Mof
Posts posted by Mof
  1. So pretty much just wire constant 12v wire to battery positive, switched or acc wire into head unit switched 12v wire and earth to an earth, so just wire it like you'd normally wire an amp and ignore the other batt?
    Yes
    (as I just re-read you have the head unit thru 12v reducer)
    Just make sure you take it off the positive of the battery that has the negative going to earth/ground
    NOT the battery that has the negative loop wire/cable going to the other battery
    Remember though, it will reduce the life of that battery
  2. 2 amps off 1 24v battery is not a good idea... theres no way you can get 2 amps to draw the same current, and you will likely still blow stuff up as they wont current share properly. Just get a 24V amp and be done with it? maybe the amp is already 24V tolerant?
    and changing the lead if you run it from one battery is also a bad idea, unless you optically isolate the signal wires from the stereo, and also electrically isolate the amp body from the car, or you will be shorting a battery to ground and melting wires and batteries.
    He meant 1 amp off one battery, 1 amp off the other
    Automotive batteries are 12v. there are no 24v auto batteries
    And Kempy is right, it would have to be the battery connected to ground, unless the amp etc was protected from ground and the earth was put to the same battery negative
    And it would take a long time to damage the battery
    aaand, it would only damage it when the batteries were not being charged (e.g engine not running)
    I don't understand this...
    Amp bodies wont be grounded, it would blow fuses/melt wires if it wasn't mounted well.
    RCA wires will not be grounded
    Speaker wires will not be grounded
  3. You can get balancing charge controllers that would allow that
    Yes, on a 12v system using 2 batteries.
    But not a 24v system with 24v alternator.
    There is available an inverter for doing heavy 12v off 24v supply. But I didn't mention it (and using 2 amps) bbecause I assumed he was not looking to spend money on it. That's why I suggested just taking it off one battery.
    You could change the lead to the other battery every 3 months or so
    Personally I wouldn't bother
  4. Copper-nickel is definitely the way to go, so easy to shape by hand, and flare
    But it is kinda soft and could squash with a whack from a rock or something
    But personally I definitely would, and have used it rather than steel
