Posts posted by fletch
Negative. Still direct drive
Make dirt day standing starts interesting, but not impossible
start it Like a chainsaw
Hold rear wheel off the ground
Bring revs up
When says go clench throttle
Drop bike and grab bars/jump on before it hooks and enjoy skid off the start line
Forgot to add- spray dirt in the faces on the people behind you
Keen as to get involved in this.....
Minor issues stopping me.
Lack of fab' skills.
Oh, and Lack of fab' skills.......
Lol.
Like someone else has said, I'll swap you for some painting tips.
I'll have my welder and a bender set up by next winter.
You know where my shed is...
I'm keen for whatever.
Am planning to make a bunch of Tru test frames for anybody that wants one.
After talking to sparky, I reckon a cam and some more gear reduction will get me going a bit faster.
Would love to keep the drome part of it as the dirt day really stuffed me.
Why can't I lift my arm above my head?
Also, my shoulder hurts now.
Sooo tired.
Might go online and find some bigger rear sprockets tonight....
Just passed the crossing aka 2016 Nats.
I'll be there around 130. Don't wait up.
Family lyfe. ....
At this stage i can only assume the blower will be ok with the "wet" system. It is a GM671 styled blower that normally sits on top of smelly old chevs with 4 barell carbys sitting on top.
The idea for the Meth/water set up was to cool the intake charge to avoid any possible detonation problems.
In the past when i have worked on blower set ups ive always seen or installed a backfire plate.
Im unsure if one will be needed on this job ? (will probably fit one anyway "just encase")
There will be no fuel running through the blower, just air.
The 1UZ injectors are being replaced with a set of 8 x 440cc RX8 Denso Injectors.
Im told to run a 50/50 mix of meth/water.
With this in mind im guessing it would be flammable ? Like you couldn't "lite" the mixture ?
If running the meth/water injector post blower would any pooling even occur ?
Put it between the throttle and blower. The liquid going through the lobes helps cool them, and also takes up a bit of the clearance between the lobes and the housing resulting in more flow and less heat.
A backfire plate is a good idea, any backfire will only be short lived as you won't be injecting a huge amount of methanol. Plus I take it you will have the injector stop as soon as you shut the throttle, so when it goes bang and you shit, you will also shut the throttle and it's all good.
Should have half a wag spare
Got Friday off now. I can be middle of the island by 12 at the earliest.
Sam, reckon I can turn the face off my high speed sprocket at yours?
I'll be in my wagon if that's all good? Saturday night and possibly Friday if I can get the day off.
Can do. Sent you a message
In for Saturday and Sunday.
Trying to organize Friday off work.
i went in search of suitable tyres today. the chinese wheelbarrow tyres i currently run are not really load rated. or speed rated
The only thing suitable i could find rubs on the head worse than the current ones.
Anybody actually keen for this week?
Weather looks to be shithouse.
Square drill bit
6
Give me the 3.9 and you won't have the problem
You haven't mentioned the water pump?
If you have good air flow it may be lack of water flow.
The replacement radiator might have been an attempt to cure the problem that could be just low water flow?
Next one Wednesday 26th October.
Couldn't make it last week as Mrs popped out another child. Aka drain on my future car funds...
Should be able to get a car legal over the long weekend and see you all there.
No more cruising under the cover of darkness
No idea tbh
I'll get under again and have a measure up,
Some new bushes first wouldn't go amiss and I know one of the leaf mounting bolts is seized
When you pull the diff, have a fuck about with the springs. Try change side to side, see if they hang on the piss. Might be able to correct it a bit.
New Plymouth Monthly Meet - Wednesday 30th November
in Lower North Island Region
It's time again. Been a long month.
Metservice says weather will be mint if your a river creature.
Also means the 50 won't be checking wof's in the rain.
See you there!
