rotor_dude
Posts posted by rotor_dude
........... well ..................ive gone and done it,
dont tell the wife
bought meself a B1600
its a start, will get a better one, one day
if anyone has any B1600 parts, let me know
here she is, in all her glory
broke the bank on this one lol £3.90
- 7
only use NGK sparkplugs on a rotary engine
found other make/brands tend to kill engines
edit. Those who know understand/know
those who don't. Will find out eventually
^^^ thanks
im just after a solid for engine bay, metallic too shiny lol
ill talk to the paint supplier with information yous provided and see what they come up with
thanks lads
@lowmk11
thanks for replying
yeah thought that be the case,
im after the mazda grey used on the flags/banners etc
or a lightish coloured grey, something from the 60's, 70's
im painting my engine bay, want a lightish mazda grey, so can see things easily, like oil leaks and stuff lol
thanks
Sooooo .........
Anyone have the paint code for Mazda grey ?
go the series 4 rx2
yeah na ???
for ya 20B lads
this how you tow your rotor
yarn, true story bro
25 years agoish, was in greenlane, BP petrol station on great south road,
heard ported rotary, ears perked up as usual,
looking, looking, looking, cant see a rx,
bongo van drives past with trailer, with burgundy rx2 4dr on trailer
think bongo was camo'd, black and white
anyone own these ?
thinking, sweet as
edit - 29-05-19
- 6
rolling rollling rolling
ooooh weeeeee check out those dash
hmmmm
brakes,
tbh, the brakes should have been fully inspected,
which means wheels off, no excuse
you need to check the brake shoes for wear, uneven
you need to check wheel cylinders, are moving freely, also not leaking
then you need to adjust the brakes,
yes, drum brakes can be adjusted from outside, inside face of drum, but you wouldnt waste your time unless you knew the condition of the brakes etc
you can check balance, fairly acurately, if you have a good feel for things
2 persons, one in car for brake pedal operation, other with wheel/brake
spin wheel, person push brake pedal, feel when it contacts, do front axle first, so r/f then l/f, a few times to get feel
rear, do same,
handbrake easier to test,
get person to pull handbrake up one click at a time,
go from side to side feeling the brake bite, should be equal bite from within 1 click etc
should bite at 4 clicks be fully locked at 7 clicks
exhaust,
no excuse for a exhaust after its been looked at,
easy to test, engine idling, hold a good thick rag over end of exhaust, another person check for leaks
no excuse this wasnt fixed, either by cleaning and resealing joints with joint sealer, or replacing joints or exhaust pipe
give them another go, if not fixed, go elsewhere ?
raflol
not something id put on my car to the masses, kids these days lol
i picture a shotgun when picking up the girl from her olds, her old man wouldnt be impressed lol
im a RX8 Owner and Proud to be
@ kyteler,
tbh, i wouldnt know, your telling the story, something to come out about ?
seriously loving this would make an awesome work shitta
even with a piston engine, it be cool
sounds really good
be nice if they videod the engine bay with bonnet up and engine running too
not the black paint colour
ditch the ramflow, man there crap, restrictive and end up the wee bits being sucked into your engine, nice
cant believe there still being used lol, old school looks
dont get the plate either ?
anyone want to buy it for me
https://www.trademe.co.nz/Browse/Listing.aspx?id=2156759661
10 hours ago, oldrx7 said:
Motoform Circs huh!!!
Yip I liked them, thats how i rolled back then
Was like 20 years ago
Slideways
Not to me. Same thing I do. Pretty sure most car guys do
If you do buy both. Make sure you start threads for each
If you do buy rotary engined car. Sell engine. Give a heads up here first
Keep us updated
slideways,
are you buying it for the car, to refit a piston engine
or buying it, just for the engine ?
