milkchoclety
New Members
Everything posted by milkchoclety
  1. Hey bro sorry to bump an old thread but did you ever manage to find some lowering sorings? I'm trying to find some myself but can't find jack haha
  2. Hi everyone. I own an '84 Bluebird which currently has a FWD CA18E Auto in it. I really want to convert this to a manual, but unsure whether to buy a manual gearbox if possible to fit it to the current motor, or buy an already manual motor. So a couple of questions: Which method will be the easiest/most cost effective? If I were to buy another whole motor, what models would bolt straight in? Would converting to manual be worth it? Cheers
  3. Thanks for your help. It turns out the cable has stretched somehow, so I added a spacer and it works again, atleast until i can find a permanent solution. Cheers
  4. I was driving today and while pressing the clutch down to move up to third gear it sounded like something broke, a sort of knock noise. It wasn't a violent knock, just soft. So now the clutch pedal feels loose, and it will not go into gear easily or at all, my dad had to do some sort of gear rpm timing maneuver to change through the gears without having to engage the clutch so we could get home. So I know it is probably nothing to do with the gearbox, and maybe with the clutch kit. The problem is I dont know where to look for parts that may have broken. Does anyone know what may have happened and how it can be fixed? Thanks The car is a KE20 with a 4k motor.
  5. Hello this is my first question of what will probably be many to come for my KE20. To make a long story short, my ignition chamber has crapped out and need to know how to set up a series of toggle switches and a push switch in order to start. I have searched Google for wiring schematics and other forums etc. but I'm still not 100% sure on which wires to connect to the toggles. I want to have them set up so that they replicate the ignition: one switch is acc, the next is engine power(?) and then push button to wind the engine. I have managed to get the steering lock disabled, so that is not a problem. Sorry if I'm not being clear enough but if you need more info or pics let me know and it would be great if you could help me out! Thanks in advance
