bit tappity sounding so not sure whats going on there. Maybe a stuck lifter. It had a dead spot at tip in and surging at cruise. Im certain the timing is good now so went over the carb. It was all gunked up, wire brush in the float bowl and a bent metering rod. Gave it a full rebuild and its now great. Have a new dash and engine harness to put in to clean things up. The fuse block looks ridiculous. Theres a lot of surface rust/corrosion under the dash but only from pedal height up which is weird. The rest of the car is great so I dont know if things just get humid under a dash?
Started goin over the engine. Compression testing @ about 155-165 but cylinder 4 is at 145psi. So I gotta keep checking that and see if it is actually bad. Ignition was way off too. I had 35deg mechanical advance (excluding vac). So even with low static timing I was in the mid 40s which cant be good. So I got a new electronic dizzy and high power coil. Now running 16deg static and 38deg mechanical with 14deg vac. Works way better. It wasnt without its issues though. I didnt know the harness ran an internal ballast. So the coil was only getting 4volts and breaking up at higher revs. Then after I fixed that out the ignition key couldnt handle the higher current coil and started playing up after a while. Put a relay in and fixed that.
- 13 replies
First job was to set up the TV arm correctly. Learning new things but it looks like the 700r4 really needs the cable set correctly or you can burn the trans out within miles Its not just a kick down cable. The arm was completely wrong but luckily not in a bad way. Needs a 1in leverage and was set to about 2in so it was driving the line pressure up really quickly.
Need a ute to carry moulds for the engine project. So I got a 67 El Camino. Picked it up in Tucson and drove it back to CA without too much stress. Has the original 327 with camel hump heads and a modern (/80s) 700r4 trans. Ton of things to sort to make it a daily. Like it doesnt run very well! Timing feels off or vac advance isnt working. Carb seems way too big. It looks good from a distance but dont let the fool you!
- 13 replies
- 47
Main inner core pattern is complete. Will most likely do a partition in the middle of this one too.- 143 replies
- 26
Hopefully not. Its going to take quite a bit of squashing on the sides to get it finished before we can see if thats a problem.
Im pretty sure, from what I've seen of other chassis (and what Pur Sang do), that they would have used a lot of heat and a lot of guys with big hammers. Thats just way too hard work for one person though! Its 4mm!
Chassis Update: My Dads been working away on this when he has a spare minute. Been making various press tools and working out a process. Starting to look like a chassis rail! Not the easiest way of doing it but definitely the most authentic! Also if anyone needs a clock or a barometer restored hes your go to. As long as it doesnt take away chassis building time!- 143 replies
- 65