anything is worth something to the right person
you need to reply with pictures and details to get a better guestimate
could be a 13B from a cosmo etc also
it has a alloy thermostat housing
old style alternator with external fan
short straight oil filler tube
so who knows, as said anything could have been changed over the years
yes, engine sitting not being turned over or running, is not good, especially to a rotary engine
seals/springs tend to stick, water seals tend to go
again, you dont know until it is checked over, compression tested and diagnosed
make sure you turn it over by hand first
remove all sparkplugs, note which position they go in to refit correctly
then put some ATF oil in through the sparkplug holes, also can do down carb with throttle fully open
again turn over by hand
if turns over by hand, you could crank it over by key, with the fuel turned off and ignition power disconnected
looks like disconnect the power to the fuel pump as its sitting on engine
ignition, remove the electrical connectors on the distributor, again noting position to refit correctly
then crank by key, if you put finger over trailing sparkplug holes, you will get an indication of compression, should be x3 pulses
then if cranks over ok, check and top up fluid levels
then refit, sparkplugs, fuel, ignition,
try to start, you could drop some fuel down carb etc
take pictures of engine from sparkplug side and post
you will find 12A or 13B on the alloy part of engine, rotor housing, its on the top of rotor housing, either on top or left edge of rotor housing
i think the blue 808 with rx3 conversion for 35k should put his price up to 50k may get some bites then
or try advertising in aus
seen some nz prices on rx's in aus too
12 hours ago, 64valiant said:
more info/pictures required please
now that is styling
5x114.3 is man
4x110 is boy
4x114.3 is young boy
14 hours ago, kiwi808 said:
Surely this guy is dreaming.
From memory this was imported as a race car only? Can anyone remember?
i think, you should really wait, till hes painted it etc
then you can buy it for 65K plus
Rotary piner thread.
in General Car Chat
bit late also
ill edit and update with info and pics when i can
well mazda rotary intro, i was 13, my brothers mate had a rx3 s1 coupe 10A engine, took us for a spin, was hooked, so smooth and went very well
then bought my first rx when i was 19, rx2 s1 capella coupe 12A
then couple months later bought my first used engine lol water seals gone, had to park on a hill so could bump start lol
my mazda & rotary list
- 1964, Ford, Cortina, Mk1, 4dr, baby blue, RX4 13B Monster J-Port, GMC 4/71 Supercharger, toyota g/box, toyota hilux diff, FC brakes Front & Rear, 17x8.5 ZS Wheels
etc etc
- RX2, S1, 12A Capella, coupe, yellow, sold, regret lol
- 808, coupe, rx3 S2 replica, blue, sold, regret lol
- RX7, S1, 12A - work hack, white, blew a few engines and diffs lol, sold
- 323, 5dr, wagon, shitte brown, piston, sold
- 323, 5dr, wagon, baby blue, piston, sold
- RX7, S4, 13BT, blue - work hack, yeah right, sold
- RX7, S3, 12A, blue
- RX7, S5, 13BT, black
- RX7, S3, 12A, green
- RX7, S5, GTR, 13BT, grey
- 626, 2.0L, petrol, automatic - work hack
- RX7, S5, 13BT, red, sold
- 1300, 4dr, wagon, piston - completely rotten, needs reshelled
- RX7, S3, 12A, green - fitted rx8 13B 6-port with IDA and Distributor and rx8 6 speed g/box
- RX7, S5, 13BT, white - ended fitting engine to another car and stripping for parts, sold
- RX7, S6, 13BTT, black - fitted S5 single turbo, sunday car, blew engine, slowly getting engine ready to repair
- RX8, S1, 13B 6Port, Plurble - my rx8 baby, 3" big bore exhaust, 20" wheels, factory front air dam, side deflectors, rear deflectors, other engine mods etc
- RX8, S1, 13B 4Port, grey - bought to rebuild engine and sell .......... yeah sometime lol
- RX7, S4, 13B 6Port, white - done few mods to engine, exhaust etc, sold
- RX8, S1, 13B 6Port, grey - turning into a track car ..........
- Demio, white, 1300cc big block, scrapped
- Demio, 1300cc, grey ........... daily shitta
ive had, 12A, 12AT, 13B, 13B 6port, 13BT, 13BTT
Stage 2, Monster J-Port, PP, Turbo, Supercharged, in various configurations etc
Im building a budget build rx8 4 rotor PP for my 50th, either in a, rx4 coupe or jc Cosmo.
rx8 3 rotor for my rx8,
FC S5 13BT 500bhp for my FC drift car,
One other secret engine. Old school. Think it will suit a RX2 coupe S1 or S2 or S4
