mtbtimr
Posts posted by mtbtimr
My dream is to have the hydrolastic suspension in the 1300 run through a pump/reservoir system.
So i can run it high for day-to-day use, then park up and pump all the fluid into the reservoir to slam it.
Is there such a pump - 12V 300PSI?
What sort of safety valves and shut offs will I need?
Haven't had much experience with hydraulics.
Cheers
Yea my guess would be linkage too - everything was turning as it's supposed to when we fiddled with it.
Day 3: I think the Minis are starting to become suspicious.
- 6
Got pulled over and cautioned for having 4 people in the back of the 1300 trundling down the strip - completely humourless.
Took Maggie down to the Beach Hop over the weekend. Ran like an champ the whole way - only issue was the gross old heater hose finally gave up (nothing a quick trip to ripco couldn't fix).
Got plenty of love despite having half the number of cylinders. Cool to see a few familiar OS faces too.
The cops decided she didn't have room for 4 people across the back...
Couple of the better ones from tonight, had focus on manual for half of them - doh!
- 6
Spotted by someone else at Auckland Uni.
LIVE update, frame was too small for the tow truck so they had to leave to find a smaller truck.
What CFD program have you been using? Would be super handy at Uni at the moment and I'm keen to try it out.
Photodump incoming...
These were all from one day in CHCH.
Sounds like its time for a cruise man
Saw that banana mini at 4&R and Leadfoot, really not a fan of the bodykit or the colour but its all really well done.
Copied GWA and adapted the new, smaller rad to the old shroud/mounts. Turned up a couple of spacers to fill the gap.
Also gave the shroud a quick sandblast - ready for paint.
What do you guys think about...
A. Leaving the OEM fan on and putting the new electric one on the other side VS removing the OEM fan?
B. Swapping to a header tank/pressurised radiator system (like on a mini) VS keeping the current pressurised expansion chamber system?
Discussion link in me sig.
Picked up a new radiator from Redline so that'll be the final piece of the puzzle in the cooling system dilemma. Going to have to sort out some mounting brackets this week and decide whether to route the expansion chamber to the new spout (and get a flat cap for the radiator) or go with the pressurised cap that came with it and put a header tank next to the window washer fluid. Also got a screw on oil filter housing on the way so that should go in this week too.
Im in central Auckland too and happy to come round and give you a hand sometime if you want man.
The gear selector shaft will be under the car running from the gearstick to the back/bottom of the diff. Should be connected at both ends.
The fuel pump is on the engine and it might be having trouble sucking it all the way up from the tank. You can check by disconnecting the fuel line running into the carbs and aiming it into a bucket. Then crank the engine and see if its squirting. Also do the valve clearances (even just roughly if you don't have a feeler gauge). And definitely get a Haynes manual for it. Most worthwhile money you'll ever spend on the car.
how's your fan set up?
was looking at pics including the one of the engine straigth out of the bay sitting on the pallet, then this one
http://i.imgur.com/h64hsKK.jpg
when it was on the pallet the fan blade was on backwards, but this pic shows the fan fitted straight to the belt pulley, then the alloy spacer fitted over top, although this time the fan is fitted the correct 'way round' from what i remember..
you want the spacer to be on in between the pulley and the fan blade, and the fan should sit into the radiator shroud quite nicely.
Yea it's definitely on the correct way now, may have been wrong on the pallet and for the stand photo we just threw it on quickly for looks.
Nice work guys. Once I get a WOF we need to go for a drive!
Yeah dude definitely, I take it you can't make it to the meet tomorrow night then?
Yea we can get a whole new spin-on housing + filter + studs etc for about 60$ so might just do that for peace of mind. Taking out that extra seal and torquing it seems to have fixed it for now but it's pretty sketchy not being 100% sure.. don't really want to drop all our oil and wreck the engine.
Turned out we hadn't taken out the old oil filter seal (doh!)
Will someone have the old school stickers?
Went for a nice long drive out to Takanini and back tonight to see how she's running. All was going great (no overheating, sitting nicely at 90-100kph etc) until we got back to the garage and noticed an unhealthy amount of oil coming from the oil filter housing. Followed the trail back for about a k or so before giving up - luckily there was still a bit in the engine... Looks like its just the oil filter seal thingy so we will fiddle with/re-tighten that and that should be that. Made a right mess of our previously pristine motor though - shit happens.
Has anyone had any experience with redline radiators?
we will be there with bells on!
Turns out this golf lives on my street.
Spotted on manakau road.
where did you buy your flares?
Got them off tardme for 5$ each. They're off an escort.
Hydraulic gurus needed
in Tech Talk
Only up to 300psi. Sounds primo.
