Posts posted by Mof
I have a Samurai, use it in 4wd club, and daily it to work
Yes they are great offroad, but they have no interior space
low power
I do wheel bearings every 6 months
back brake shoes every 6 months
leaf springs every 2ish years
takes a few mods to fit 30" or bigger
from experience I would recommend a Pajero, Especially a softtop as they are already geared for big tyres, front cvs are virtually unbreakable, possible factory rear locker and pto winch (there is a model (2.8 diesel hardtop I think) that has weak rear axle housing)
Terranos are good, especially for starting out, FAAAAR better than a poxy surf
70 series are good, possible factory lockers and pto winch, but prone to rust
MU's have very short front axles and hopeless front travel, leaf sprung rear
Cherokee is monocoque so no body lift, hard to fit recovery hooks because of no chassis, and heavy on petrol
Surfs are like skylines, every A holes got one, so far too expensive for what it is, prone to rust, very low centre crossmember that hangs up on everything, weak front diff
Bighorns are ok, but wide and heavy
my 286 cents....
Front looks fuckin evil
I quite liked the old wheels
Page one
Check it lol
Heat gun works good for bringing the black back in to pp.
I can't remember if it works on pe
Did you remember to fit the release bearing?
Don't laugh it happens
Has anyone ever put stop leak through the engine? That shit is great for blocking up radiators. Might pay to get the radiator rodded
You're both bang on.
There's a bi metal that opens a valve when hot and lets the viscous fluid thru and almost locks it up yada yada
There's a guy in chch that reconditions them. He's very good
I'm sure there's others around the country
Or backyard repair. Open it up put in a piece of rag in and reassemble.
I did this once on the side of the road
Saw this today in the flesh, and it is super low!
What a monster! front end looks eeevil
Ok so the original jump start killed the alternator possibly?
"correct" jump start is positive lead to positive on battery,
negative lead to good earth point on engine (NOT neg on batt)
if not it can kill diodes and whatnot
Edit: good earth like engine lift hook
and on dead vehicle only
Take the Graveley
Tehehehehehehehe
Sorry man biggest we've got is 108mm
Try a truck body builders like Seaview or Hales
Possibly not...
Ill check at work tomorrow
+1
Edit: And answered lol
Flemings in sockburn do great work
Is the door fitter colour blind?
Nah not flywheels
Clutch rebuilds do flywheels and dished ones too
And I think Tony at clutch systems will do your flywheel (only flat ones) free if you get the clutch from them
My old man has a tin box on engine for exactly that
Na its been made to look like a RS2000, the 3 centre gauges have been retro fitted by cutting holes in the face. The Tacho gauge style doesn't match the speedo, you can see the centre needles are red not orange, and the centre gauge is vacuum (rs2000 is oil pressure)someones done a very tidy job though don't get me wrong
Oh and the carb is all cleaned, and reassembled. got the bimetal working perfect on the choke butterflies, tested it with a heat gun. and I picked up a new diaphragm off trademe.
Still not sure about the return fuel line though, I think im going to continue to run without.
And plans are to soda blast the carb and manifold before refitting
Something that isn't a mondeo
- 7
A harder brake lining on the shoes would lessen the braking
Lower the CoF
4mm centre
3mm sides
Over-eager pull on front hook bent the steel, so that's the main reason for the top bars (9mm exterior gusset)
Took measurements around winch (top photo) then drew up plans, the tricky part was drawing the side parts unfolded.
Got steel sheet from mate at Autobend, then got another mate at Hamilton jet to cut and bend, then I did the jigging and welding
it was in random fab thread I think
Edit: the gussets only go about 60mm up the risers, the rest is 3mm
Edit edit:bar weighs 35kg, winch 31kg.
mounted bottom to chassis rails, top mounted with 10mmx40mm bar to brackets sticking above rails half way up engine bay
Never had any trouble with Diggers, that's thru work tho
Lazyness in a bottle
Nothing beats a tear down and proper clean
Best cheap 4wds
in General Car Chat
Seen other leaf springs do that with only 1 ton sitting on it?
Will be for sale early next year to be replaced by a 70 series type Prado.... as long as she stops spending all my money
