rotor_dude
Posts posted by rotor_dude
I had 235/50R13 eagers on my 808 coupe
re rx8
try house of boost, north shore, ask for geoff
i know he had the obd adapter and software to edit the ecu
you do realise the software and adapter is more than a few beers aye
Cheers kiwi808
5 hours ago, Evan said:
Not worth the effort
Really ?
Thought at least the S5 13BT be worth it.
help/advice
1 - rx7 fc series 5 13BT
so i have a really excellent condition series 5 13BT, in pieces, cleaned etc
what is the complete engine block and external parts worth in nz ?
2- rx7 fc parts
what is a complete fc series 5 front end worth ?
is it worth bringing into nz ?
as i have x2, bit rusty as uk, usual, sandblast paint etc mint as lol
ie struts, hubs, calipers, subframe, suspension arms, power steering rack and pump, sway bar, etc
thanks
if you look in a mazda workshop manual, it has the chart for converting etc
so your first picture, the readings need converted to @250rpm
@ 255 rpm - 98 / 102 / 96 - PSI
correct to
@250 rpm - 96.00 / 100.51 / 94.56 - PSI
(sorry calculator convertor uses Kpa not psi, hence extra digits etc)
my bad, sorry shouldnt have made comment
@oldrx7
my bad, now how to explain so it comes out right lol
i thought it was the new version "rotarycompressiontester" tester
the new one, i havent used, as i have the old version as a spare, i use for call outs also
read it gives the readings for one rotor as they are, ie actual readings and then at the actual rpm it was taken at
then next screen it reads them @ 250 rpm which your 2nd pics look like
the first pic show readings, but at 255 rpm, which need converted to 250rpm,
it doesnt change it much as the rpms are so close to 250 rpm,
when you have one that has reading taken at 265 rpm etc it changes abit etc
which i thought the second picture was the first picture readings corrected,
so then thought were is the 2nd rotor readings at whatever rpm it is at then, needs to be corrected to 250 rpm
clear as mud
the first couple rotarycompressiontester versions, only gave readings at whatever rpm it was actually taken at,
you had to use the conversion chart/calculator to convert readings to 250 rpm
How to remove your RX flywheel nut 101
this made me laugh,
moans about someone taping hid unit to oil cooler lines,
then he does this
hmm wonder why a 54mm socket comes in 3/4" or 1" drive, so you can get adapters down to a 1/4" power bar lol
so totally destroys, flywheel nut, center part of flywheel, probably the crankshaft
clutch pressure plate locating pin holes and bolts with angle grinder, must not have had a 14mm spanner
as long as it was done cheap, ie didnt have to pay someone to do it, now needs to buy, crankshaft, flywheel, nut etc lol, yip cheap ftw
looking forward to him working on my car, not lol
Alloy is better than copper. Heat and flow etc.
Different types of alloy cores to.
I had a custom alloy rad made for my mk1
Think it was Christchurch radiators. 20 years ago. $1000. A lot cheaper nowadays. More people doing it.
Plus alloy hose pipe don't collapse when you over tighten lol
what would an RX2 wagon look like ? ? ?
so 80mm ?
thanks
build a 20B center plate
you have to love a series 1 rx2
bad parking james lol
gt 12 slots gt 12 slots gt 12 slots
20B query
exactly, how thick is the thick plate, the plate with the primary and secondary ports in it etc
I'm guessing 100mm. But need exact measurement
also, any chance of some quality pictures, both faces, both sides, top and bottom views
would be very much appreciated
have tried to buy a used damaged plate here, but no luck
@20BRX3
anyone else help ?
Rotary piner thread.
in General Car Chat
so who here owns a FC drift car ?
also drifts it ?
also where from auckland based can you do drifting nowadays ?
