I could run stainless wire through my existing MIG welder, but for a number of reasons I would prefer to switch to TIG.
I already use a Vortex filtered air feed to a Miller helmet. It's an excellent system. Quite apart from the filtered air, the cool air flow makes it much more pleasant welding in summer, although the downside is getting your face frozen off in the middle of winter. You get used to it. The Vortex / Miller combo costs the raw end of $1200, but once you've used it for a while it's worth every penny.
However it does have a couple of issues. One problem is the loudness of the fan noise travelling up the pipe into the helmet. I finally solved it (after various experiments) by cutting into the pipe and inserting a 1 litre plastic milk container. It doesn't need any internal baffling, and does a great job of soaking up the fan noise.
The other problem is that the Vortex blower runs diagnostics while it's running, with an audible buzzer beeping away seemingly at random, and an internal vibrator going off (like a mobile phone, but more intense). Finally got sick of it and snipped the wires to the vibrator.
The other good thing about the Miller helmet is the X-Mode setting. The helmet picks up the electromagnetic feed when the torch ignites the weld arc. X-Mode is intend for exterior use outside, where UV from the sun will otherwise trigger the helmet. However the X-Mode setting tends to trigger bit earlier when MIG welding inside, and also turns off the shading a bit more quickly. It's the standard setting I use now. Again, one of those things you won't want to be without once you have used it.
Rather than deal with chrome fumes solely by using the filtered helmet, I would prefer to limit the fumes at source as much as possible. I'll be installing some sort of air removal & filtration system at some stage, but reducing the fumes at source will reduce what's needed in terms of air flow and filtration.
I'd like to put up a photo of my helmet setup. How do I go about that? Can't seem to find anything in the edit menu.
