Posts posted by Kimjon
Heaps of clearance, tried it over and over again to find best position. I found that if kept tight close to steering shaft it has very little movement. The twist wire acts like an old telephone cable (showing my age).
Just found this on YouTube
Three things stood out to me.
1) its probably New Zealand?
2) it smokes more than he does
3) holly fuck...it's scary fast for a pedal car with a mini quad engine!!!
So, looks like it should work if I stick to the plan and just pass on your advice (commit).:-)
9 hours ago, a.craw4d said:
Nice power plant choice
One thing I've found with these is they need full right foot to get moving. Once up to speed however they have a little power on hand. Good to start on flat hard ground then hit the rough stuff with full commitment.
Would you recommend one of those reduction gearboxes to overcome this? Top speed isn't really a priority right now
So, I had to grind down one end of a long bicycle cable to a very small size in order to fit the carburetor slide. The other end needs a solution like this:
Now if I'm been honest, this is the MK2 model as the first was a soft M8 bolt which fell apart when I started to tighten it. The above is a M10 grade 8 bolt, which hopefully works.
Crank up your voltage control to get more heat looks like not enough heat. Best to set this on some scrap. Then stich weld in small pulse type passes, around the perimeter until done.
For the cheap helmet, I run electrical tape around that lens you removed to clean. This really helps keep the sooty stuff out. If you ever need to clean, just do it and replace the tape later.
Got to wait for a rear sprocket and a couple other low dollar items like some fuel line a throttle cable. Then I'll weld it solid and it should be all go with 50cc of 2-stroke awesomeness!!!
Hey, have you seen this? Similar - but different...but pretty dam cool!
Just watched all of them, as I'm totally crippled by man flu right now.
That came up well, what did you use?
Kimjon's go-kart "for the kids"
in Other Projects
But God clearly hates gokarts and throws yet another curse my way, the offsets are fucking wrong...balls, arse, cunt, boobies!!!!!
Oh well, back into the scrap bin to search for treasure in order to find a solution to fix my last solution:
