Posts posted by kempy
Redesigned the remote to be smaller and simpler.
Finally have the pump assembly together, this fits inside the a cavity in one end of the fuel tank
Fuel Pump, Solenoids and Filters for both Fuel and Propane start.
I had zero luck trying to find a good set of rims that weren't past it with rust so I bought this bike just for the wheels, Felix picked it up for me in CHCH and he reckoned it was too good to tear down so I decided to get the whole bike shipped to Akl which ended up being the right thing to do..
Thanks to the help of Felix and the good chaps at Mainfreight for the shipping, this wee baby turned up at work.
I think I've accumulated 6 frames now, so I hope to get the other 3 up and running for the family beach house, I'll keep this one up to spec so I can go for a ride iith the kids and totally knacker them out!
Annoying kids? no problem!, just flick a switch and blast away with Acme Jet Cruiser...
Starting to put it together now, knew i should have gone slightly larger with the stainless tube as it took 3 hours to feed the pipes and wires through with a lot of silicone.
Loosely mounted on the frame for the first time, starting on the control solenoid mounts and filters in the fuel tank.
Managed to keep it to still just a single bolt to attach/detach,
- 6
Thought it was worth mentioning that the Mexicali guys refused the complimentary drink with meals , he said there wasn't enough people eating there to be worth it for him. Might be time to remove the offer from the OS page?
all you need now is some wire and one of these
Use an electric fence, set up a camera, fun veiwing
another step forward, kinda, I screwed the measurements I wrote down on paper for the rear mount so we need to adjust that, but it's getting closer
couple more pics
Trial fit on the bike frame
Here's the the rear view, still need to adjust the mount width and add a support frame that slides over and locks onth the rear carrier.
The actual jet mounts on the underside of the SS tube and mounting tabs need to be welded on to the frame yet.
Measuring up the fuel lines and control cables to go inside the SS tubing.
You get cheaper Wof's being an AA member too
I hope to be there in Healing fashion.
Not the crystal type, or sexual... unless (complete this sentence)....
I'm hoarding one of those in a similar state, awaiting inspiration.. following
i need to complete the caravan
Bit more progress, ball rolling in the fabrication department thanks to a fellow OSer.
- 9
Ok, "over 11" is what the brain meant but didn't communicate to the outside world.
Is that because they're not standard or have the rules changed? hope not
It has 7000kg of optional extras which will keep it under the required 11 seconds, no matter what you put in it
Right impress i was, Riiiiight impress
Just to add to this a+ writeup..
If you don't have a voltmeter or don't want to spend the coin on one..get a test lamp
and if you can find a test lamp, use your tongue.
See you again next month it seems.
Thanks for a great night.
You guys are so choice.
So many firsts.
You made a little boy happy.
He'll sleep well tonight lads.
Nice impromptu beersies and shedsies!
20" Rims for these cruisers, can you buy new rims on their own? All the ones I have are rusty inside and out and make me a bit concerned they might puncture.
Apart from that it's still full steam ahead.
This weekend at Matakana
Damn I was in hamilton on Sunday and didn't see this until now, see any suzuki AC50 stuff?
Small update, have the prototype of the remote working.
Throttle is black knob, down is off, to left is idle and turn it clockwise for full power, also a mode switch (yellow) and power switch.
Easy start, just turn it on, throttle to min, then up to max for a second and back to min and it begins the auto-start process, to turn it off you just rotate the throttle knob to zero, much easier than trying to hold an RC remote or using the Ground Support Unit.
I'll get some nice stickers made up at some stage.
Got another lot of stainless with nice pre-formed bends and it's ready to start being built.
Hey Rusti, is it one of these?
I have this one and don't use it apart from shocking unsuspecting victims, yours if you want.
The original machine is now in the shed and operating.
much coffee happiness this morning.
Kempy's ACME Healing Cruiser.
in Two Wheels
Control box almost complete, almost as I couldn't find any 6 pin plugs like the other ones I used locally so they'll have to go on later, I'll just stuff a grommet in the hole for now.
This houses the ECU, Battery, a little servo trickery and a whole nest of wires.
Ended up being a lot bigger than I imagined it to be as the die-cast boxes jump from just a tiny bit too small to way to big.
I ended up placing it directly over the turbine for a couple of reasons being that if the turbine decides to let go it has another barrier to get through before it hits the rider, also it helps protect the turbine if I fall off.
Nearly done!
